conspiracy to confuse?
brian jones 11 | 11/07/2021 16:33:31 |
347 forum posts 62 photos | Ive been banging away at Myford going carbide with some enlightening results and an ominous DONT DO IT but didnt explain why other than you dont need to and the Myford is too small to maul Well in search of knowledge I found myself in the quag of carbide codes and associated mysteries
One sound advice was - dont buy the tool sets on offer - you end up with half the bits you wont use That very wise. Indeed frustrating cos out of a set of 8pce, it did not contain a LH holder - WOW couldnt find another to suit. Its like a car only arriving with 3oo4 wheels. !"£$£$""$^$****** So digging further I then found the EB market smothered in these set boxes, you couldnt buy individual tool holders (unless you got way up in price) not even used parts anyone else noticed this I suspect a conspiracy to flood us with rubbish and fake bits you could waste a lot of money on this. you really could get trapped for our hobby market
anyone else found this
JasonB | 11/07/2021 16:53:57 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by brian jones 11 on 11/07/2021 16:33:31:
you couldnt buy individual tool holders (unless you got way up in price) I would not say you need to go "way up in price" to get individual holders. name brand ones in say 8mm square may set you back £75 or so but there is some middle ground between that and bargain basement pot luck direct from China ones. Many of the model engineering suppliers here cater for the hobby size machines that are commonly used in the home workshop and carry a range of Imported or even UK made holders that won't break the bank at £15-20 per holder that don't require any modification to them or the machine so can be used straight away With the right insert there is no need to "maul" on any lathe and contary to what a lot of people say carbide can be used to take fine cuts. I've seen good work done on Cowells, Unimat and Sherline machines using the right insert. Also thinking long term the smaller shank holders tend to take the smaller size inserts which cost less than larger ones so are cheaper to use than having to spend out on large inserts when most of the time you are just going to be using the corner and not the rest of the tools cutting edge. |
Joseph Noci 1 | 11/07/2021 16:56:31 |
1323 forum posts 1431 photos | Posted by brian jones 11 on 11/07/2021 16:33:31:
I presume that the implication is that these 'rubbish and fake bits' you refer to are of Chinese source or similar? I must say that I cannot agree with a statement so general in nature.. I have purchased a small handful of those 'sets' - some of the 10mm. some 12mm and some 16mm square tooling. I have found sets with left and right hand complements, in cutting tool and single point threading tools. I have purchased from Banggood, Ali-Express, and one or two other Chinese sources as well, and I have not been disappointed with any of the tools at all. Perhaps there may be one or two types here and there that are dicey, but I have maybe 40 or so different tools and none are bad. I modify them to suit special applications as well - for my small CNC lathe the ATC requires the tool body to be 50mm max in length, so I cut them down as required. And the steel used is very good! A hacksaw feels like it cuts the tool body the first stroke very nicely, but thats because the tool just removed all the sharp peaks of the teeth from the hacksaw blade.. The steel is hard through, not just case hardened. I would not be too quick to speak disparagingly of these tools and suppliers.. Joe |
Peter G. Shaw | 11/07/2021 17:15:28 |
![]() 1531 forum posts 44 photos | Suggest trying shop-APT.co.uk. A Glasgow firm with a variety of carbide tooling and a very helpful website. No connection, just a satisfied customer. Peter G. Shaw |
Vic | 11/07/2021 17:34:15 |
3453 forum posts 23 photos | Posted by Peter G. Shaw on 11/07/2021 17:15:28:
Suggest trying shop-APT.co.uk. A Glasgow firm with a variety of carbide tooling and a very helpful website. No connection, just a satisfied customer. Peter G. Shaw I’ve used them in the past. Prices aren’t bad but still not as low as the auction site. I bought my last lot of inserts from Amazon though, 2/3 the price and free next day delivery. I’ve also just ordered some less than half price SECO inserts from the auction site. |
David George 1 | 11/07/2021 17:40:45 |
![]() 2110 forum posts 565 photos | I bought an Iscar 2mm parting tool for my rear toolpost and having gone through two other blades from the show at Doncaster and the Midlands Show in consecutive years so I got a few years between them of use. The Iscar blade is now over two years old and going strong on its first tip and is used on stainless, brass, mild steel, and tough steels as well. I am not sure what I will do with the other nine tips I bought at this rate. The cheaper style allows the tip to push back and therefore goes below center and the job climbs over the tip and bang. David |
brian jones 11 | 11/07/2021 17:47:47 |
347 forum posts 62 photos | OK Pete I got the site noted but not for small boys who need 8 10 12 mm shanks
thnx Dave, following that up with Arceurotrade, I assume that gtin 19-2 means a 2mm wide tip, they dont say this Edited By brian jones 11 on 11/07/2021 17:59:11 |
JasonB | 11/07/2021 18:10:40 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by brian jones 11 on 11/07/2021 17:47:47:
OK Pete I got the site noted but not for small boys who need 8 10 12 mm shanks thnx Dave, following that up with Arceurotrade, I assume that gtin 19-2 means a 2mm wide tip, they dont say this
2.2mm actual cut width as detailed here on ARC's site APT do holders down to 6mm square if you look. Typical 6mm here
Edited By JasonB on 11/07/2021 18:15:51 |
brian jones 11 | 11/07/2021 18:15:30 |
347 forum posts 62 photos | Right JB but wasnt shown on their main site guess I should have known SLTBN Part Off Blade Tool Blocks with Part Off Blade
