Cylinder drain cock thread?
Mike Hurley08/07/2021 19:02:38
530 forum posts
89 photos
My 3 x 5 twin Victorian steam engine restoration plods on. The cylinder ends each have a threaded hole which I naturally assume was for some kind of fitting. The only things that come to mind are drain cocks
img_1043small.jpg.
My main query is about the thread size, it measures 1/2" OD ot the top, with a core about .48" narrowing to around .46" about 3/8" in. but it's 25 TPI. I've checked this numerous times. I just cannot seem to find any reference anywhere to 25TPI standard threads at these sizes (e.g. BSP / BSPT).
Are these just one-off specials or is there some obscure 'standard' I've just not been able to locate?
Also, I was under the impression that drain cocks weren't necessary on older slide valve engines, as any water build up can be forced out via the slide valve lifting off its seating. If so, what other purpose could these threaded holes serve?
Any thoughts appreciated.
Regards Mike
Dave Halford08/07/2021 19:09:42
2536 forum posts
24 photos
BSB is 26tpi
Michael Gilligan08/07/2021 19:27:48
23121 forum posts
1360 photos
Posted by Mike Hurley on 08/07/2021 19:02:38:
… but it's 25 TPI. I've checked this numerous times. I just cannot seem to find any reference anywhere to 25TPI standard threads at these sizes (e.g. BSP / BSPT).
Please forgive my impertinence, Mike … but I have to ask:
How did you check the tpi of the threaded holes ?
… presumably not with a thread gauge, or they would be to some standard.
This is probably a ‘Red Herring’ but:
https://racingnorton.co.uk/Douglas-2-3/4hp-Early-Square-Brake-Rod-Bolt-Alternative-25tpi-Douglas-Thread-Stainless-Steel
Edited By Michael Gilligan on 08/07/2021 19:31:41
DiodeDick08/07/2021 22:43:19
61 forum posts
10 photos
The old-timers'way to measure an inside thread in an off-site location is to fill the threaded hole with candle wax. I have seen it done with the blunt end of the candle, just pared down with a pen-knife, then screwed in. The modern way to do it would be to spray inside the hole with WD40, then fill the hole with mastic. Stab a flat bladed screwdriver into the mastic when set, then screw the plug out and measure it. Note that 25tpi is quite close to 1mm pitch, although if the engine is old British that is quite unlikely, but not impossible. As an aside, I needed to cut a concentric 1mm thread on a drill spindle, to take a Unimat chuck. I looked at screw cutting it on an Imperial Myford and balked at the time and expense involved. I screw cut it 26tpi , but left it oversize, then finished it with a die.Job done.
Michael Gilligan08/07/2021 23:30:16
23121 forum posts
1360 photos
Just to clarify, DiodeDick …
We all have our own preferred techniques, but
I actually wanted to know how Mike checked the threads in his cylinder ends
Pete.08/07/2021 23:36:12
910 forum posts
303 photos
You could try thermoplastic, it's pretty cheap these days, it's plastic pellets you put in a mug of boiling water, 40 seconds later you take the now soft pellets out squeeze them together and mold to shape, if you block one side with your thumb, you could force it into the hole and create a perfect male pattern, advisable to leave some sticking out to grip and unscrew.
It takes a minute to harden to a tough nylon like material, maybe a bit harder.
It can be reused by putting it back in boiling water.
Nigel Graham 209/07/2021 01:39:11
3293 forum posts
112 photos
Mike -
With great respect I think you may have mis-gauged the thread, for as you say 25tpi doesn't match any standard.
I think it is most likely 1/2 " X 26tpi BS Brass, whose tapping-drill size is very close to the core diameter you quote.
You could try the dodges others suggest, but I would make a test-gauge by threading a short piece of brass (or use a 1/2 " BSB fitting if available) and carefully try that. The reduction in diameter suggests it was not cut right through for some reason, perhaps to create a taper-thread effect.
If it actually is 25tpi, it is an oddity indeed.
You also ask the holes' purpose.
I don't know the engine but if it's a vertical the holes may be for tallow-cup lubricators. If so, I would expect smaller holes in the cylinders, close to the ends, for drain-cocks. If a horizontal then they very likely are for drain-cocks. Those are the outer end covers: what equivalents exist in the crank-end covers
I consider it wise, indeed normal practice, to fit drains "even" with slide-valves, but as I say I don't know this particular engine's design.
Whilst it is possible the water might lift the valve off its seat sufficiently to relieve the pressure, there is no guarantee it will do so, and the engine still has the problem of disposing of the water.
David George 109/07/2021 06:49:49
2110 forum posts
565 photos
Hi Mike just cut a piece of round wood which will be slightly larger than the hole core and longer than an inch. Screw it into the hole and it will impress the thread like a die but not damage the hole thread and you can measure the TIP.
David
Bill Davies 209/07/2021 08:59:03
357 forum posts
13 photos
Pete may be referring to a specific thermoplastic, polycaprolayone, otherwise polymorph, and various other names. Quite useful but it is biodegradeable, so not so useful for permanent uses.
