Michael Gilligan | 11/07/2021 19:03:34 |
![]() 23121 forum posts 1360 photos | Several years ago we had a high garden wall built Foolishly, I took the builder’s advice and purchased “Scotch Common” bricks. We are now in the situation where perhaps one in thirty of them are ‘blown’ I want to fill at least some of them, before this turns into an expensive rebuilding exercise. Can anyone advise, please, what material would be most appropriate. Kindly resist the temptation to suggest JB Weld, or Milliput !! Thanks MichaelG. |
JasonB | 11/07/2021 19:09:45 |
![]() 25215 forum posts 3105 photos 1 articles | "Spalled" is the word Short of cutting them out and replacing I can't think of anything that will look like brick, all the epoxy repair mortars are not designed to look nice. Even then the frost can still get at the moisture in the brick and just spall off another layer complete with the epoxy. |
Buffer | 11/07/2021 19:12:13 |
430 forum posts 171 photos | In my experience this happens because the mortar is harder than the brick. I have scraped out bricks and turned then around. This normally happens on stone houses and churches that were built with lime and then repointed in cement. |
Michael Gilligan | 11/07/2021 19:17:41 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 11/07/2021 19:09:45:
"Spalled" is the word Short of cutting them out and replacing I can't think of anything that will look like brick, all the epoxy repair mortars are not designed to look nice. Even then the frost can still get at the moisture in the brick and just spall off another layer complete with the epoxy. . Just what I didn’t want to hear, Jason … but thanks ! MichaelG. . So … my new word for the day: https://www.heritage-house.org/stuff-about-old-buildings/brick-and-stone/brickwork-spalling.html ’though actually I think the cause of my problem is simpler than described there … We bought a rubbish batch of bricks. Edited By Michael Gilligan on 11/07/2021 19:29:51 |
gary | 11/07/2021 19:22:28 |
164 forum posts 37 photos | render or roughcast the wall is an option if you have a good coping on the wall to prevent water getting in. |
Buffer | 11/07/2021 19:28:41 |
430 forum posts 171 photos | No it's just a rubbish choice of mortar. |
Michael Gilligan | 11/07/2021 19:34:39 |
![]() 23121 forum posts 1360 photos | Posted by Buffer on 11/07/2021 19:28:41:
No it's just a rubbish choice of mortar. . Sorry, Buffer … I have to disagree I have a pile of left-overs, and many of them are just breaking up [no mortar involved] MichaelG. |
Bob Worsley | 11/07/2021 19:38:00 |
146 forum posts | There is a 20 year old estate in the village, and lots of the bricks are spalling. But only on the walls, none on the houses. These are engineering bricks so unlikely to be softer than the mortar. Having watched the problem develop over the years, something useful from a dog walk, I think it is the damp getting in the wall. But, we have had hardly any frosty days for years, not this winter, and the bricks still spall so not certain of the reason. The worst affected bricks are the ones on their sides at the top of the wall. Provided the wall is a brick thick then unlikely to be a safety issue? Just leave them.
Buffer | 11/07/2021 19:44:05 |
430 forum posts 171 photos | It even says it in your link the mortar has to be softer than the brick. |
HOWARDT | 11/07/2021 19:45:44 |
1081 forum posts 39 photos | Time consuming probably but could you cut out the face of the brick and insert a new facing. |
Emgee | 11/07/2021 19:59:16 |
2610 forum posts 312 photos | Michael If it were my garden wall I wouldn't be too concerned, that wall may continue to have spalling bricks showing the black interior, just look on it as decorative features. Emgee |
Michael Gilligan | 11/07/2021 20:09:15 |
![]() 23121 forum posts 1360 photos | Here is the end of the wall … with good bricks and bad bricks: .
