pgrbff | 29/11/2021 07:02:19 |
261 forum posts 31 photos | Do these have another name? I can only find them for sale in the US. Where might I find one in the UK? I'm in Italy so my search engine would not give me as many good hits as someone in the UK. |
Clive Hartland | 29/11/2021 07:15:37 |
![]() 2929 forum posts 41 photos | Hexagon shaped dies are not used for cutting threads, they are used for cleaning damaged threads. Thread cutting dies are normally round with a slit and can be adjusted in the die holder. |
DiogenesII | 29/11/2021 07:29:13 |
859 forum posts 268 photos | Buy a cheap (i.e. 'soft' ) 6-point socket and either put a handle on each side or turn it into a round 'adaptor' to fit a split-die holder? Edited By DiogenesII on 29/11/2021 07:29:33 |
JasonB | 29/11/2021 07:29:26 |
![]() 25215 forum posts 3105 photos 1 articles | Ir read it as wanting to hold round dies in a hex block Should be easy enough to make one from say 1.5" hex bar or just mill six flats onto some round bar, bore a pocket for the die and add the grubscrew holes. When I have not been able to turn a die in a standard holder I have used the round holders from my tailstock dieholder and used grips on them.
Edited By JasonB on 29/11/2021 07:30:38 Edited By JasonB on 29/11/2021 07:34:20 |
DiogenesII | 29/11/2021 07:36:11 |
859 forum posts 268 photos | I must not overthink things.. |
Nicholas Farr | 29/11/2021 07:39:02 |
![]() 3988 forum posts 1799 photos | Hi, I used a couple of big standard hexagon nuts to make these two. Regards Nick. |
DiogenesII | 29/11/2021 07:39:45 |
859 forum posts 268 photos | Posted by JasonB on 29/11/2021 07:29:26:
...When I have not been able to turn a die in a standard holder I have used the round holders from my tailstock dieholder and used grips on them.... ..never had you down as a 'Stillsons' sort of guy, Jason - I'm appalled.. |
JasonB | 29/11/2021 07:45:55 |
![]() 25215 forum posts 3105 photos 1 articles | They are on UK e-bay |
JasonB | 29/11/2021 07:53:47 |
![]() 25215 forum posts 3105 photos 1 articles | Thinking about it a bit more I'd probably make them like this. That way you could get a socket on the end or if in a tight space use a smaller |
pgrbff | 29/11/2021 11:18:03 |
261 forum posts 31 photos | Posted by JasonB on 29/11/2021 07:29:26:
Edited By JasonB on 29/11/2021 07:30:38 Edited By JasonB on 29/11/2021 07:34:20 Unfortunately I'm a woodworker not a metalworker. In the process of restoring an old bandsaw. |
pgrbff | 29/11/2021 11:20:01 |
261 forum posts 31 photos | Posted by JasonB on 29/11/2021 07:45:55:
They are on UK e-bay You must be seeing something I can't. I tried eBay first. As most of my metalworking tools don't get a lot of use I often buy used British tools rather than new imports. |
pgrbff | 29/11/2021 11:24:46 |
They are on UK e-bay OK, found it. Thanks. £27 postage to Italy, and the price of the item goes up to nearly £7! |
pgrbff | 29/11/2021 11:27:03 |
261 forum posts 31 photos | Posted by Clive Hartland on 29/11/2021 07:15:37:
Hexagon shaped dies are not used for cutting threads, they are used for cleaning damaged threads. Thread cutting dies are normally round with a slit and can be adjusted in the die holder. I had no idea that was the difference. Thanks The quality of the fixings on my bandsaw is terrible and after many years of use, a lot of the threads are in a very poor state. I'm cleaning them all up. |
larry phelan 1 | 29/11/2021 11:37:51 |
1346 forum posts 15 photos | We used to call them dienuts, only used to clean up threads. |
Bill Phinn | 29/11/2021 12:58:46 |
1076 forum posts 129 photos | Posted by Clive Hartland on 29/11/2021 07:15:37:
Hexagon shaped dies are not used for cutting threads, they are used for cleaning damaged threads. I've read this many times, but never seen a satisfactory explanation for the distinction. All the hex dies I've seen have a lead-in taper, and, whilst all I've seen have been solid, solid round threading dies appear to be as common as split round ones. In either case, if you prefer a split die and your die is solid it's usually easy enough to make it into a split die. Obviously, in the case of hex dies you have split yourself you would have to use the die in some kind of die holder to make use of the split. Did the distinction arise, I wonder, not because hex dies can't be used perfectly successfully for cutting new threads, but simply because the intended market for hex dies was originally for areas of industry (such as the automotive trade) where the need for threading tools was mostly for rethreading purposes rather than for cutting new threads and the workers wouldn't necessarily have access to die stocks but they would of course have sockets and spanners? I note that Machinery's Handbook isn't completely rigid about it, saying hex dies "are intended for repair work".
Edited By Bill Phinn on 29/11/2021 13:04:16 |
Clive Hartland | 29/11/2021 14:05:03 |
![]() 2929 forum posts 41 photos | If you start cutting threads with a Hexagonal die nut the pressure will burst the die nut, just clean threads with them or use to identify a thread.. They are particularly good for checking long threads and as they go slack you can tell if the thread is worn.. |
Bill Phinn | 29/11/2021 15:18:54 |
1076 forum posts 129 photos | Posted by Clive Hartland on 29/11/2021 14:05:03:
If you start cutting threads with a Hexagonal die nut the pressure will burst the die nut Why is that? Is the cutting diameter of a hex die smaller than that of a solid round die? If so, why? Edited By Bill Phinn on 29/11/2021 15:20:30 |
JasonB | 29/11/2021 15:21:55 |
![]() 25215 forum posts 3105 photos 1 articles | Clive what's the difference between a die nut and an unsplit die that will make the nut burst? If anything Die nuts are longer so should have more metal and be less likely to burst. Most of the unsplit dies that I have are marked with a tolerance and will cut a thread perfectly well without bursting and if I was working to a tolerance would produce a thread to that rather than being +/- which is what you get using a split die. |
Michael Gilligan | 29/11/2021 16:27:53 |
![]() 23121 forum posts 1360 photos | I doubt if it’s definitive … but here is the description of Die Nuts from RS Components: A die nut, also known as a thread chaser, is used for sharpening an existing thread. It is run over threads that may have been damaged or blunted over time to correct them to their original condition. It looks the same in appearance to a square or hexagonal nut. They are easy to use and can be operated using an ordinary box spanner or set spanner. They are available in various sizes, types and threads, with this information being engraved on their front surface or face. . Ref. **LINK** https://uk.rs-online.com/web/c/hand-tools/threading-tools/die-nuts/ MichaelG. . Edit: __ and Cromwell references a couple of Standards [which presumably are definitive: BS 1127. Edited By Michael Gilligan on 29/11/2021 16:34:04 |
clogs | 29/11/2021 16:32:01 |
630 forum posts 12 photos | I was offered some Square die nuts the other day....most were BSF n Whit..... no use to me other than for display.....no idea how old they were..... would have bought them just for show but the guy thought they were made of GOLD considering the price.....lol... I have a few old tools that are just for looking at.....
