John Smith 47 | 04/06/2021 00:54:44 |
393 forum posts 12 photos | Hello Can any of you recommend a UK supplier for good quality "mill board"? (Clue: My understanding is that "mill board" is very much like grey board, but it is a virgin material and tends to be very much stronger. It is recyclable and it does not have to toxic/carcinogenic chemicals contained in MDF) I need a thickness of about 1400 or 1300 microns (1.4 or 1.3mm) thickness. I have found some good stuff by the supplier has a Minimum Order Value of £330!
Bill Phinn | 04/06/2021 01:51:17 |
1076 forum posts 129 photos | I've been using mill board from various sources for twenty-five years, but don't know of any UK supplier who currently sells it in 1.3mm or 1.4mm thickness or insists on a minimum order of £330. Maybe the minimum order is because you have requested a non-standard thickness. Since you've come here for information, perhaps you'd be good enough to return the compliment and inform us who the supplier you're referring to is and provide a link to the product, regardless of whether the company is based in the UK or elsewhere.
Packmule | 04/06/2021 06:57:16 |
133 forum posts 6 photos | Hi John, Woolies have milboard @ £17.80 per sheet. It is thicker at 2.3mm Edited By Packmule on 04/06/2021 06:58:55 |
Ron Laden | 04/06/2021 07:00:55 |
![]() 2320 forum posts 452 photos | Don't know what it's intended for but have you considered Birch Ply it goes down to 0.4mm thickness wise. |
JasonB | 04/06/2021 07:42:14 |
![]() 25215 forum posts 3105 photos 1 articles | Could you not use a good quality "6 sheet" mount board as that comes out 1.4mm and is a lot more solid than grayboard. I've not knowingly used Millboard so can't compare the two. There are quite a few paper and card modelling forums, may be worth asking on those what they use and from where. Edited By JasonB on 04/06/2021 08:10:47 |
Ady1 | 04/06/2021 08:02:09 |
![]() 6137 forum posts 893 photos | "Due to the bulk of these millboards shipping overseas may be prohibitive" Now that's a proper caveat Is it possible to buy 2.3 mm and thin it down? (assuming small piece use) |
John Smith 47 | 04/06/2021 09:37:27 |
393 forum posts 12 photos | Fwiw, the supplier who's mill board is excellent quality with a MOV of £330 is Limehouse Board Mills. Their stuff is good but their MOV is a deal breaker. Ady1 - no, there would be zero chance of thinning it down - the areas require are too large. I wouldn't be shipping it overseas - just UK mainlaind. If pushed, another option I might use would be a good quality (i.e. rigid & strong!) "Tawny Board" - Double-sided Kraft paper lined grey board", which Limehouse can supply - but same MOV! But if so it must strong stuff and be between 1300 and 1400 microns (abs max 1500microns) in thickness. J
Steambuff | 04/06/2021 09:51:02 |
![]() 544 forum posts 8 photos | Hi, What type of model are you making and what size/scale? Have you thought about Plastikard (Slaters) this comes in various sizes. Dave Edited By Steambuff on 04/06/2021 09:51:22 |
Michael Gilligan | 04/06/2021 09:53:40 |
![]() 23121 forum posts 1360 photos | Well at least we now know what’s special about Millboard: MichaelG. . Edit: This may be more cost-effective than buying the current [2003] version of the standard: ftp://ftp.iks-jena.de/mitarb/lutz/standards/dstan/13/184/00000100.pdf Edited By Michael Gilligan on 04/06/2021 10:00:41 |
Bill Phinn | 04/06/2021 10:22:06 |
1076 forum posts 129 photos | You can get excellent quality mill board in 1.5mm thickness from several UK suppliers, in some cases with a minimum order of only half a sheet. FWIW, I gave you the names of these suppliers in a previous thread of yours. |
SillyOldDuffer | 04/06/2021 10:37:57 |
10668 forum posts 2415 photos | I think John may have to experiment to find exactly what he wants. 'Millboard' isn't a particular material, rather it's a generic name for a finishing, trimming or cladding product that can be made in different ways from different materials. A quick search found Millboard made of selected oak, 'wood free Millboard', Millboard made of recycled materials, and Millboard containing polyurethane, which John might consider toxic. Whether or not an individual Millboard is 'good quality' when used for an off-piste purpose like modelling is anybody's guess. It would help to know much more about John's application, for example we only know it has to be 'strong stuff', which is meaningless in engineering terms. Does it have to bend round a particular radius, be hard or tough, resist tension, or tearing, or whatever? Does it matter if the material is brittle, or isn't waterproof? Etc, etc. John mentions millboard is recyclable: is that a requirement or an observation? In engineering it's best to defer deciding what the solution is for as long as possible; that is don't start by deciding the answer, and work back from that. (In this case 'good quality Millboard, what Brand should I buy', when perhaps the answer is tinplate, fibreglass, or vacuum formed plastic.) Better to clearly identify the requirement, identify options that meet it, and only then chose one. At the moment only John knows what he has in mind, and why one product would be more suitable than another. For example, what is it exactly about the Limehouse Mills product that makes it's specification more suitable than other millboards? Dave |
Andrew Entwistle | 04/06/2021 10:43:05 |
![]() 120 forum posts 218 photos | If you could go down to 1.2mm then would fibreglass PCB material do the job? Standard thicknesses are 0,4, 0.6, 0.8, 1.0, 1.2, 1.6, 2.0, 2.4. It can be ordered machined to the desired dxf profile (usually 0.4 mm minimum radius) from a PCB manufacturer (JLCPCB, PCBWay) for as little as £10 for 5 off 100 mm x 100 mm. Andrew. |
