Former Member | 24/07/2021 09:37:40 |
1085 forum posts | [This posting has been removed] |
Bob Stevenson | 24/07/2021 10:20:42 |
579 forum posts 7 photos | ....It is easily repaired,....just bung it in the scrap and make a new wheel!...........(note cracked spokes!) |
Rob McSweeney | 24/07/2021 10:21:34 |
98 forum posts | Never mind the flange, which could be built up with weld and re-turned , the spokes at 1 and 2 o'clock look to be cracked at the root. |
not done it yet | 24/07/2021 11:21:09 |
7517 forum posts 20 photos | Could be turned down and a new ‘tire’ shrink fitted. But what about the other wheel on that axle (and all the rest, for that matter)? I’m not considering buying it so I’m not going to worry about it, for sure. |
Martin Connelly | 24/07/2021 11:38:26 |
![]() 2549 forum posts 235 photos | Dropped at some point I would guess. Martin C |
Rob McSweeney | 24/07/2021 11:39:58 |
98 forum posts | What is the model - are the wheel castings still available?
Nicholas Farr | 24/07/2021 11:50:53 |
![]() 3988 forum posts 1799 photos | Hi, you could clean the wheel in a ultrasonic cleaner and probably fill the cracked spokes with brazing and then as NDIY fit a new tyre by shrinking or using some high strength cylindrical retaining compound, which would be easier if the wheel is not too difficult to remove, or like Bob has said, fit a new wheel, but failing every thing else, if you have the skill, making a completely new wheel set would probably make it an economical repair. Like NDIY, I'm not going to buy it, so it won't bother me either. Regards Nick. |
Former Member | 24/07/2021 12:23:35 |
Dalboy | 24/07/2021 14:11:50 |
![]() 1009 forum posts 305 photos | I like the comment at the bottom of the ad
"Condition is "Used" but like new. As far as I can work out it has never seen daylight!" |
Mark Rand | 24/07/2021 17:48:09 |
1505 forum posts 56 photos | Probably why it got dropped then, someone tripped over with it in the dark. |
BOB BLACKSHAW | 24/07/2021 18:48:07 |
501 forum posts 132 photos | Last comment made me laugh. |
Brian H | 24/07/2021 20:03:08 |
![]() 2312 forum posts 112 photos | It would be a shame to spend time and money on the repair only to find more damage afterwards. Brian |
old mart | 24/07/2021 20:42:17 |
4655 forum posts 304 photos | If I was listing it, I would be honest and say that it could be repaired by an expert. |