Bill
DiodeDick09/07/2021 09:04:05
61 forum posts
10 photos
I did not spend long in the tool room during my apprenticeship in the 60's but I never saw anything like a micrometer that could used to measure the diameter and pitch of an internal thread. If there is one now, I would very much like to read about it, although I doubt it would be affordable for the home workshop. Back then, the only ways were ready made test gauges, which were go-no go limit gauges or to section the part, then measure with a Shadowgraph, or similar. A plug cast from whatever is to hand remains the only credible non-destructive route for hobby use.
Mike Hurley09/07/2021 09:35:21
530 forum posts
89 photos
Lots of lovely, useful feedback!
Michael : I greased the thread then squeezed a pellet of epoxy putty on it. Result was reasonably sharp and I compared it under high magnification against my thread gauge, certainly didn't appear to closely match 24 or 26, but was near as at 25.
Nigel - it's a horizontal engine. Originally there was ONE tapered 'plug' in situ. Rather stupidly (on reflection) I assumed it was the correct one and spent about 2 days on and off duplicating a second one exactly the same. Only to happily discover that didn't fit. After the usual round of bad language, discovered the thread I was duplicating was 20TPI and the hole was - as per the object of this thread - much finer. Oh joy. Someone in the past had simpy jammed in what was to hand - fortunately doesn't appear to have cross threaded either hole!
I'll look into the possibilty of the BSB (not something I was familiar with ) even with 26 TPI may be able to squeeze something in at a pinch. If they were for drain cocks, I would assume they would be of brass so logical to use a complimentary thread? BTW however, there's no provision for similar at the other end of the cylinders.
David: Never thought to use the 'wood' trick, you learn something new every day. Thanks
Really appreciate the time and effort all have taken to respond. I'll try and update you on how I get on.
Bill Davies 209/07/2021 09:38:59
357 forum posts
13 photos
Working in an inspection department in the early 70s, we used a plastic to copy internal threads. This came as a powder mixed with water, and set very quickly. The form and pich were then measured using an optical projector. We were discouraged from using it due to its expense. I haven't been able to identify what the material was. Along with other suggestions, I offer plaster.
Bill
Michael Gilligan09/07/2021 09:42:43
23121 forum posts
1360 photos
Posted by Mike Hurley on 09/07/2021 09:35:21:
That sounds suspiciously like it could be 25.4 tpi [i.e. 1mm pitch]
… especially as it’s on a taper
Have you tried just laying an M6 screw into it ?
Mike Hurley09/07/2021 10:16:09
530 forum posts
89 photos
On an engine from the 1850's all the threads are Whitform so far (I've had to repair numerous to date on this machine) some being heavily corroded. The ones in question don't look to bad in comparison but are obviously not in pristine condition so not easy to get a precise 'image' of them. Funnily enough as per your suggestion Michael, I've just gone out and checked and a Metric thread does match pretty well 100%! Could be someone has re-cut it many, many years later and they only had metric kit to hand?
With the limits of equipment / techniques available I don't think I shall be able to precisely differentiate between 25, 25.4 & 26TPI, so I think it will be a case of cutting test pieces of each in brass or alloy and see what is the best fit!
Regards, Mike
Michael Gilligan09/07/2021 10:43:32
23121 forum posts
1360 photos
I don’t think this will help much … but it’s a good overview of the various ‘systems’
https://cdn.shopify.com/s/files/1/0068/3235/7429/files/Thread_Identification_Guide_Trimantec.pdf
Brian H09/07/2021 10:57:18
2312 forum posts
112 photos
Posted by Bill Davies 2 on 09/07/2021 09:38:59:
Bill
Bill, that sounds like a Rubert material but I couldn't see this powder on their website. Maybe someone else does it it but I have not found anything yet
Maybe I have! There is a company called RepliSet but I cannot find any prices.
Edited By Brian H on 09/07/2021 11:13:19
Circlip09/07/2021 10:58:21
1723 forum posts
"Could be someone has re-cut it many, many years later and they only had metric kit to hand?"
Think you're correct with that one Mike. Bosses look to be too small in diameter for thread. Wonder if originally was 3/16" thread.
Regards Ian.
Bill Davies 209/07/2021 15:12:46
357 forum posts
13 photos
Brian H, Replicet looks very useful, but definitely an improvement from what I used all those years ago. It seems to be a silicone based material, capable of reproducing fine features such as surface finish or, in this NASA document, crack detection:
Replica based crack detection
I thought, today, that my unknown material might be a dental cement (e.g., ToofyPegs - over the counter filling repair ! ) which contains zinc sulphate plus zinc oxide and sets very fast. However, it generates some heat, which I don't recall from my experience, however the metal components would have conducted heat away very readily.
Mike now has many options for reproducing the thread; does anyone have a design for a shadowgraph type projector?
Bill
Michael Gilligan09/07/2021 18:01:41
23121 forum posts
1360 photos
Posted by Bill Davies 2 on 09/07/2021 15:12:46:
Bill
A flatbed scanner would be adequate, if Mike can section the replica
Brian H09/07/2021 18:21:47
2312 forum posts
112 photos
Posted by Michael Gilligan on 09/07/2021 18:01:41:
That is an excellent idea Michael, I'd not thought of that! I must give it a try.
Presumably if it's a thread then a suitable profile can be downloaded from the Internet?
