Warco HV6 rotary table
Great item.
Bryan Cedar 130/10/2021 14:43:17
127 forum posts
4 photos
Having purchased a 6" rotary table from Chronos, I hope I am permitted to say this. The Chronos table was very poorly finished and the engraving was barely visible through the corrosion. I think this was a returned item.. The cranking handle was fixed on its spindle. It went back. Purchased a 6" one from Warco and what a difference. Beautifully finished smooth as silk good legible engraving and finish with a fully rotating handle. Backlash adjusted to virtually nil. Good job Warco!
Bryan Cedar 130/10/2021 14:51:29
127 forum posts
4 photos
Forgot to say the Chronos table was sold as a Soba make. The package was all in all a very similar price for both deals.
larry phelan 130/10/2021 17:20:07
1346 forum posts
15 photos
You lose some, you win some !
Sometimes !
Howard Lewis30/10/2021 17:33:43
7227 forum posts
21 photos
Hopefully, the chart supplied with Division Plates for the RT will not contain the errors that were present on my now elderly Vertex HV6.
The RT itself, was OK, just that there were errors in the chart supplied with the Division Plates. The first of which was found the hard way after thinking that i could not count. Of course it had to be in the number of Divisions that I wanted to produce!
Having made up a spreadsheet, I found that there were eight errors or omissions in the chart. Probably the result of misreading hand written figures.
Apart from three pieces of scrap, and each waiting for Loctite to cure, eventually, a week spent to good effect
not done it yet30/10/2021 17:37:43
7517 forum posts
20 photos
Vertex have a good name amongst rotary tables. Please tell us why you even considered an alternative if the price difference was marginal.
Or maybe if wasn’t a Vertex - but looks very much like one.
Edited By not done it yet on 30/10/2021 17:54:27
Bryan Cedar 130/10/2021 18:08:28
127 forum posts
4 photos
Posted by not done it yet on 30/10/2021 17:37:43:
I did not need the Vertex as for my needs was a bit over kill. The one from Warco looks so close to a Vertex that I doubt there would be much advantage to spend some £100 more. I am happy now. The price difference was between the Chronos and Warco one, making the Warco a bargain
Chris Crew31/10/2021 22:32:13
418 forum posts
15 photos
With a lot of internationally sourced items, lathes, drilling machines and accessories etc., I get the impression that there are some big factories somewhere each exclusively producing one item which are then sprayed different colours and branded with different names but are essentially identical. Drilling machines especially all seem to be of the same design and specification whatever the colour or brand may be. I may be quite wrong but the similarities of most of the items on the market are easy to recognise. I have also noticed this with cheap DIY power tools which all mostly seem to perform just as well as a 'branded' item. I have found this with the Clarke brand as marketed by Machine Mart, especially their 'contractor' series, which have served my purposes well enough although I know some will disagree on this point.
not done it yet01/11/2021 07:07:56
7517 forum posts
20 photos
Posted by Chris Crew on 31/10/2021 22:32:13:
Yep. Some look similar but in different paint, but some may look identical on the outside but be completely different (quality-wise) under the surface. Hardening parts and machining hardened parts very quickly adds expense. Out-of-tolerance parts can be used for the bottom end rubbish.
JasonB01/11/2021 07:33:18
Ketan explains it well in his posts in this thread.
Paul M01/11/2021 08:46:12
86 forum posts
4 photos
I too purchased a Warco HV6 rotary table with dividing plates etc. As with most Chinese imports it needed a strip down and clean. Apart from the a small adjustment with one of the clamping plates it has served me well. The only annoying aspect are the tee slots not in the vertical and horizontal position when the table was set to 0 degrees.
Chris Crew01/11/2021 10:07:24
418 forum posts
15 photos
I am interested in all the comments and respect everybody's point of view but I look at it this way. Production of any component these days is mainly done on CNC machines as far as I am aware. Gone are the days when armies of semi-skilled men in blue overalls stood behind semi-automatic capstan lathes turning out parts that would be as good as the tool-setter's level of skill and where variations in accuracy might creep in. Although I don't work in the manufacturing engineering industry, or work at all for that matter these days, it is my understanding that everything is now designed on a computer (gone also is the traditional drawing office) and the production programs are sent directly to CNC machines which, I am told, even compensate for their own tool wear. Therefore, it seems to me that it no longer matters where the product is designed, although quality of design must play a part, or where the CNC machine is located because it will run the same program to exactly the same level of accuracy and produce exactly the same components. Production will only follow where the necessary skills and energy costs are the lowest. I would agree that the quality of the materials used may have an impact on the finished product but overall wherever the production takes place it will all be pretty much of a muchness. Hence, the availability of reasonable and cheap DIY power tools and the similarity of machine tools only differentiated by colour and brand. Am I incorrect in thinking this way?
