Using a Drumond Head Stock
GoCreate | 16/06/2021 18:07:34 |
![]() 387 forum posts 119 photos | A while back I converted a Drumond lathe head stock to work as a spiral milling attachment for my mill, photo's in my album. Recently I was asked to do an interesting job milling a spiral into a shaft for a throttle assembly for an old motorbike. I used the Drumond head stock and it worked out really well. The head stock is driven from the lead screw using a timing belt and pulleys, though in this case the belt had to be twisted to reverse the direction of rotation of the head stock, I've posted some pictures below.
I hope this is of interest and helpful Edited By tractionengine42 on 16/06/2021 18:11:33 |
old mart | 16/06/2021 18:10:31 |
4655 forum posts 304 photos | You were lucky to get away with that crossed belt! |
Michael Gilligan | 16/06/2021 18:17:25 |
![]() 23121 forum posts 1360 photos | Nice ‘re-purposing’ … and an impressive result MichaelG. |
Les Jones 1 | 16/06/2021 18:24:45 |
2292 forum posts 159 photos | I did a similar thing using a a rotary table and a right angle drill adapter.
Les. |
bernard towers | 16/06/2021 18:32:07 |
1221 forum posts 161 photos | Done the same for one of my bikes a few years ago and got the gear tables from machinery handbook. An interesting job and very satisfying. |
Ian Johnson 1 | 16/06/2021 18:58:04 |
381 forum posts 102 photos | Watched your video last night Nigel and was suitably impressed, it's one heck of a helix! Just need a couple more videos now, one of the throttle operating the carb, and another one on making the toothed belt pulley, looks like drilled holes and round bar did the job? IanJ |
GoCreate | 16/06/2021 22:27:01 |
![]() 387 forum posts 119 photos | Les, that looks a great set-up, I like the idea of using the right angle drill adapter. Getting a nice spiral groove is very satisfying. Ian, thanks for watching my video, I actually used a form tool to cut the teeth on the timing pulley. Nigel |
Chris Evans 6 | 17/06/2021 08:48:02 |
![]() 2156 forum posts | Nice work that gets the brain going. It has been years since I did any and would have to read the gearing charts. |
Baldric | 18/06/2021 11:36:15 |
195 forum posts 32 photos | I did a similar job a couple of years ago, a 2 start square thread, I used gears rather than belts, but I did need to get a big gear ratio, I had to make the "banjo" and I 3d printed the gears as it was a one-off to make the part & 2 taps. Not sure why this image is on it's side, it is not on my PC. The cutter is 1/16", I used the handle on the dividing head to driver the table, the return was made & faster easier by making an adapter to use a socket on the nut driven from a drill. Baldric |
GoCreate | 20/06/2021 20:55:41 |
![]() 387 forum posts 119 photos | Impressive set up Baldric, that gear train must of taken some serious maths.
Nigel |
Chris Evans 6 | 20/06/2021 22:00:27 |
![]() 2156 forum posts | Baldric, is that a Bridgeport with a 36" table ? If so a prized addition where workshop space is at a premium. |
John P | 20/06/2021 22:04:43 |
451 forum posts 268 photos | I made a provision on my Warco milling machine to drive from |
GoCreate | 21/06/2021 20:01:11 |
![]() 387 forum posts 119 photos | John, some interesting spiral milling, allot of versatility in the cnc route.
Nigel |
vic newey | 21/06/2021 22:37:14 |
![]() 347 forum posts 173 photos | Very interesting, I've been setting up my vintage c.1895 Pittler B2 to try spiral turning, it has an overhead drive to the tailstock, this is my first attempt but it's not milling on the video, just slowly cutting a coarse spiral as a test run. The Pittler B2 uses a worm and one of 17 worm wheels for spirals and screw cutting spiral cutting on a vintage Pittler B2 I next need to fit the milling attachment to the top-slide which will also run off the overhead drive if I can sort out the pulley belt from slipping. |
John P | 22/06/2021 12:53:12 |
451 forum posts 268 photos | Some spiral milling photos here 10 Tpi 1/2 inch diameter leadscrew finished length Cutters seen here form relieved from silver steel on the Eureka device. Useful for cutting worms , i use the cnc part of the machine for these odd pitches John |
GoCreate | 22/06/2021 20:50:11 |
![]() 387 forum posts 119 photos | Vic, Amazing set up and a beautiful lathe. I also did a video spiral milling
John, very interesting set up, it must be very satisfying to complete a long slender lead screw like the one you show. It's good to see your making your own cutters, the Eureka device in on my project list.
Nigel |
vic newey | 22/06/2021 22:03:10 |
![]() 347 forum posts 173 photos | Posted by GoCreate on 22/06/2021 20:50:11:
Vic, Amazing set up and a beautiful lathe. I also did a video spiral milling Nigel ----------------------------------------------------------------------------------------- I did see your video, very slick & neat compared to my crude attempt so far, I still need to set up one of the three milling spindles I have and then try again. The original Pittler one takes 8mm watchmaker collets and the other two are vintage MT1, |
vic newey | 24/06/2021 17:09:07 |
![]() 347 forum posts 173 photos | Another attempt on my vintage Pittler lathe, this time I have both the leadscrew drive and a milling cutter running off the overhead. It's running with the original milling head supplied with the lathe c1895. It takes 8mm collets but I don't have a suitable small end mill so it's fitted in a small chuck as a means to get it up & running |
