Empty Drill Boxes
Dr. MC Black02/09/2021 00:27:03
334 forum posts
Does any reader know where one can buy empty metal drill boxes (Indices?) at a sensible price, please?
I have bought these in the past but the local supplier no longer stocks them.
I'm beginning to wonder if the answer is to buy a VERY cheap set of drills in a box and then throw the drills away.
Is anybody able to help, please?
Very many thanks
Peter Greene02/09/2021 01:18:30
865 forum posts
12 photos
eBay under "drill index" ?
Peter Greene02/09/2021 01:51:28
865 forum posts
12 photos
Amazon have them too.
JasonB02/09/2021 07:15:33
Do you actually want a box or would a stand do? If so search for something like "drill bit stand"
My boxes always sit open in easy reach, in fact on a couple I've removed the lid so they take up less room
Grotto02/09/2021 07:39:03
151 forum posts
93 photos
It’s a pity you don’t live locally, as I've got a spare one you could have.
They’re the sort of thing you pick up cheap at markets with 2 or 3 blunt drills in.
noel shelley02/09/2021 09:49:58
2308 forum posts
33 photos
TRACY TOOLS ! Noel
Dr. MC Black02/09/2021 10:33:31
334 forum posts
Ladies & Gentlemen
Thank you for taking the time to respond.
I looked at both Ebay and Amazon before posting but neither were helpful.
I actually want a sturdy drill box to give as a present to a chum who is "mechanically inept". I have just sharpened his HSS drills for the second time and suspect that they would stay sharper if kept in a Drill Box.
I am hoping to be able to obtain an empty 1 - 6 mm or 1 - 10 mm by 0.5 mm steps.
Grotto - what do you have spare, please? Where are you located?
With best wishes and thanks again.
Clive Foster02/09/2021 10:45:45
3630 forum posts
128 photos
Stands and de-lidded boxes are handy when you only use one or two sets. If you have several proper boxes with lids become essential for practical storage. I have eight boxes in the "workshop" storage and several others for handyman duties.
What I'd like to know is what twit decided that metric 0.1 mm increment boxes should stop at 10 mm rather than going up to 13 mm like the 0.5 increment ones do. Many useful sizes missed out that way. I hate having to go to loose drills or the very incomplete MT metric stock for those so usually an Imperial gets pushed into service. Guess it helps having almost all the MT 2 and MT3 imperials by 1/64 th.
John Olsen02/09/2021 12:18:18
1294 forum posts
108 photos
Meanwhile I have several empty or mostly empty drill boxes here in NZ. It turns out to be uneconomical to buy the drills to fill them, you can buy a full set in another box cheaper than buying loose drills of the same quality.
Dr. MC Black02/09/2021 12:37:22
334 forum posts
Thank you for taking the time to respond from NZ.
I'm NOT looking to buy loose drills. I'm hoping to extend the life of the drills that he already owns!
I have seen cheap sets advertised - but they often come in plastic boxes and the reviews of the drills suggests that they would find it difficult to drill holes in cheese!
To answer Mr. Foster, I suspect that a set of drills from 10.1 to 13.0 in 0.1mm steps would be uneconomically expensive. How often would one need the complete range?
Howard Lewis02/09/2021 13:06:14
7227 forum posts
21 photos
I too have bemoaned the lack of 0.1 mm increment drills above 10 mm
But by then the hole is large enough to allow a boring bar to enter.
Also, using Imperial drills to just below the required size, allows the hole to,be bored or reamed to size, no no major problem.
not done it yet02/09/2021 13:53:20
7517 forum posts
20 photos
Give the fellow a strip of timber batten with instructions on how to drill suitably spaced blind holes in the timber with each drill size (to a suitable depth), then screw the batten to the wall (with spacers, if necessary) is my suggestion!
Obviously inappropriate if the drills are to reside in a toolbox.
Not all HSS drills are of the same quality - perhaps his are just not ‘HSS enough’. Or, again, perhaps his mechanical ineptitude extends to how to use the drills? Fast and furious, while not actually cutting (much) is the single most wearing problem while drilling.
Dr. MC Black02/09/2021 14:09:56
334 forum posts
He doesn't have a workshop; I think the drills just rattle together in a tin.
He's a semi retired minister of religion. I would NOT be surprised if he offers up a small prayer before drilling!
Andrew Tinsley 102/09/2021 14:16:24
4 forum posts
ARC do empty drill boxes, They are plastic, but look sturdy enough.
Andrew.
JasonB02/09/2021 14:17:32
Posted by Howard Lewis on 02/09/2021 13:06:14:
They are easy enough to buy individually, dormer go upto about 14mm and then start going in 0.25mm steps.
Its just that sets are not common as like mentioned above there would be little demand for such sets particularly given that individually the drills sell for £20-30 each that's a big investment for a set where only certain ones may get used.
I think the ARC boxes are only the ones for mixed taps and tapping drills but they are sturdy
Edited By JasonB on 02/09/2021 14:19:41
Dr. MC Black02/09/2021 14:37:17
334 forum posts
I have taken the risk of looking at ARC's web site and can't find empty drill boxes.
It's probably because I'm going senile but I should be most grateful if you would kindly give me a hint as to where they are listed on that web site.
Thank you
JasonB02/09/2021 14:43:51
This is the only one I know they do, as said in previous post not much use for a set of drills.
Have a search for "Roebuck empty drill case" on google for the traditional metal ones.
Howard Lewis02/09/2021 14:48:48
7227 forum posts
21 photos
Arc Catalogue 11, only shows drills in boxes, not empty boxes. Ditto for Tracy Tools, and The Tap and Die co, as far as I can see.
You may find what you want on Amazon, under Drill Index Boxes.
Tony Pratt 102/09/2021 14:53:23
2319 forum posts
13 photos
'Roebuck empty drill case' brings up one at £11.58 plus I assume postage from Buck & Hickmansurprise
Tony
JasonB02/09/2021 15:04:14
Really? As well as a couple of different Roebuck ones from several suppliers good old Drill Services also comes up in the search results, plenty of choice from them on this page or a few from Farnell
Edited By JasonB on 02/09/2021 15:05:46
