Michael Gilligan | 15/08/2021 08:26:35 |
![]() 23121 forum posts 1360 photos | This exhibit is described as a Wire Diffraction Grating : **LINK** http://waywiser.fas.harvard.edu/objects/261/wire-diffraction-grating The description is brief; but of course the fundamental requirement would be to have the wires parallel and equispaced. … So, I wonder how much effort must have gone into placing the holes neatly on three concentric circles ? Unfortunately, the photo is not at high resolution; but it looks to be a fine piece of Scientific Instrument Making ! How would you have done it, with the tools of the day ? Note that the centres of the ‘tuning pegs’ would be offset to account for their own diameters, and that of the wire ! MichaelG. . Edit: __ for comparison, here is a description of some ‘rectangular’ versions: Edited By Michael Gilligan on 15/08/2021 08:53:54 |
Dave S | 15/08/2021 09:02:08 |
433 forum posts 95 photos | 16 lines per inch, there are at most 72 wires. Think they are 1/16" apart - sounds like rule and dividers layout. : ) Dave |
Michael Gilligan | 15/08/2021 09:20:59 |
![]() 23121 forum posts 1360 photos | I would respectfully suggest that you may not have considered some subtleties of the problem, Dave MichaelG. |
pgk pgk | 15/08/2021 09:25:21 |
2661 forum posts 294 photos | Without a DRO and with my limited skills, I would go about it as follows: Make up/order/buy a strip of metal 1/4in + 4 wire diameters wide and drill/ream holes to match my punch's diameter and spaced and offset for the middle and outer pin holes and in it’s middle for the inner holes, noting the 'handedness' of the pins is different left than right. I'd also create a fixture ring as a stop for my marking bar. pgk |
John Haine | 15/08/2021 09:34:21 |
5563 forum posts 322 photos | Never mind how they made it, with a spacing of ~1/16" what was it used for? |
pgk pgk | 15/08/2021 09:58:38 |
2661 forum posts 294 photos | Posted by John Haine on 15/08/2021 09:34:21:
Never mind how they made it, with a spacing of ~1/16" what was it used for? Apparently it was attached to a telescope, presumably a large objective lens and if so then I’d guess used for plate photography? pgk |
Dave S | 15/08/2021 10:01:22 |
433 forum posts 95 photos | They have to be parallel and equally spaced. The divider gives me a set of circles, the 1/16" scribe ensures I don't make a gross error. The (assumed) milling machine /jig bore table takes care of the parallelism - drill one side then move in Y to the other side and drill. Move a precise 1/16 in X, set up over the scribed circle, drill the next one, move in Y. Repeat until done. That's how I would do it. The item is a diffraction grating, used for looking at spectrums of stars I think Dave Edited to add: the circular pin layout is purely aesthetic, and it isnt that old -1920 - that it would preclude the use of an accurate leadscrew driven xy machine Edited By Dave S on 15/08/2021 10:05:15 |
Michael Gilligan | 15/08/2021 10:14:19 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 15/08/2021 09:34:21:
Never mind how they made it, with a spacing of ~1/16" what was it used for? . The listing suggests Microwave or Infra-Red [click the + signs] … but there’s not much detail there. MichaelG. |
bernard towers | 15/08/2021 10:15:00 |
1221 forum posts 161 photos | Is it possibly a bahtinov mask |
JasonB | 15/08/2021 10:20:05 |
![]() 25215 forum posts 3105 photos 1 articles | I would have laid it out say 10 times bigger and use some form of pantograph machine to place the holes, would also have made it relatively quick assuming these were made in batches rather than a one off. |
Michael Gilligan | 15/08/2021 10:20:22 |
![]() 23121 forum posts 1360 photos | Posted by Dave S on 15/08/2021 10:01:22:
[…] Edited to add: the circular pin layout is purely aesthetic, […] . MichaelG. |
Mick B1 | 15/08/2021 10:30:46 |
2444 forum posts 139 photos | Posted by Michael Gilligan on 15/08/2021 10:20:22:
[…] Edited to add: the circular pin layout is purely aesthetic, […] . MichaelG. Yes, but AFAICS a rectangular layout would have to be bigger. It may be the whole thing had to fit inside a tube of particular diameter to be at the right focal distance or suchlike. |
John Haine | 15/08/2021 10:31:58 |
