Me. | 08/06/2021 15:06:31 |
147 forum posts 30 photos | Hi - recently been given a tilting dividing head - can't find a makers mark on it yet but it looks very well made. It looks like it was taken apart for some reason and the main drive bevel gear is missing along with the handle - the surround doesn't look like too much work to make a new one but the bevel gear is my sticking point. How do I work out what gear ratio it needs to be - ive not counted the teeth on the gear that remains yet but that's my next job.
Dave Halford | 08/06/2021 15:16:17 |
2536 forum posts 24 photos | The BS0 is 40:1 A photo would help |
Me. | 08/06/2021 15:35:00 |
147 forum posts 30 photos | Seems to me that most run a 40-1 final drive but how do I work out what the missing gear is. I take it there is a mathematical formula for such ?
I will add some photos later. Edited By Me. on 08/06/2021 15:35:27 |
old mart | 08/06/2021 17:21:01 |
4655 forum posts 304 photos | Did it have a beval gear, or a worm drive? |
Tony Pratt 1 | 08/06/2021 17:57:03 |
2319 forum posts 13 photos | Posted by Me. on 08/06/2021 15:35:00:
I will add some photos later. Edited By Me. on 08/06/2021 15:35:27 Not all run a 40:1 ratio. Tony |
John Haine | 08/06/2021 21:10:20 |
5563 forum posts 322 photos | I think we are all puzzled as to what a bevel gear is doing in this - does the OP mean a worm or wheel? |
Nigel Graham 2 | 08/06/2021 21:47:35 |
3293 forum posts 112 photos | Odd that anyone would have removed the gear in the first place, but unless this was some special type, dividing-heads and rotary-tables normally use worms drive, not bevel-gears. The dimensions of the innards should give you a guide to the sizes required, but unless spares are available for the specific device it's likely you'll have to buy an appropriate stock set (usually 40:1 but not always so verify on the particular head) and modify as and where necessary to suit.
Robin Dufton | 08/06/2021 21:52:11 |
38 forum posts 10 photos | I remember reading something like the worms on small dividing heads and rotary tables are peened in the factory to reduce backlash, as they're too small to fit in any other way of eliminating it. Even with a new worm gear it may be more hassle than it's worth getting it set up correctly because of that. If it's a well made unit from a decent company that has a few parts missing, and worth saving, there is the option of buying a foreign copy and stripping it for parts. Edited By Robin Dufton on 08/06/2021 21:52:26 |
John Olsen | 09/06/2021 11:09:19 |
1294 forum posts 108 photos 1 articles | You might find a bevel gear on the outside if it is a differential dividing head, but the gears on the inside will normally be a worm and pinion. The number of teeth on the pinion would tell you the ratio of the head, it is unlikely to be a multi-start worm. The worm would have to have a tooth form and pitch to match the pinion. Could be made, but is it going to be worth the trouble? John |
Me. | 09/06/2021 11:11:22 |
147 forum posts 30 photos | Its defiantly a bevel gear drive that's missing - I can work that out from where the original handle would have been - I will attach a photo later.
John Reese | 13/06/2021 23:47:45 |
![]() 1071 forum posts | Universal dividing heads had a shaft geared to the hollow shaft that carreis the dividing pates. It could be geared to the table leadscrew for milling helices. In some cases it could be geared to the spindle to enable divisions that were not possible with the index plates alone. That is the only pace I would expect a bevel gear. |
Me. | 17/06/2021 15:53:06 |
147 forum posts 30 photos | As you can see - there should be a gear (bevel) to help turn the other bevel gear.
Dave Halford | 17/06/2021 16:11:11 |
2536 forum posts 24 photos | The bevel engages with the missing aux. input shaft (and change gears) for milling helix's, it operates via a mill power take off when the division plates are not used. |
Oldiron | 17/06/2021 16:30:19 |
1193 forum posts 59 photos | You probably do not need the missing parts unless you want to machine helix' helix's helixes helii regards |
RobCox | 17/06/2021 16:43:25 |
82 forum posts 44 photos | helices And if you want to do that you'll need the gear on the end of the mill leadscrew and the banjo and gears to get the desired lead on the helix. But... you can use the dividing head as it stands to index the gear blanks to cut them Edited By RobCox on 17/06/2021 16:47:41 |
Howard Lewis | 17/06/2021 17:08:00 |
7227 forum posts 21 photos | Measure the OD of the gear that is present, count the teeth and look to see if HPC, Reliance, Davall, or any of the other gear specialists have to offer. It may be necessary to modify the bore to suit the spindle. If you know the make and model of the Dividing Head, it may be possible to obtain a replacement gear. Howard |
Andrew Johnston | 17/06/2021 17:11:16 |
![]() 7061 forum posts 719 photos | It's common for the drive shaft from the mill table leadscrew to maintain a ratio of 1:1 until it reaches the worm drive on the dividing head spindle. Bearing that in mind, and looking at the existing gear and witness marks, I think the bevel gears are a special case, ie, mitre gears. So we just need a copy of the existing gear in terms of tooth count and angles. When spiral milling the division plates are still used, unless the helix is single start. While the drive from the mill table creates the helix: the division plates are still needed for indexing multiple starts: The only time I've machined a single start helix I used a 4-axis CNC mill: Andrew
Dave Halford | 17/06/2021 17:31:43 |
2536 forum posts 24 photos | Helix, smelix |
Me. | 18/06/2021 11:33:44 |
147 forum posts 30 photos | Thanks for the detailed answers - I had it in my head that the extra drive was needed to rotate the head in normal operation. I understand the Helixieseezze's idea - maybe in the future if i ever need to cut one i will try to get it working properly so I can cut a "spiral "... |
Andrew Johnston | 18/06/2021 11:54:36 |
![]() 7061 forum posts 719 photos | A helix and a spiral are not the same. In a spiral the radius changes as the angle increases. A helix is a special case where the radius is a constant. Andrew |
