CHAS LIPSCOMBE | 14/05/2021 01:56:29 |
50 forum posts 3 photos | My interest in 3D printing is deliberately limited (so little time, so many potential areas of interest) to buying in 3D prints that are used as “waxes” for lost wax casting in stainless steel. I use the stainless castings to make a range of handlebar levers etc for vintage and veteran motorcycles. As bought, the prints often have minor defects and visible “layer lines” all of which can result in a failed or poor quality casting. To get round this I go over the castings with a wax product I get from the foundry. I think this is a locally-made product here in Australia and the foundry uses it to repair blow holes etc in conventionally produced wax masters before casting. This process is slow and time consuming and I want to find an alternative. What I need is a spray-on wax that gives a thickish build on the 3D print, which I can then smooth off to give a good surface to the print. My question is – can anyone think of such a product, maybe designed for a totally different purpose that would do this job? Aerosols of car polish wax give too thin a build to be of much use. Some alternatives that I have already looked at are:
Chas |
JasonB | 14/05/2021 07:11:20 |
![]() 25215 forum posts 3105 photos 1 articles | 4th option is to print in another material and spend time smoothing and then use that as a master to make a silicon mould to cast waxes in. That way you only do the smoothing once assuming these are not one offs |
Luker | 14/05/2021 07:46:05 |
![]() 230 forum posts 172 photos | Hi Chas The commercial prints for investment casting are typically done using a 0.6 nozzle, I would check with the printers what size nozzle they’re using. As you say the layer height and to a lesser degree the nozzle size will improve print quality at a cost. Acetone works on ABS prints but this is not suitable for investment casting as the ABS expands and cracks the shells. You need to check with the printers they are using the correct printing media. Prints can be smoothed with steel wool, and you get a special silicon spray used in the investment foundry industry that seals the prints, but it is unlikely you’ll find this anywhere other than a specialised foundry supplier. I have used this on a large investment pattern we had sealing issues with. I’m sorry to say that with once-offs there is no substitute for meticulous checks and repairs of the patterns. For multiple parts, as Jason mentioned, you can’t go wrong with silicon moulds. I wrote a short article on 3D printing for pattern making (including flexible moulds) in ME that might be of interest to you. Hope this helps… |
not done it yet | 14/05/2021 07:47:36 |
7517 forum posts 20 photos | Spray wit diluted nail varnish? Most certainly don’t go boiling 2-propanone in domestic surroundings. - do the job safely elsewhere! |
jaCK Hobson | 14/05/2021 08:12:51 |
383 forum posts 101 photos | https://www.smooth-on.com/product-line/xtc-3d/ To smooth with acetone you just put a bit of acetone and the part in a sealed container - which could be outside. You don't need to boil. High build spray on primer/filler heat gun resin printer? Better detail. Edited By jaCK Hobson on 14/05/2021 08:14:02 |
Paul Lousick | 14/05/2021 08:18:18 |
2276 forum posts 801 photos | Spray putty as used to fill rough surfaces (small imperfections) prior to undercoating when painting a car. Available from auto parts suppliers in aerosol cans. (sold by AutoOne, Repco, etc in Australia). Easy to sand smooth after it has dried but gets harder in time. Paul |
JasonB | 14/05/2021 08:20:38 |
![]() 25215 forum posts 3105 photos 1 articles | I'm not sure some of these spray on primer fillers will work on the wax prints Chas is talking about, OK for plastic or masters for the silicon moulds. |
Luker | 14/05/2021 08:25:54 |
![]() 230 forum posts 172 photos | Posted by JasonB on 14/05/2021 08:20:38:
I'm not sure some of these spray on primer fillers will work on the wax prints Chas is talking about, OK for plastic or masters for the silicon moulds. I agree, the bulking agents for these automotive fillers is talc. It absorbs water during the investment dipping process and creates ash when the shell is fired... |
Neil Wyatt | 14/05/2021 10:16:14 |
![]() 19226 forum posts 749 photos 86 articles | Posted by CHAS LIPSCOMBE on 14/05/2021 01:56:29:
Hi Charles, I think you have misunderstood the technique. Just get a suitably-sized container. Pour an adequate amount of acetone in the bottom, give it a while to reach equilibrium, then place an ABS print inside on a stand or suspended and fit a lid. Keep a close eye on it, as it will start smoothing very rapidly. Your exposure to fumes should be no more than someone painting their nails; bear in mind acetone's toxicity is very low. Neil |
Neil Wyatt | 14/05/2021 10:18:06 |
![]() 19226 forum posts 749 photos 86 articles | There's a great guide here: rigid.ink/blogs/news/acetone-vapor-smoothing Neil |
Adrian Johnstone | 14/05/2021 10:40:18 |
![]() 34 forum posts | This may not apply since I think you are buying prints and don't have the CAD model, but an alternative approach is to use a resin printer. I run the Gauge 1 3D printing forum and there is a thread there from Markus Neeser which describes the use of special resins to print waxes. Now, the resin is not cheap, and a brake lever might need a midrange printer to fit in, but the quality will be outstanding. Take a look at https://gaugeone3dcircle.groups.io/g/home/topic/lost_wax_castings_from_3d/71397306?p=,,,20,0,0,0::recentpostdate%2Fsticky,,,20,2,20,71397306 Adrian
Edited By Adrian Johnstone on 14/05/2021 10:47:33 |
Adrian Johnstone | 14/05/2021 10:46:27 |
![]() 34 forum posts | And on smoothing, I certainly agree with Neil's approach: hot acetone apart from being an obvious H&S bomb waiting to go off is far tooo active for useful smoothing. You need it to be at room temperature to give the necessary control. My approach is even more tentative that Neil's: I spot acetone onto kitchen paper that is draped over the walls and bottom of one of those polypropelene boxes that have a seal. I then put the print in and seal the lid. Thus very little in the way of escaped volatiles. After I've finished I dispose of the paper sheets in the brazier.. Adrian