JasonB | 11/07/2021 18:16:49 |
![]() 25215 forum posts 3105 photos 1 articles | They only have one site so what do you mean by not on main site? Also see my edit about APT doing 6mm sq tooling. |
brian jones 11 | 11/07/2021 18:29:57 |
347 forum posts 62 photos | this was the link from another member https://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Lathe-Turning-Tools-Indexable/ARC-Indexable-Turning-Tools/SLTBN-Part-Off-Blade-Tool-Blocks-with-Part-Off-Blade this was the bewildering link from apt https://www.shop-apt.co.uk/lathe-turning-tools-apt.html no way to select shank size all seemed to be 20mm+
i dont know how to get to your page
JasonB | 11/07/2021 18:36:24 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by brian jones 11 on 11/07/2021 18:29:57:
From your link click on a tool that is shaped how you want and that takes the insert shape you want, I went with the one ringed as that's a good all rounder as one tool will face and turn diameter and they fit boring bars too so you don't end up having to keep a big range of insert shapes/sizes. From there look at the code numbers given, 0606 is 6mm square, 0808 is 8mm square and so on. SCLCR is Right Hand SCLCL is left hand but L/H get a lot less use in this style of holder hence why not so many in sets Edited By JasonB on 11/07/2021 18:37:57 |
JasonB | 11/07/2021 18:51:01 |
![]() 25215 forum posts 3105 photos 1 articles | Page 28 of this pdf catalogue explains about the tool holder shape and size codes which may help you understand |
Vic | 11/07/2021 20:06:54 |
3453 forum posts 23 photos | Posted by brian jones 11 on 11/07/2021 18:29:57:
You select the type of tool you want then the size options are available. |
SillyOldDuffer | 11/07/2021 20:38:22 |
10668 forum posts 2415 photos | Posted by brian jones 11 on 11/07/2021 16:33:31: ... One sound advice was - dont buy the tool sets on offer - you end up with half the bits you wont use ... So digging further I then found the EB market smothered in these set boxes, you couldnt buy individual tool holders (unless you got way up in price) not even used parts ... I suspect a conspiracy to flood us with rubbish and fake bits you could waste a lot of money on this. ...
Cock-up is far more likely than conspiracy! Plenty of discussion on the forum about the value of sets: they don't suit everyone. Many prefer to buy individual holders as theydiscover need them. Others, including me, find it easier just to buy a set and work from that. Unfotunately sets aren't standardised in terms of holder or insert type and it can't be assumed one chosen at random will be exactly what you need, because it depends on what you're doing. The buyer has to think. Perhaps the main disadvantage of carbide inserts is their bewildering variety. Industry need a wide choice of shapes and sizes to optimise cutting in all circumstances, and that doesn't make life simple for newbies. It may take a while for a hobbyist to find what he needs. One trick, look at the inserts and holders sold by Arc Euro because their range caters for hobbyists: if they sell it, you probably want one! Sets can include unusual tools: very useful if you need one, otherwise a waste of money. I learned from the sets I bought. Rather than blow a gasket because some set tools didn't match my needs, I investigated their purpose - very educational, and after 5 years I've used them all. Fakes are always a possibility - don't buy too cheap, and beware of 'bargains'. On internet sites it's difficult to tell the difference between genuine bargains because they're production overrun or bankupt stock, and counterfeits. In my experience, most Far Eastern stuff is satisfactorily mid-range and value for money. But I prefer to buy from UK vendors because there's less bother if a purchase goes wrong: consumer prrotection. Can't be assumed products are all wonderful, or all rubbish. Country of origin is almost meaningless as a guide because manufacturing is globalised. Brand-names aren't solid either. The best you can do is buy from reputable suppliers. Dave |
Vic | 11/07/2021 20:49:00 |
3453 forum posts 23 photos | I’m not sure if they still make it but I bought a double sided tool holder from JB Tools at one of the shows. I’ve only used it for left hand cutting but you can flip it over and refit the insert for right hand. |
brian jones 11 | 12/07/2021 00:00:31 |
347 forum posts 62 photos | Posted by JasonB on 11/07/2021 18:51:01:
Page 28 of this pdf catalogue explains about the tool holder shape and size codes which may help you understand Wow JB 749 pages on inserts and tooling, what Ive always wanted
but its is a serious reference doc
pg 28 seen on the pdf viewer not caltalog - 50 something does indeed unfrock tooling
Bill Pudney | 12/07/2021 05:31:30 |
622 forum posts 24 photos | For what its' worth I've been using Warner HSS inserts for over ten years. I haven't slung one away yet. Using a credit card size diamond thingy they can be sharpened with a few strokes, they are very robust and in my opinion well worth the cost. Yep, sorry they are not cheap. I settled on 3/8" shank toolholders and the small triangular inserts and the small 55 degree (diamond shape) ones. There are two sources ....Little Machine Shop and A. R. Warner themselves although I have only used LMS. No connection apart from being a very satisfied customer. Obviously there are those who will say that they are limited by their flat top rake, but I have not found a problem. cheers Bill |
brian jones 11 | 12/07/2021 06:36:07 |
347 forum posts 62 photos | Good for you Buddy, but LMS is in California and AFAIK Warner has no outlet in Europe |
Bill Pudney | 12/07/2021 06:58:27 |
622 forum posts 24 photos | Sorry, buddy, I didn't realise that you had an embargo on stuff from 'merca. Remind me to button my lip, next time I try and offer advice. |