Bryan Cedar 101/11/2021 10:21:44
127 forum posts
4 photos
There is no doubt about the quality of the Warco HV6 rotary table. It was from a newly delivered batch and does not need dismantling to clean etc. The design is quite different from what was supposed to be a Soba brand from Chronos. which did not have a Soba marking. The Warco was superior in all respects and looks almost exactly like a Vertex even down to the black crackle finish. I rest my case. I did note that the Vertex had just three slots as opposed to four on the Warco.
Howard Lewis01/11/2021 10:32:21
7227 forum posts
21 photos
CNC will produce consistent levels of accuracy, but the finished product quality is determined by the Design, the Materials used, the of component cleamliness and ultimately, the care taken in assembly.
A well designed and precisely made machine can be wrecked by failure to clean or accurately assemble the finished the article.
Juddy01/11/2021 11:02:33
131 forum posts
Not every factory has quality modern machine tools, some of those far eastern factories rely on old worn out poorly maintained second hand machines, the quality of the products are reflected in this. Also some of the components are probably produced in back street workshops, like every product in this modern world the big factories sub a lot smaller parts to little producers.
SillyOldDuffer01/11/2021 11:26:17
10668 forum posts
2415 photos
Posted by Chris Crew on 01/11/2021 10:07:24:
Broadly yes. And new ways are deadly to traditional and old-fashioned production methods. The chap who thinks he can work in Whitworth at a manual lathe is doomed. In manufacturing you have to keep up: it's vicious.
However, modernising production isn't complete yet. Around the world there are plenty of businesses who are behind the curve. It's still possible to find excessively cheap stuff being made by low-productivity methods. A small foundry with low labour costs and a few basic machine tools might be scratching out a living by knocking out HV6 clones. Goods made this way can vary enormously from excellent to junk, even from the same factory. But these guys are batting on a sticky wicket. An up-to-date factory that wants the business can produce the same item better and at lower cost. It may not be worth their while.
Model Engineers are at a disadvantage because the market is small and their isn't much competition driving improvement. In comparison, almost every home wants a DIY electric drill, so there's high demand for reasonable kit. Better but affordable electric drills are profitable because they sell by the million. DIY tools are excellent value because the rubbish has mostly been forced out.
Home workshop gear sells in much smaller quantities, and the problem is compounded by Model Engineer's being notoriously tight. If we all tripled our spending, I'm sure hobby makers would offer better kit. Doubt it will happen though; I can only think of one hobbyist coughing up serious money for a new industrial grade machine, and there's a lot of dodgy cheapo stuff bought off the web by optimists!
I'm surprised at how good hobby tools are for the money. Had a few lemons, but generally my mid-range purchases have done what's needed of them. I think it's because much of it is made economically by modern methods, not by rice-farmers in a shed!
John P01/11/2021 11:38:04
451 forum posts
268 photos
Posted by SillyOldDuffer 01/11/2021 11:26:17
Don't appear to even have a shed ,well not in the first part.
https://www.youtube.com/watch?v=S6QmvOU_syM
JasonB01/11/2021 11:44:10
Chris, did you miss the post a week or two back showing crankshaft production?
As with most things the design is to a budget so what get sent to the CNC is determined by the design, higher tolerance will take longer and cost more so the cheaper item may not have such high tolerances. Could also be decided at the design stage that a machined finish will get it within budget rather than the better ground finish. Then there are material choices and any treatment to those materials.
As mentioned above a lot of old first generation CNC machines may have been exported and these may be what is being used to build the lower budget products. Top of the range CNC gets used when the customer is willing to pay the top range price for their rotary table that is why some 6" ones cost a couple of thousand pounds compared to £150-200 for the run of the mill hobby ones.
Michael Gilligan01/11/2021 11:56:31
23121 forum posts
1360 photos
Posted by Bryan Cedar 1 on 01/11/2021 10:21:44:
Just as an aside … When Vertex supplied HV6 rotary tables to Myford, at Beeston [which were then sold as Myford parts] they had four slots.
Chris Crew01/11/2021 13:39:02
418 forum posts
15 photos
Some informative replies to the points I raised, so thanks to you all for adding to my education. But just before I let this thread go, please let me say that I bought a 6" British made Sharp rotary table from Mill Hill Supplies many years ago. It has never been used because shortly afterwards I acquired what immediately looked to be a far superior Vertex model for a very reasonable price at an exhibition trader's stand and this was at a time when the air was full of derogatory comments about the far-eastern products which were coming on to the market. I assumed even then that this was because the much higher quality 'Chinese' product had been made using modern production methods designed to supply the world market whilst at the time I think a lot of people would have said that British made Sharp was better because it had been made using traditional skills by a small engineering company in the north of England. I apologise if this comment disappoints those who still cling the rose-tinted view that British was best.
Tony Pratt 101/11/2021 15:19:13
2319 forum posts
13 photos
CC, the bottom line is the far eastern stuff is made to a price point not a quality point so it varies like hell & a CNC machine can produce just as many bad parts as a manual one but it will do it a lot quicker. I'm also pretty sure quality control is absent in a good many Chines/Indian factories.
Tony