Edited By Adrian Johnstone on 14/05/2021 10:47:59 |
Steve F | 14/05/2021 16:14:10 |
![]() 101 forum posts 25 photos | You could try this stuff regards Steve |
Dave Halford | 14/05/2021 17:16:05 |
2536 forum posts 24 photos | You can thin beeswax blocks by warming till it melts, then add a little white spirit (for a slow dry) to make a paste. I used it to fairly runny to make a thick mould release for GRP. |
Bazyle | 14/05/2021 18:08:13 |
![]() 6956 forum posts 229 photos | If you are using the prints in a lost wax process you also need to test what happens to the filler in the burn out process. Metal casting fillers probably have the emphasis on permanence. I wonder about PVA glue which is sold very diluted as a sanding sealer (big con). |
Alan Wood 4 | 14/05/2021 18:55:53 |
257 forum posts 14 photos | XTC is very good but expensive and goes off very very quickly so you can't hang around applying it. I have used Araldite or Gorilla twin pack glue cut with meths. It goes runny but coats well and does go off OK. With either it is much easier to get a good finish if you use the wide V shaped foam brushes. |
CHAS LIPSCOMBE | 15/05/2021 00:40:19 |
50 forum posts 3 photos | Amazing! such a quick response and so many very helpful replies Jason: I do use exactly the technique you describe, except that the foundry I use will not accept silicone moulds. I have to get Aluminium/Epoxy moulds made. I find 3D printing just about indispensible for prototypes before committing myself to the expense of hard moulds. To avoid confusion what I do is hobby stuff to keep me mentally and physically fit at 81 years old. Any negligeable profit is quickly absorbed by new tool purchases! Luker: Thanks very much for your reply, is Acetone only useful for ABS or does it work on other print materials? I will look into the silicone spray question but my problem is more the quality of the print surface rather than porosity. I would very much like to see a copy of your article but I don't get ME - any chance I could get a copy of the article from you? The tip of using steel wool sounds interesting! Paul Lousick: I don't think this would work because the fillers in the primer would probably not be carried out completely with the wax when that is melted and lead to incomplete castings. Neil: You are quite correct, it's all a question of terminology. As a retired chemist, vapour implies concentrated matter to me while what you describe would be fumes. No matter, your terminology is every bit as good as mine Adrian Johnstone: Thanks for your link. Again I will study it in detail as soon as I finish this post. I have seen prints from resin printers and they are truely of amazing quality. However the one I know about use "acrylic resins" which may not be suitable as "waxes", although they would be excellent for making silicone moulds. For me I suspect costs would be prohibitive. Steve F: I shall certainly investigate this Bazyle: Unfortunately the foundry are no more co-operative than they need to be but I will try to get them to run a few prints coated with PVA just to see what happens. "Just to see what happens" is the curse of the scientific mind. It can lead one into all sorts of trouble DAHIK. The choice of foundries in Australia is very limited. Chas
Luker | 15/05/2021 06:05:53 |
![]() 230 forum posts 172 photos | Hi Chas, I honestly don’t know if acetone works on other printer filaments, never tried. In my humble opinion and from my personal experiments fume polishing has less effect on the vertical edges of a print which is where it’s needed most. The spray is not for porosity it’s to seal the print. If you have hundreds of lines thermally joined there might be places where they don’t join properly. When dipping the pattern the slurry fills these areas causing poor surface quality. If you’re using printed patters for investment moulding the foundry should do a vacuum test. An easy way for you to check is to submerge the pattern in some warm water and check for any bubbles as the air inside the pattern expands. I think you misunderstand Jason and I RE the flexible (silicone) moulds. The end result is a wax pattern you give to the foundry. A positive is printed using 3D printing (or a sample), the silicone is poured around this (a negative mould), and finally you can pour wax into this mould. I unfortunately don’t have pictures of this exactly but I have used this process to make badges for one of my vintages, the underlining concept should be clear from the pics… Incidentally you don’t need to buy potting silicone, calking silicone with corn starch mixed in and a little terps as thinning agent will also work if you want to experiment a little. Tricks for mixing and releasing agents are in the article… |
JasonB | 15/05/2021 07:21:38 |
![]() 25215 forum posts 3105 photos 1 articles | Chas what you say is a little confusing. In the opening post you say you are having waxes printed and want to improve the WAX surface. Yet in the second reply you say you are taking hard moulds off of presumably solid prints and then casting waxes from those. The two surface treatments will differ depending on if it it wax or a plastic you are wanting to improve the surface of. Also how do your foundry handle the waxes? if they are being made into a "tree" with wax runners than any non wax surface treatment may affect how they are melted onto the tree. The other advantage of casting the waxes in a silicon mould is you can pull complex shapes from the silicon that would otherwise need draft angles etc on a solid mould. |
Paul Lousick | 15/05/2021 07:36:56 |
2276 forum posts 801 photos | My mistake Chas with suggesting spray putty. I missed the point that you were doing lost wax casting and was thinking solid pattern. |
