Colin Heseltine | 10/07/2021 10:35:39 |
744 forum posts 375 photos | I have an underwater strobe light which is no longer holding charge and wish to change the batteries. It is fitted with 6 off 1.2v 2200mAh tagged batteries giving a 7.2V supply. Having opened the battery pack I can see couple of the batteries have started to weep. The other problem is the printed circuit switch has corrosion on its tracks. What is the best way to clean this corrosion of the board and its corresponding rotating connector. Any recommendations for procedures to follow when changing the batteries. Thanks, Colin
Martin Kyte | 10/07/2021 10:51:26 |
![]() 3445 forum posts 62 photos | RS used to do fibreglass scratch pens for track cleaning. Garry blocks also are a help. Is this a photography strobe or come and find me if I am in trouble beacon. If the latter get a new one. regards Martin |
Grindstone Cowboy | 10/07/2021 11:13:21 |
1160 forum posts 73 photos | Battery corrosion can be dealt with by wiping with vinegar, cleaning the vinegar off with water, then isopropyl alcohol to dry it all up. In the absence of a fibreglass pen or Garryflex block, you can use the ink end of an eraser (do they even do those two-coloured ones these days?). Rob |
Colin Heseltine | 10/07/2021 11:38:10 |
744 forum posts 375 photos | Martin, It is a photography strobe. Colin |
Robert Atkinson 2 | 10/07/2021 11:50:25 |
![]() 1891 forum posts 37 photos | Nothing special to do when changing th cells as lon as you use tagged ones. Give the tags a rub with emory paper or garry block to break the oxide befor soldering and don't overheat them. After you have cleaned the contacts lubricate them with a smear of vaselene. DON'T use the divers favorite, silicon grease, any arcing will turn it into silicon dioxide (glass) and ruin the contacts. Robert G8RPI. |
Paul Lousick | 10/07/2021 11:52:49 |
2276 forum posts 801 photos | Faber Castell still make fibreglass erasor pens which I used to used many moons ago when I was a draftsman on a drawing board. Used to use them for modifying ink drawings. Still remember getting itchy hands after brushing the broken fibres with my hand. Paul. |
not done it yet | 10/07/2021 11:56:51 |
7517 forum posts 20 photos | I would think that a change of battery chemistry might be prudent? Cadmium is on the ‘naughty list’ and just two lithium cells would suffice (with a decent battery management system - which would likely be at the cell level). Nickel metal hydride might also be an alternative. |
peak4 | 10/07/2021 16:23:44 |
![]() 2207 forum posts 210 photos | If you have a fast charger, please make sure the cells you select are capable of accepting that maximum charge rate. |
Dave Daniels | 10/07/2021 17:09:14 |
87 forum posts | CPC stock fibreglass cleaning pens.
https://cpc.farnell.com/c/tools-maintenance/cleaning-chemicals/precision-cleaning/fibreglass-pens?searchref=searchlookahead
D. |
Dave Halford | 10/07/2021 17:42:37 |
2536 forum posts 24 photos | Replace the negative wires, black wire corrosion wont go away. Buy good cells with a long date |
