Whether a copper undercoat copper is a good idea
Mark Rand | 29/08/2021 15:58:34 |
1505 forum posts 56 photos | I know that in cosmetic 'triple chrome' plating copper is used under the nickel and chrome coats. This appears to be because it is easy to polish for a mirror finish on the end result. Is there any benefit to a copper coat under nickel when the main aim is corrosion protection of the steel component? The application in this case, is some knurled 0BA screws with tommy bar holes through the heads that need replacing on a BCA jig borer. |
old mart | 29/08/2021 16:18:00 |
4655 forum posts 304 photos | It always used to be the case, but you may not need it with a modern nickel solution. There should be recomendations included with the nickel bath specification. |
Robert Atkinson 2 | 29/08/2021 16:24:08 |
![]() 1891 forum posts 37 photos | Yes, Robert G8RPI. |
Dave Halford | 29/08/2021 16:53:29 |
2536 forum posts 24 photos | Posted by Robert Atkinson 2 on 29/08/2021 16:24:08:
Yes, Robert G8RPI. Having had a car bumper plated without a copper layer (not my choice) I can confirm Robert is spot on. |
HOWARDT | 29/08/2021 17:47:53 |
1081 forum posts 39 photos | I remember years ago visiting the Premier Drum factory and seeing their electroplating system. All their metal plating was done in house with copper being the base layer. Their finish was impressive after much hand polishing both prior and after plating. |
Clive Hartland | 29/08/2021 17:51:05 |
![]() 2929 forum posts 41 photos | Yes, that is the reason for the Nickel coating to allow polishing of the item to give a better finish to the Chrome' |
old mart | 29/08/2021 18:26:15 |
4655 forum posts 304 photos | The original reason for the copper was that the nickel would not adhere well to steel directly, it was the thick layer of dull nickel that was mechanically polished prior to chrome plating. |
Bazyle | 29/08/2021 21:23:08 |
![]() 6956 forum posts 229 photos | And it is the nickel that provides the corrosion resistance by dissolving away instead of the chrome. That's why chrome plating flakes off around damaged areas - the underlying layer has gone. Nowadays they skimp on the nickel which is why modern chrome plating doesn't last so long. |
Michael Gilligan | 29/08/2021 23:05:52 |
![]() 23121 forum posts 1360 photos | Posted by Mark Rand on 29/08/2021 15:58:34:
[…] The application in this case, is some knurled 0BA screws with tommy bar holes through the heads that need replacing on a BCA jig borer. . Might it be cheaper/easier to make them from Stainless Steel ? MichaelG. |
Mark Rand | 30/08/2021 09:43:57 |
1505 forum posts 56 photos | Posted by Michael Gilligan on 29/08/2021 23:05:52:
Might it be cheaper/easier to make them from Stainless Steel ? MichaelG. Where's the fun in that? |
noel shelley | 30/08/2021 10:04:19 |
2308 forum posts 33 photos | HOW do you polish Knurling ? Noel. |
Mark Rand | 30/08/2021 13:48:19 |
1505 forum posts 56 photos | I don't want to polish any of it. This isn't bright work, it's corrosion protection, like the originals tried to be.
Oddly, the dials, locking screws and other parts that were obviously made in-house were nickel plated, while the handles for the feedscrews are chrome plated - bought in. Edited By Mark Rand on 30/08/2021 13:48:41 |
Michael Gilligan | 30/08/2021 14:43:35 |
[…] The application in this case, is some knurled 0BA screws with tommy bar holes through the heads that need replacing on a BCA jig borer. . I am still struggling to identify these knurled 0BA screws … If they are the locking screws for the slides, I’m almost certain that mine have plain ‘capstan’ heads. [*] Or are you replacing some after-market screws with the proper design ? MichaelG. . [ *] ready to be embarrassed when I check Edited By Michael Gilligan on 30/08/2021 14:46:57 |
Mark Rand | 30/08/2021 15:56:32 |
1505 forum posts 56 photos | Brain fart! The dials are knurled, the screws are (slightly) domed...
And yes, one of them on the Mk3 was replaced by a nasty mild steel bodge that's gone rusty. Got a few way locking screws on the Beaver mill that need finishing as well. Edited By Mark Rand on 30/08/2021 16:02:57 |
Mike Poole | 30/08/2021 16:12:54 |
![]() 3676 forum posts 82 photos | I believe chromium is porus so the copper and nickel provide the corrosion protection and highly polished layers, the Chromium provides the decorative finish. Mike |
Michael Gilligan | 30/08/2021 17:24:02 |
![]() 23121 forum posts 1360 photos | Posted by Mark Rand on 30/08/2021 15:56:32:
Brain fart! The dials are knurled, the screws are (slightly) domed... …. . That’s O.K. then Thanks for confirming MichaelG. . Edit: for anyone still confused … this is the style of screw which I believe Mark is making: Adapted from : http://www.lathes.co.uk/bca/page4.html Edited By Michael Gilligan on 30/08/2021 17:55:05 |
old mart | 30/08/2021 18:17:22 |
4655 forum posts 304 photos | Unless you intend to keep the machine outside, I don't think there will be much difference between the two approaches. |
Mark Rand | 30/08/2021 20:00:38 |
1505 forum posts 56 photos | Yes, I might just plate the nickel directly on the steel.
Michael:- Them're the ones. Even in the photo it's possible to see the colour difference between the handle and the dial, screw, dial gauge mount etc. Not that it matters. |
Michael Gilligan | 30/08/2021 20:15:27 |
![]() 23121 forum posts 1360 photos | Some bed-time reading for you, Mark: **LINK** https://nickelinstitute.org/media/2323/nph_141015.pdf MichaelG. |
Mark Rand | 30/08/2021 20:46:49 |
1505 forum posts 56 photos | Get thee behind me satan, and push! |
