Warco 220 Need help with missing parts please
Sam Bernard | 03/01/2022 18:22:57 |
3 forum posts | Hi everyone, I recently brought a new lathe a warco 220. Unfortunately it didn’t come with any change gears apart from a couple for the feed. would anyone who owns one be willing to help me figure out if I’m missing any bits eg. Going from feed setup to screw cutting setup, is there any bushings etc I need to make up. If you could give me sizes etc of the parts I would be most grateful. also with regards to the change gears would I be correct in believing they are module 1.5 with a 20 pitch. I’m thinking I may buy some 1.5 spur gears and modify them to fit. Any suggestions?
Dave Halford | 03/01/2022 23:20:37 |
2536 forum posts 24 photos | Might be something in here |
not done it yet | 04/01/2022 07:21:12 |
7517 forum posts 20 photos | with regards to the change gears would I be correct in believing they are module 1.5 with a 20 pitch. Use the formula for calculating the MOD, using the (tooth count + 2) and diameter of the gear, to confirm, or otherwise, your belief. |
John Haine | 04/01/2022 08:13:55 |
5563 forum posts 322 photos | I assume you mean mod 1.5mm, 20 degree pressure angle? |
JasonB | 04/01/2022 08:34:58 |
![]() 25215 forum posts 3105 photos 1 articles | Ive not seen MOD expressed in mm before, generally just a number eg 1, 1.5, 2, etc which once multiplied by pi will give the circular pitch in mm. 20pa would be most likely. Divide the OD by number of teeth +2 to get the MOD |
Nicholas Farr | 04/01/2022 09:02:34 |
![]() 3988 forum posts 1799 photos | Hi Sam, this chart shows all the change gears that came with the lathe I have Selection Chart there is a little info about the machine Mashstroy there are some oddments of info in my Warco 220 album I may be able to have a look at my change gears later or in the next day or two. Regards Nick. |
Peter G. Shaw | 04/01/2022 09:21:00 |
![]() 1531 forum posts 44 photos | There is something odd, which frankly I haven't looked into so don't understand it, in that the two largest gears, I think it's the two largest, are stamped with a different number compared to the others. Unfortunately, they are on the machine and this morning is the coldest yet this winter! Brrrrr.... Sam, Have you got the so-called manual that goes with the lathe? If not, then I have a copy of the original pink handbook stored on my computer complete with their version of English! It's no big deal to email it to you if you wish. I've also got a copy that Nick Farr sent me: this version being done by Warco (I presume) and is in better English and printing. I'm sure Nick won't mind me saying this. I've also got photos, drawings, info, about some of the bits & pieces of the lathe - unlike Nick, I haven't got an album, so if you want something, ask, and if I've done it, then it's yours for the price of an email. Cheers, Peter G. Shaw |
Nicholas Farr | 04/01/2022 09:27:42 |
![]() 3988 forum posts 1799 photos | Hi Peter G., I have no problem with you sharing any info that I've sent you regarding the Warco 220 lathe. Regards Nick. |
John Haine | 04/01/2022 10:05:22 |
5563 forum posts 322 photos | Posted by JasonB on 04/01/2022 08:34:58:
Ive not seen MOD expressed in mm before, generally just a number eg 1, 1.5, 2, etc which once multiplied by pi will give the circular pitch in mm. 20pa would be most likely. Divide the OD by number of teeth +2 to get the MOD Pitch diameter = #teeth x mod in mm. So the units of mod are mm. Normally they aren't included as "mod" is assumed to be a metric system of gear definition, but I wanted to be clear since the OP said a 20 pitch. I am assuming that a pitch of 20 DP is not intended! Also it would have to have units of mm to give the circular pitch when multiplied by pi. |
JasonB | 04/01/2022 10:43:48 |
![]() 25215 forum posts 3105 photos 1 articles | John, agree the answer is metric but I've never seen it written as Mod#mm. Much the same way as we don't write 32DP" or 32DP inches but all the calcs using the DP give an answer in inches. |
not done it yet | 04/01/2022 11:03:24 |
7517 forum posts 20 photos | JB DP would be in 1/inch in units as it is a number (no units) divided by a length (diameter, in inch units). I suppose if one looks up the definition of DP (from a proper text), it will define the result of the calculation as the numerical DP, not including units. Same with metric gear MODs. They likely neither include units as they are derived specifically from mm or inches, so are specific to the particular system. |
Howard Lewis | 04/01/2022 12:39:07 |
7227 forum posts 21 photos | If it really a new machine, the supplier should supply any gears that are missing, since it has been short shipped. If it "New" to you, but used,, this may help. Being a recent machine, the gears are very likely to Module and 20 degrees Pressure Angle. OD in mm / (Tooth Count + 2 ) = Module So a 1.25 Module gear with 60 Teeth would be 77.5 mm OD. Once you have found which gears are missing, you could ask WARCO if they can supply. It is possible that gears from a later machine would have the same Module, width, bore and keyway. Howard