5563 forum posts 322 photos | Posted by Michael Gilligan on 15/08/2021 10:20:22:
[…] Edited to add: the circular pin layout is purely aesthetic, […] . MichaelG. Well no, surely? If the rows were straight either the aperture would have to be smaller or the OD larger which might not fit. If it was microwave it wouldn't be used on an optical telescope, and the spacing is too large even for infra red. I think Bernard is on the right lines, it generates a diffraction pattern in the telescope focal plane when focused on a bright star, which is characteristic of the optical performance. Ideally if the spatial frequency of the wires is constant across the array there should just be a single line, but that would be smeared out by aberrations. Maybe Neil could cast some (coherent) light as our resident astronomer? |
SillyOldDuffer | 15/08/2021 10:38:37 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 15/08/2021 08:26:35: ... The description is brief; but of course the fundamental requirement would be to have the wires parallel and equispaced. … So, I wonder how much effort must have gone into placing the holes neatly on three concentric circles ? Unfortunately, the photo is not at high resolution; but it looks to be a fine piece of Scientific Instrument Making ! How would you have done it, with the tools of the day ? ... for comparison, here is a description of some ‘rectangular’ versions:
Dave's method would work, and is the only way I can think of producing a round diffraction grating to fit in the end of a telescope. (Rectangular gratings are rather easier to make once the kenyon paper has been read.) The hard part is the accuracy required. Not difficult to make a rough grating if the purpose is only to demonstrate diffraction. Much harder to make a good grating for accurate measurements. Fine results demand the wires be accurately equidistant and accurately parallel, and I don't think an ordinary mill and DRO would do the job particularly well. I think the wires need to be much the same diameter too - accurarely made, and not stretched randomly when the grating is strung. Really annoying, I can't give it a go. My workshop is full of boxes at the moment pending daughter leaving home, and I can't get at my tools or bench. This paper has more on the theory. Went clean over my head at school! Don't bother reading it unless diffraction gratings are your thing. Dave |
Ady1 | 15/08/2021 10:50:25 |
![]() 6137 forum posts 893 photos | Its a 1920s veg-o-matic insert |
Michael Gilligan | 15/08/2021 11:40:38 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 15/08/2021 10:31:58:
[…] Edited to add: the circular pin layout is purely aesthetic, […] . MichaelG. Well no, surely? If the rows were straight either the aperture would have to be smaller or the OD larger which might not fit. . There would be no need to change the size or shape of the item, John There is already an infinite number of possible locations for each peg. The maker chose the elegant layout. MichaelG. |
Samsaranda | 15/08/2021 11:59:00 |
![]() 1688 forum posts 16 photos | Michael’s link at the top of the page lists one of the users as Oak Ridge from 1931 to 2005. Oak Ridge was the premier nuclear facility for preparing enriched uranium for the Manhattan project and the USA’s subsequent nuclear Arsenal, could there be a use for this item that we are not considering? Dave W |
John Haine | 15/08/2021 12:33:36 |
5563 forum posts 322 photos | Different Oak Ridge - this one is in Massachusetts, the "nuclear" one in Tennessee. |
Peter Cook 6 | 15/08/2021 12:40:03 |
462 forum posts 113 photos | I would have thought dividing to that precision would be well within the capabilities of the clockmakers of the time. This is mid 19th century work. The dial is 230mm across, the third wheel (centred in the dial) is about 75mm diameter and less than 1mm thick. I haven't counted the teeth. And I don't think I want to try and make it! |
Michael Gilligan | 15/08/2021 13:36:26 |
![]() 23121 forum posts 1360 photos | Angular dividing is simple, Peter … But this device also needs to include all the offsets that relate to the use of those ‘tuning pegs’ and I think it would be a little trickier than dividing a clock wheel. MichaelG. |
