Slipping ER25 collet and best practice
andrew lyner10/06/2021 19:12:27
274 forum posts
5 photos
Time to consult the oracles again.
I guess I am doing something wrong here but collets like the ER25 should be extra good at holding (I would have thought) as both inner and outer bits squeeze down on the tool. I have problems with the tool working its way up inside the collet.
I make sure that the holder, collet and nut are all pretty clean and I sock it up pretty tight Do I need to be extra scrupulous a bout the cleaning? I have eyeballed the inside of the nut and the holder and there doesn't seem to be anything amiss. is there a step that I'm missing. Is lubrication a good thing or a bad thing here?
JasonB10/06/2021 19:23:22
Are you snapping the collet into the nut correctly before inserting tool and doing it up?
Edited By JasonB on 10/06/2021 19:24:19
Journeyman10/06/2021 19:43:34
1257 forum posts
264 photos
The recommended torque for tightening these collets is quite high. See the Rego-Fix table for details.
Vic10/06/2021 19:53:14
3453 forum posts
23 photos
I find the ball bearing nuts easier to use to get a good grip.
Nuts
old mart10/06/2021 20:19:13
4655 forum posts
304 photos
I don't find that the spanners that you can get for tightening them are long enough. We use er25 and I have a pair of spanners with 10" long handles. As already mentioned, a ball bearing nut helps.
Emgee10/06/2021 20:22:56
2610 forum posts
312 photos
Some chucks have a facility to use an adjustable backstop screw, if yours has you will see a tapped hole below the internal collet taper.
Emgee
Neil Lickfold10/06/2021 20:29:24
1025 forum posts
204 photos
Make sure that the cutter is in the collet to the full length of the collet or the length of the diameter of the cutter. Some collets are counter bored from the back. Some ER holders or spindle adapters also have end stops provided or a thread to make one as well. They are to set the cutter to the same length when changed. Also will stop a cutter moving back into the collet. You almost can not over tighten the ER25 collet assembly with the 2 spanners provided. Their max closing torque is very high.
bernard towers10/06/2021 21:40:00
1221 forum posts
161 photos
Not trying to put a damper on the comments above but nobody has mentioned the cutters! ARE THEY SHARP. I have seen people using cutters in the past that are only fit for the bin and they quite happily complain about poor finish and cutters moving.!!
andrew lyner10/06/2021 22:06:02
274 forum posts
5 photos
Wow. Thanks for that long list of things to look for. The "snapping" could be something that I am missing. There is a slight click but nothing very impressive that I can remember. I'll take more care and tighten it until my eyes bulge.
Oldiron10/06/2021 22:48:09
1193 forum posts
59 photos
There are some excellent video's on Youtube on the do's & dont's of ER series colletts. Just search for them. Much easier to see than read directions.
regards
Rob Wheatley10/06/2021 23:08:42
52 forum posts
28 photos
Don't forget they only have a small range they will close up on, generally 1mm over 5mm and 0.5mm for sizes under 5mm, if I'm using a 10mm shank end mill I will always use the 9-10mm collet not the 10-11 mm one.
It helps to have a complete set of metric and imperial ones.
Paul Lousick11/06/2021 00:58:54
2276 forum posts
801 photos
I don't use a tension wrench to set the torque but normally remove the collet holder from the mill and clamp it in a vice so that I can tighten the nut with a bit more force. A little oil on the thread is good but keep the bore of the collet dry.
Paul.
Edited By Paul Lousick on 11/06/2021 01:00:50
Swarf, Mostly!11/06/2021 09:13:41
753 forum posts
80 photos
Posted by Jason 10/6/21
Posted by andrew lyner on 10/06/2021 22:06:02:
SNIP!
SNIP!
Reviewing this thread, it seems to me that this important topic is being glossed over!!!!!!!!!!
My understanding is as follows: the collet should be engaged into the nut while both are OFF THE CHUCK.. Then fit the collet/nut combination onto the body of the chuck and then insert the tool and tighten the nut.
I await comment from others.
Best regards,
Swarf, Mostly!
Andrew Johnston11/06/2021 09:38:06
7061 forum posts
719 photos
Posted by Swarf, Mostly! on 11/06/2021 09:13:41:
..............the collet should be engaged into the nut while both are OFF THE CHUCK.
Correct - Andrew
JasonB11/06/2021 09:43:00
Yes that's what the link I included says though you can insert the tool into the collet once snapped into the nut and then put nut onto chuck body. I find this way best as you don't need to raise the mill head so much. Main thing is collet snapped into nut first, not only does this ensure even contact of the collet's short front taper it also extracts the collet from the long chuck taper when you undo it.
Mr Happy from Haas has quite a good video
Howard Lewis11/06/2021 09:55:05
7227 forum posts
21 photos
I always engage the collet into the nut, before fitting to the arbor. (How else can you do it? )
The collet should be selected to be as close a fit on the cutter as possible.
And as asked, are the cutters sharp?
Remember that if the collet is not tightened sufficiently, the helix on the flutes will try to screw the cutter out of the collet.
Once I had learned to tighten the clamping nut fully, (The ball bearing type help ) I had no more problems with End Mills moving.
Oily Rag11/06/2021 10:27:02
550 forum posts
190 photos
I am surprised that the OP has not noticed bruising of the lower taper on his collets if he has failed to 'snap' the collets into the nut with the nut removed. This is evident where people have failed to follow the correct procedure in fitting the collet to the nut and as a consequence whenever I have seen this the nut and collets are effectively scrapped due to this bruising and distortion of the 'C' snap ring.
I would agree that a quality nut with bearing, such as the Rego-fix Nuts are the best items for use with the ER system. Too many cheap and inaccurate nuts are on the market from 'you know where'!
Martin
Vic11/06/2021 12:23:47
3453 forum posts
23 photos
I have never been shown how to fit a collet in the nut. When I first started using them however, just looking at the inside of the nut for the first time made it clear to me that some sort of engagement was required.
Oily Rag11/06/2021 12:38:56
550 forum posts
190 photos
Vic,
May I suggest that is because you are an 'intuitive' engineer. I think that the first time I came across ER nuts and collets a look at the inside of the nut made it pretty obvious that the collet needed to be seated under the 'C' ring to act as an extractor, no one showed me, I just worked it out - same as you.
Martin
andrew lyner12/06/2021 15:52:28
274 forum posts
5 photos
The 'snap' seems to vary from collet to collet and tool to tool.
Tightening the arrangement up with the holder not in the taper means I can sock it all up a lot tighter. I think that was the main cause of my problem. I may invest in a longer handled replacement for the C spanner supplied. AlsoI'll go for a ball bearing version of the Nut - if I can assume compatibility with the two ER25 holders(?).
BTW, I am aware of a fair bit of reaction against the idea of 'liking' posts with a single button press. This is a typical thread where I could well have wanted to give a brief approval to many of the above ideas but that would have involved explicit quotes of nearly all the posts with the resulting ten mile long post which so one would ever bother to read right through.
Sop here's ONE BIG LIKE and I was shouting this!
