old mart | 16/10/2021 20:38:52 |
4655 forum posts 304 photos |
I have some pictures, but have forgotton to add them to my album before posting this thread.
Edited By old mart on 16/10/2021 20:42:06 |
Pete. | 16/10/2021 21:07:33 |
![]() 910 forum posts 303 photos | An old boring head with a similar symbol popped up in my ebay feed a few hours ago 'Crown' brand |
old mart | 16/10/2021 21:34:58 |
4655 forum posts 304 photos | I have a 100mm 4 jaw independent chuck in a cupboard at the museum, marked Crown, and foreign. You reminded me that this 1/2" chuck has foreign marked next to the MT arbor. The screws are 8-32, replacing the original slotted ones which had seen better days, I had expected 4mm, or 3BA, but the 32 tpi gauge was the best fit and they screw in nicely. The design would work with hexagonal bar stock, but 1/2AF would be too big on the corners. Edited By old mart on 16/10/2021 21:37:30 |
DiogenesII | 16/10/2021 21:43:50 |
859 forum posts 268 photos | ..just for interest, that pattern of drill chuck is still made; |
JasonB | 17/10/2021 06:59:58 |
![]() 25215 forum posts 3105 photos 1 articles | There is another thread about this style of chuck somewhere on the forum, my old Chas Strelinger & Co catalogue from 1895 has several of them in it. Edit, found the thread and the image I posted at the time Edited By JasonB on 17/10/2021 07:03:32 |
peak4 | 17/10/2021 14:36:00 |
![]() 2207 forum posts 210 photos | I have a ½" Crown one of these myself, but rarely use it as the arbor is both well dinged and slightly bent. |
old mart | 17/10/2021 18:48:03 |
4655 forum posts 304 photos | Thanks, Jason, that thread is very interesting. As for the taper of the arbor, With the chuck dismantled, I could get a reasonable measurement of the end of the arbor and compare it with the outer end. Having some very heavy metal blocks and a suitable thick walled tube, it was easy to break the taper with a large punch and a club hammer. I have measured the taper and it is close to J33, J33 0.624" x 0.5604" x 1" length. Arbor 0.624" x 0.581" x 0.903 length. Edited By old mart on 17/10/2021 18:48:53 |
bernard towers | 17/10/2021 20:16:31 |
1221 forum posts 161 photos | I used to have one and the jaws where 90deg vees to take square stock. |
Ady1 | 18/10/2021 09:23:55 |
![]() 6137 forum posts 893 photos | |
old mart | 22/10/2021 18:27:49 |
4655 forum posts 304 photos | An update on fitting a MT2 arbor with a JT33 end. I bought one from Myford LTD, a good price and fast delivery. It was a failure. I had runout of about 0.020" tir. After removing the arbor, there were witness marks at the large end of the taper and I could feel the mismatch. That meant that JT33 had too steep an angle. After some investigation, the only candidate left would be the B16 which is based on the MT2 angle, and has a large end of 0.6195" The JT33 angle per side is 1.80422 degrees. The B16 angle per side is 1.43055 degrees.
peak4 | 22/10/2021 21:45:30 |
![]() 2207 forum posts 210 photos | Posted by old mart on 22/10/2021 18:27:49:
An update on fitting a MT2 arbor with a JT33 end. I bought one from Myford LTD, a good price and fast delivery. It was a failure. I had runout of about 0.020" tir. After removing the arbor, there were witness marks at the large end of the taper and I could feel the mismatch. That meant that JT33 had too steep an angle. After some investigation, the only candidate left would be the B16 which is based on the MT2 angle, and has a large end of 0.6195" The JT33 angle per side is 1.80422 degrees. The B16 angle per side is 1.43055 degrees. I'm not sure about the B18 I also set up the three tapers in the lathe and used a pair of dial gauges to measure the single sided taper over ½" and doubled it up to give the single sided taper per inch, doubled it again to give the actual taper per inch and times 12 to give taper per foot. Again a bit tricky as the MT1 Crown arbor is bent, which is why I wanted to replace it with a new MT2 one. The readings I got; MT2 0.050"/inch or 0.600"/foot (which more or less tallies with what's expected from the tables) The Crown arbor was about 0.630" at the wide end and about 0.598" at the narrow end A truncated (at the wide end) Brown & Sharp No7 is a possibility as they are 0.5010"/foot J33 is 0.624 - 0.5605 = 0.0635"/inch or 0.762"/foot so not that. Jarno are 0.600"/foot taper, so not suitable B16 is the small end of an MT2 , so again 0.600"/foot and not suitable Bill
Edited By peak4 on 22/10/2021 21:54:38 |
Michael Gilligan | 23/10/2021 04:37:52 |
![]() 23121 forum posts 1360 photos | Posted by peak4 on 22/10/2021 21:45:30: […] A truncated (at the wide end) Brown & Sharp No7 is a possibility as they are 0.5010"/foot […] Bill . I doubt if this is much practical help, Bill but … Machinery’s Handbook [30th Edition] gives the critical No7 taper values to five decimals : .50147 and .60000 MichaelG. . [ disturbed night … hoping to get back to sleep now ] |
peak4 | 23/10/2021 11:13:29 |
![]() 2207 forum posts 210 photos | Thanks Michael; badly worded on my part. I'd already looked through my copies, and couldn't find any other tapers in there which might fit the bill, though I'd used 11th & 20th, rather than the later pdfs that are now available. |
Michael Gilligan | 23/10/2021 11:18:21 |
![]() 23121 forum posts 1360 photos | Posted by peak4 on 23/10/2021 11:13:29:
[…] . Not at all, Bill … I didn’t see your post until about 04:15 MichaelG. |
old mart | 23/10/2021 19:14:51 |
4655 forum posts 304 photos | If the B16 arbor does not work, I will put it aside as a spare like the JT33 one. I may well simply Use the jaws to clamp onto a true running 1/2" steel bar as in the first post and bore the taper parallel to shrink in a MT2 soft ended arbor. This is purely an exercise, as I cannot really think that it can match a standard drill chuck. Trying to measure these type of angles which run to seconds of arc with a digital angle finder which only resolves 6 minutes is futile. Looking at the series of Morse tapers, I find it difficult to understand the mindset of the person who failed to make them all the same angle. |
peak4 | 23/10/2021 21:24:56 |
![]() 2207 forum posts 210 photos | Old Mart, from the measured tapers above, the ones done with a pair of clocks, not and angle gauge, I think the B16 is wrong; not only that, but the thin end of an MT2 up the spout wobbles around. |