Michael Gilligan | 04/06/2021 12:31:48 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 04/06/2021 10:37:57:
I think John may have to experiment to find exactly what he wants. 'Millboard' isn't a particular material, rather it's a generic name for a finishing, trimming or cladding product that can be made in different ways from different materials. […] . Hence my enthusiasm for the DEF-STAN MichaelG. |
Paul L | 04/06/2021 12:43:14 |
![]() 87 forum posts 26 photos | Posted by SillyOldDuffer on 04/06/2021 10:37:57:
I think John may have to experiment to find exactly what he wants. 'Millboard' isn't a particular material, rather it's a generic name for a finishing, trimming or cladding product that can be made in different ways from different materials. A quick search found Millboard made of selected oak, 'wood free Millboard', Millboard made of recycled materials, and Millboard containing polyurethane, which John might consider toxic. Whether or not an individual Millboard is 'good quality' when used for an off-piste purpose like modelling is anybody's guess. It would help to know much more about John's application, for example we only know it has to be 'strong stuff', which is meaningless in engineering terms. Does it have to bend round a particular radius, be hard or tough, resist tension, or tearing, or whatever? Does it matter if the material is brittle, or isn't waterproof? Etc, etc. John mentions millboard is recyclable: is that a requirement or an observation? In engineering it's best to defer deciding what the solution is for as long as possible; that is don't start by deciding the answer, and work back from that. (In this case 'good quality Millboard, what Brand should I buy', when perhaps the answer is tinplate, fibreglass, or vacuum formed plastic.) Better to clearly identify the requirement, identify options that meet it, and only then chose one. At the moment only John knows what he has in mind, and why one product would be more suitable than another. For example, what is it exactly about the Limehouse Mills product that makes it's specification more suitable than other millboards? Dave Why do I get the feeling that whatever is suggested will not be suitable? |
john halfpenny | 05/06/2021 13:07:03 |
314 forum posts 28 photos | Traditional millboard, as formerly made by eg Jacksons of Bourne End, was a paper based dense material and quite difficult to cut. It was typically used until the 1970s for parcel shelves and untrimmed door cards for cars and trucks. Usually plain grey on one side and slightly embossed on the other with a hard wearable finish. Woolies sell the best alternative that I have found, but the term now encompasses a variety of substances. |
John Smith 47 | 10/06/2021 19:55:42 |
393 forum posts 12 photos | I have been off-grid, hence the delay in responding. MY REQUIREMENTS 1. I need a material that is as broadly "eco-friendly" as possible. 2. Thickness: The walls have to be made up from 2 layers of material bonded together. The total wall thickness must be no more than 3.0mm, ideally more like 2.6 to 2.8mm thick... Hence each layer should be about 1.25 to 1.5mm thick. Any smaller or any larger will be of no use to me. One complicating factor is that for added strength and durability I may possibly bond a layer of craft paper, or 'eco-friendly' (recyclable/biodegradable) film onto the base material. APPLICATION For our 'box' structure to more rigid and generally strong the better. But resisting permanent damage through bending non-elastically is much more important. i.e. It is fine to be somewhat elastic/flexible if necessary, but it is not fine to be brittle nor to crease/crumple/wrinkle when bent. All suggestions much appreciated.
Bill Phinn | 10/06/2021 20:11:34 |
1076 forum posts 129 photos | Posted by John Smith 47 on 10/06/2021 19:55:42:
Since you ask, my application is that I am creating a sort of A4+ sized box for indoor, room temperature use. I have already tried plywood but when you get less then 3mm thick the price seems to go through the roof. Also some plywood grades seem to be vastly more flexible than others of the same thickness. For our 'box' structure to more rigid and generally strong the better. But resisting permanent damage through bending non-elastically is much more important. i.e. It is fine to be somewhat elastic/flexible if necessary, but it is not fine to be brittle nor to crease/crumple/wrinkle when bent. All suggestions much appreciated.
For your box, two layers of AFBG13 looks to be what you want: https://www.johnpurcell.net/arcbox.html It is used by the British Library and other major institutions for their archival box work. I did link some time ago to Purcell's in the hope that you would detail your requirements to them and get appropriate suggestions back. Frankly, if Purcell's can't supply what you need in the way of board, no-one can.
SillyOldDuffer | 10/06/2021 20:47:37 |
10668 forum posts 2415 photos | Posted by John Smith 47 on 10/06/2021 19:55:42: ... For our 'box' structure to more rigid and generally strong the better. But resisting permanent damage through bending non-elastically is much more important. ... All suggestions much appreciated.
Thin and strong means suggests sheet metal, reinforced as necessary by metal angle.
They can all be papered or painted... Dave
Michael Gilligan | 10/06/2021 20:50:31 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 10/06/2021 19:55:42:
[…] "Mill board" appears to be a virgin material ...
. I feel obliged to ask : Did you read the DEF-STAN ? MichaelG. |
Roger Best | 12/06/2021 14:17:08 |
![]() 406 forum posts 56 photos | This is hilarious. I think I will stick to shoeboxes and box files for my document storage.