. and that same brick after dropping it from waist height, onto the tarmac : . and rearranged, for artistic effect : MichaelG. Edited By Michael Gilligan on 11/07/2021 20:17:45 |
Phil Whitley | 11/07/2021 20:16:18 |
![]() 1533 forum posts 147 photos | Bad bricks, easiest and best is to cut the whole brick out and replace them, nowhere near as difficult as it sounds, then clean out the hole, put a mortar bed in, butter one end, pop the brick in, and point up. Did a lot of this on my workshop refurb. The only problem will be getting good bricks that are a reasonable match! Phil |
Georgineer | 11/07/2021 21:48:40 |
652 forum posts 33 photos | I'm not a brickologist, but wonder if these are clamp-fired bricks. The clay is mixed with coke or other combustible material, the bricks are assembled into a 'clamp' and fired, and the combustible stuff burns away, leaving a finished brick. One of Dad's friends, Noel Pycroft, used to make bricks this way on Hayling Island. This is different from kiln-firing where the clay bricks are heated in an oven. Looking at your bricks, the light colour of the outside and the black interior make me suspect that they are clamp bricks which have been fired too quickly and at too high a temperature, leaving the middle unburned and soft. That's much the same effect as barbecuing chicken legs too quickly, where you get burned skin on the outside and raw meat in the middle. It wouldn't solve anything, but my sense of curiosity would lead me to heat up a sample of the black part and see if it can be made more brick-like. Is there any prospect of taking this up with the supplier or maker of the bricks? George B. |
Michael Gilligan | 11/07/2021 22:07:32 |
![]() 23121 forum posts 1360 photos | Posted by Georgineer on 11/07/2021 21:48:40:
I'm not a brickologist, but wonder if these are clamp-fired bricks. The clay is mixed with coke or other combustible material, the bricks are assembled into a 'clamp' and fired, and the combustible stuff burns away, leaving a finished brick. One of Dad's friends, Noel Pycroft, used to make bricks this way on Hayling Island. This is different from kiln-firing where the clay bricks are heated in an oven. Looking at your bricks, the light colour of the outside and the black interior make me suspect that they are clamp bricks which have been fired too quickly and at too high a temperature, leaving the middle unburned and soft. That's much the same effect as barbecuing chicken legs too quickly, where you get burned skin on the outside and raw meat in the middle. It wouldn't solve anything, but my sense of curiosity would lead me to heat up a sample of the black part and see if it can be made more brick-like. Is there any prospect of taking this up with the supplier or maker of the bricks? George B. . I will get a gas torch on the black stuff, George, and see what happens … but it actually appears to be brittle. Unlikely to get much joy from the supplier after all this time, but I may pop over to see them. MichaelG. |
pgk pgk | 11/07/2021 23:13:43 |
2661 forum posts 294 photos | I'd wonder if that was claimable on insurance. pgk |
duncan webster | 11/07/2021 23:26:52 |
5307 forum posts 83 photos | There are various grades of brick, classified by frost proof ness. see bricks (despite the same name, I have nothing to do with the brick company!) Not that this helps now. Your only answer is to dig the blown ones out and replace with better bricks. This might look a right mess unless you can get something that matches, but as others have said it's not technically that difficult. Not getting mortar all over the face of the brick is the skilled bit I think the strength of the mortar is more to do with accommodating slight movement of the foundations, if the mortar is weaker than the bricks the mortar cracks and you can remedy it by pointing, if the other way round the bricks crack. as you have said some bricks have blown without seeing any mortar |
JasonB | 12/07/2021 06:51:34 |
![]() 25215 forum posts 3105 photos 1 articles | I'd say they are "overburns" which are often sold off cheaply and used in less critical situations such as garden walls. Commons are not that good in exposed situations to start with and the overburning will make things worse, water gets in, freezes and spalls the face off. |
Michael Gilligan | 12/07/2021 08:13:51 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 12/07/2021 06:51:34:
I'd say they are "overburns" which are often sold off cheaply and used in less critical situations such as garden walls. Commons are not that good in exposed situations to start with and the overburning will make things worse, water gets in, freezes and spalls the face off. . Which is, I regret, pretty much where we started … except that I wrote ‘blown’ Thanks everyone … The only relief is that my workshop [which is cavity-walled, with blocks inside and these outside], seems to be surviving O.K. … it’s “only” the solid walls that have suffered. Presumably the workshop roof keeps them from getting soaked, and the cavity is letting them ‘breathe’ Many expensive and distressing lessons have been learned on this project MichaelG.
Chris Evans 6 | 12/07/2021 09:07:56 |
![]() 2156 forum posts | Lots of spalled bricks on my house built in 1860. Builder suggested I treat them with "Thompsons water seal" to prevent damp getting in and making them worse. I haven't bothered, the house will see me out. |
