wire came loose
Niclas Oberg | 07/07/2021 19:19:50 |
10 forum posts | Hello! Edited By Niclas Oberg on 07/07/2021 19:27:03 |
Ian Parkin | 07/07/2021 19:38:30 |
![]() 1174 forum posts 303 photos | Have you got a potentiometer with a switch on the back of it? it looks like the live out of the fuse goes to teh light and the switch on the back of the pot |
Niclas Oberg | 07/07/2021 19:56:38 |
10 forum posts | Yes, the lathe is a CJ0618A It is OFF -> Increase RPM Edited By Niclas Oberg on 07/07/2021 20:01:57 Edited By Niclas Oberg on 07/07/2021 20:02:34 |
Niclas Oberg | 07/07/2021 21:31:21 |
10 forum posts |
Edited By Niclas Oberg on 07/07/2021 21:31:58 |
SillyOldDuffer | 07/07/2021 21:41:06 |
10668 forum posts 2415 photos | Just a guess, but have a close look at the orange switch top right in the first photo. I think it's a double pole mains switch and the green wire goes to a tag hidden underneath. If so, the clear plastic sleeve may still be on it. The brown wires connect to one terminal and are are hiding the other.
Edited By SillyOldDuffer on 07/07/2021 21:42:55 |
Stuart Smith 5 | 07/07/2021 22:04:13 |
349 forum posts 61 photos | I have a cj18a lathe and have a few photos of the control box and wiring but not in enough detail to show what you are looking for. The end of the green wire looks a bit strange - it doesn’t look like it has been in a terminal. Does it look like the end has broken away from a soldered tag? If so, it could have broken away from the switch terminal on the end of the pot. The one with the white wire to the indicator light. You really need to trace the wiring from the mains incoming cable through the various components. Note that on some of these lathes, the switches and fuses are in the neutral and not the live as they should be. Stuart Edited By Stuart Smith 5 on 07/07/2021 22:05:50 |
David George 1 | 07/07/2021 22:52:25 |
![]() 2110 forum posts 565 photos | Have a look at the E stop the wire ends look similar and may have come from there and there is a wire going to a fuse there. David |
Niclas Oberg | 07/07/2021 22:52:53 |
10 forum posts |
Time to solder the wire to the switch and install a new fuse and hope it works...must source the fuse 1st Edited By Niclas Oberg on 07/07/2021 22:53:39 |
Niclas Oberg | 14/03/2022 22:19:14 |
10 forum posts | OK! jb01-15/2 saftey switch (connected to the clear shield) jb03-12/2 emergency switch zh-a CW/CCW selector W4.7K OFF & RPM potentiometer Blue and green goes left into a black cord. A brown lead goes to the transparent shield (jb01-15/2) returns as blue and goes to 1 side of the fuse.
So did this work? |
David-Clark 1 | 14/03/2022 22:38:47 |
![]() 271 forum posts 5 photos | I think the green could be the earth side of the potentiometer. P3 from the photo and diagram. A lot of that looks like a low voltage preset speed control. I would first check the earth chassis to the broken lead with a multimeter. Then trace the circuitry through the mains to the circuit boards. I had a lathe once that had a green earth lead that was not connected from new but too long ago to remember the make. |
Niclas Oberg | 15/03/2022 10:38:22 |
10 forum posts | I doubt that this one is ground or earth, as this one goes thru the fuse...it is one of the main leads on incoming power. |
Dalboy | 15/03/2022 10:53:08 |
![]() 1009 forum posts 305 photos | From the picture in the first post, the loose wire goes to the fuse yet the other terminal of the fuse has a blue wire which appears to go out of the box where does that wire go to |
Niclas Oberg | 15/03/2022 11:01:07 |
10 forum posts | Yes. From the fuse you see a blue wire. It goes to the transparent shield covering the chuck. |
Niclas Oberg | 15/03/2022 11:16:02 |
10 forum posts | Actually...the indicator light is connected to 1 side of the E-stop, currently being joined with a blue wire. |
SillyOldDuffer | 15/03/2022 12:09:49 |
10668 forum posts 2415 photos | Posted by David George 1 on 07/07/2021 22:52:25:
Have a look at the E stop the wire ends look similar and may have come from there and there is a wire going to a fuse there. David +1 Looking at the circuit the dangling wire is circled in green, and it connects to switch JB01: I believe JB01 and JB03 (circled in blue on the circuit diagram above ) are mounted together in the Emergency Stop assembly. In the large yellow box on top, JB01 is operated by the big red button, and JB03 is the orange box below (circled in red, top-right): Pretty certain the dangling wire is nothing to do with the pot or the Forward/Reverse switch. Be nice if the green wire had fallen off and shorted the fuse, thus explaining the fault, but the circuit diagram shows the dangling wire just safely removes mains Live from the fuse. I fear the control electronics have failed and the green wire fell off when the control box was opened up. It has to be reattached to JB01, but the green wire is nothing to do with the original fault. I'd check the motor with a 12V car battery - it should spin slowly. If the motor's good, I'd replace the board. In theory I have the tools and knowledge needed to diagnose and fix the board, in practice I've lost interest in fixing electronics. Others thoroughly enjoy mending broken electronics. Dave Edited By SillyOldDuffer on 15/03/2022 12:11:02 |
old mart | 15/03/2022 14:28:10 |
4655 forum posts 304 photos | Am I imagining it, or is that loose green wire in the first photo connected to a brown wire? |
Niclas Oberg | 15/03/2022 14:35:34 |
10 forum posts | Posted by old mart on 15/03/2022 14:28:10:
Am I imagining it, or is that loose green wire in the first photo connected to a brown wire? You are correct, it is soldered together with the brown and secured with heatshrink. |
Robin | 15/03/2022 14:42:03 |
![]() 678 forum posts | Has this been answered yet? Can't be bothered to read this lot According to the circuit diagram, the green wire should go to live via the fuse, probably where it enters the switch. Disconnecting the green wire will kill the little green light above the fuse, nothing else. |
Niclas Oberg | 25/03/2022 11:57:12 |
10 forum posts | There must be something else broken as well...most likely the 1st sparks made a shortcut in circuits. No matter what I try I end up blowing yet another fuse and triggering the protection switch in the mains fuse box.
So I deemed this a dead one and told my neighbour that we (I) cannot fix it without replacing more parts or even the mainboard.
Neil Wyatt | 25/03/2022 14:06:18 |
![]() 19226 forum posts 749 photos 86 articles | That green wire looks very wrong. It's not the same colour as the other green wires, and why extend a wire in that way in the factory? Looks to me as if someone has had a fiddle with it at some point... Neil |
