Best grease for taper roller lathe spindle?
Alan Jackson03/11/2021 17:38:23
276 forum posts
149 photos
I am about to regrease my Stepperhead lathe spindle just to check the bearings etc. At present the bearings are lubricated with moly grease, but I just wonder if there is a better choice.
Alan
Dave S03/11/2021 17:47:11
433 forum posts
95 photos
Why did you use moly grease in the first place?
IIRC moly is an EP additive, for use when there is considerable pressure and the lube film may break down.
I would think a quality lithium grease would be fine.
Howard Lewis03/11/2021 18:04:42
7227 forum posts
21 photos
+1 for Lithium or Calcium grease.
Molybdenum grease may be OK where there is sliding motion, but it is not ideal for rolling motion. In the very worst case, it might even lubricate so well that the rollers do get enough grip to roll!
John Haine03/11/2021 19:01:34
5563 forum posts
322 photos
Would that matter? Lower friction surely?
old mart03/11/2021 19:03:09
4655 forum posts
304 photos
Use a lithium high melting point available from any car spares shop. The moly grease is not recommended for rolling element bearings as the molydenum can make the surface brittle chemically, as already mentioned it is best for plain bearings. The original grease might have had graphite in it making it black colour. Only fill the space 50% maximum to allow the grease to be displaced from the bearings as they move.
Edited By old mart on 03/11/2021 19:06:08
Neil Wyatt04/11/2021 13:50:18
19226 forum posts
749 photos
86 articles
I like Teflon grease.
Tim Stevens05/11/2021 18:24:27
1779 forum posts
Teflon is a solid.
Tim
Simon Collier05/11/2021 19:28:25
525 forum posts
65 photos
Colloidal Teflon suspension, I think. I have Nulon grease too.
Samsaranda05/11/2021 19:44:18
1688 forum posts
16 photos
I wouldn’t use moly grease with roller bearings, it can cause total failure, ask me how I know. Dave W
HOWARDT05/11/2021 20:30:21
1081 forum posts
39 photos
Kluber. We always used NBU15 in high speed spindles but there are many more options now.
RMA05/11/2021 20:51:03
332 forum posts
4 photos
You don't need anything more than bog standard Lithium soap grease. High melting point grease is wasted unless your lathe bearings approach boiling point or beyond. Only fill the cone with grease, packed into the cage and rollers, and no more.
Peter G. Shaw06/11/2021 12:57:51
1531 forum posts
44 photos
My lathe manual recommends a grease type with many letters, dashes etc. I queried this with Castrol, and was told that their standard lithium grease, type LM, was a suitable equivalent.
Peter G. Shaw
Alan Jackson09/11/2021 16:48:36
276 forum posts
149 photos
I thank you all for your suggestions and have decided to use Silicon grease with Teflon. I seems to be a bit quieter when running so all is good.
Thank you
Alan
RMA09/11/2021 18:44:34
332 forum posts
4 photos
Seems an odd choice for a tapered roller bearing.
mgnbuk10/11/2021 08:06:03
1394 forum posts
103 photos
+1
Always regarded silicone greases to be mainly a rubber / plastics lubricant. Perusing some lubricant & bearings manufacturer information suggests that it can be used for rolling element bearings under specific conditions (i.e very low operating temps for lightly loaded bearings), but it does not appear to be a general recommendation. One bearing manufactuer mentions derating the bearing load ratings to 1/3 of normal if using silicone grease & grease manufacturers mention "low speed, low loading".
Really can't see why you would want to use this product in this application - just use a plain lithium bearing grease with no additives as recommended by the bearing manufacturers. Given that TRBs "pump" lubricant from one end to the other, making provision for easy re-greasing would be advantageous.
Nigel B.
RMA10/11/2021 09:16:51
332 forum posts
4 photos
Unlike sliding bearings, tapered roller bearings don't actually need much lubrication. The rollers roll, and the only area that 'rubs' is the end of the roller and its mating cone face. When I left the bearing industry and went into research it was becoming common for machine tool manufactures (and we had plenty in the 60's) to use oil mist lubrication which has many advantages.
Maybe the motor industry is to blame for all these additives which arguably enhance performance. Even in engines, the quantity of oil actually used for lubrication could be significantly reduced if it wasn't necessary for it's cooling action.
Bearing manufacturers have been recommending ordinary Lithium soap based grease for decades, and they do very deep research before recommending anything. Why ignore it and waste your money on products designed for different applications?
It's your machine and your choice at the end of the day.
Robin10/11/2021 09:30:56
678 forum posts
Silicon grease got a bad press from the airgunners who found it promoted, rather than prevented, galling. Probably fine for a rolling contact but you might want to be careful what you do with the rest of the pot.
KWIL10/11/2021 10:27:44
3681 forum posts
70 photos
My M300 uses extremely expensive Gamet Super Precision Taper Roller bearings with ISO32 Hydraulic Oil with the headstock gearing "throwing" the oil for a continuous feed. If it was lathe with no oil feed system I would use Lithium Grease only. Greased bearing run at lower speeds.
Speedy Builder510/11/2021 11:27:58
2878 forum posts
248 photos
All these silicone and teflon based greases - not good if you ever decide to do any painting within 20 miles of the workshop !! Just a smidgen of grease on your hand and paint will not stick to your project. I used some silicone spray outside the workshop as a mold release agent for some epoxy casting. - I wish I hadn't !
Bob
Alan Jackson10/11/2021 11:30:44
276 forum posts
149 photos
Thank you all for you recents comments on silicon grease with teflon. I bow to your better knowledge and have ordered some lithium grease which will be used. Luckily it is quite easy to remove and replace the spindle.
Alan