Nicholas Farr | 04/01/2022 13:56:00 |
![]() 3988 forum posts 1799 photos | Hi Howard, the Warco 220 is an old lathe, I bought mine second hand way back in about 2005 and they were not in Warco's 2002 catalogue, so there's no guarantee that they will have any spares now for them, Sam could always ask of course. Regards Nick. |
Sam Bernard | 27/01/2022 04:47:13 |
3 forum posts | Posted by Peter G. Shaw on 04/01/2022 09:21:00:
There is something odd, which frankly I haven't looked into so don't understand it, in that the two largest gears, I think it's the two largest, are stamped with a different number compared to the others. Unfortunately, they are on the machine and this morning is the coldest yet this winter! Brrrrr.... Sam, Have you got the so-called manual that goes with the lathe? If not, then I have a copy of the original pink handbook stored on my computer complete with their version of English! It's no big deal to email it to you if you wish. I've also got a copy that Nick Farr sent me: this version being done by Warco (I presume) and is in better English and printing. I'm sure Nick won't mind me saying this. I've also got photos, drawings, info, about some of the bits & pieces of the lathe - unlike Nick, I haven't got an album, so if you want something, ask, and if I've done it, then it's yours for the price of an email. Cheers, Peter G. Shaw Hi Peter, Many thanks for your response. When you swap over from turning to screw cutting I understand that you need a short tee nut and also a bush, would you mind giving me the sizes of these components? A picture of the setup in screw cutting mode would be really helpful. Ive brought some off the shelf gears that I’m modifying to fit.
Peter G. Shaw | 27/01/2022 10:18:58 |
![]() 1531 forum posts 44 photos | Sam, May I suggest that you use the private messaging system to send me your (or a suitable) email address. The reason is that I have, so far, turned up two photos which I believe are what you may be asking for, a word document I did some time ago on fine feed and a set of drawings which I did some years ago when I managed to break the triple pulley block on the finefeed mechanism. This drawing shows, I think, all the parts that you are asking for. It will have to be a pdf, unless you can read drawings from Design Cad Pro! Also, the measurements will be as I measured them, and I rather think that there is space for rationalisation, eg, a dimension of 4.06mm is probably meant to be 4.00mm. At least, if I was designing from scratch, I would be very unlikely to use such odd dimensions. All in all, a lot of stuff to put on the ME/MEW forum - not for any reasons of secrecy, just the practicalities. Cheers, Peter G. Shaw |
Daniele Farronato | 09/09/2023 18:04:36 |
1 forum posts | Buon giorno a tutti, sono un nuovo mambro e sono inesperto in materia. Sto imparando da autodidatta. Sono da poco venuto in possesso di un tornio mashtroy(warco 220) sto cercando di restaurerlo, però non ho un libretto istruzioni, ho visto che ci sono dei giochi nelle chiocciole in ottone, e non so il passo della vite senza fine. Qualcuno nel gruppo mi può aiutare? Informazioni, disegni, ecc. Ne sarei molto grato grazie |
JasonB | 10/09/2023 10:01:19 |
![]() 25215 forum posts 3105 photos 1 articles | My computer auto translated this when I approved it this morning, for those that can't translate "Good morning everyone, I'm a new member and I'm inexperienced on the subject. I'm self-taught. I have recently come into possession of a mashtroy lathe (warco 220) I'm trying to restore it, but I don't have an instruction booklet, I saw that there are some games in the brass nuts, and I don't know the pitch of the worm. Can anyone in the group help me? Information, drawings, etc. I would be very grateful, thank you" |
DiogenesII | 10/09/2023 10:11:59 |
859 forum posts 268 photos | 'Play in the nuts and I don't know the pitch of the screw'? ..does anyone have enough Italian to ask whether Daniele means the leadscrew or feed-screws? |
Ady1 | 10/09/2023 10:20:56 |
![]() 6137 forum posts 893 photos | Big worm or little worm (in italian) |
Ady1 | 10/09/2023 17:35:32 |
![]() 6137 forum posts 893 photos | Got a message: Buon giorno, sto cercando i passi delle chiocciole in ottone tutti e due grande e piccolo. Grazie mille Good morning, I'm looking for the steps of the brass snails, both large and small.
anyone got the TPI for the leadscrew nuts pls http://www.lathes.co.uk/mashstroy/ https://docs.hacman.org.uk/instruction_manuals/Warco-Lathe-220.pdf I'm guessing the main half nut is 4mm Edited By Ady1 on 10/09/2023 17:57:38 |
