My version of Potty Mill engine
David George 111/04/2021 20:13:29
2110 forum posts
565 photos
Just finnished the valve section and eccentric and done a first assembly. I have changed a few bits to my liking to give it a bit more strength.
David
Jim Nic11/04/2021 20:30:03
406 forum posts
235 photos
Looking good David.
What's in the box on top of the valve chest?
Jim
Neil Wyatt11/04/2021 20:30:22
19226 forum posts
749 photos
86 articles
Nice job, David.
Next decision - to paint or not to paint?
Harry Wilkes11/04/2021 21:06:12
1613 forum posts
72 photos
Nice
Nigel Graham 211/04/2021 21:39:07
3293 forum posts
112 photos
That's an elegant machine!
David George 111/04/2021 22:12:50
2110 forum posts
565 photos
Hi Jim the box is an exhaust with the outlet on the end. I have drilled the exhaust outlets on the top and cross drilled to end.
Not tried it out yet and have some finishing to do on edges and corners as well as lube bits and pieces then clean up the flywheel casting. I probably will paint it red.
David
Jim Nic12/04/2021 10:26:27
406 forum posts
235 photos
Thanks for that David. One of the things I like about Stew Hart's designs is that they can be personalised fairly easily. I did a similar thing on my version but had the inlet on top and the exhaust on the side.
I like your connecting rod too, I must bear that in mind
Jim
SillyOldDuffer12/04/2021 10:48:20
10668 forum posts
2415 photos
David's PottyMill is better finished than both of mine!
Admittedly both were made for the learning experience, but I paid more attention to finish on the second. Perhaps I should make a third, or several...
blush
Curiously my rather rough number 1 runs noticeably better than engine number 2. I suspect it's because №2 is a tighter fit all round, and needs running in! I'm still slightly miffed the extra-effort version wasn't as good as the trainee bodge!
Hopper12/04/2021 10:57:39
7881 forum posts
397 photos
Posted by SillyOldDuffer on 12/04/2021 10:48:20:...
...Curiously my rather rough number 1 runs noticeably better than engine number 2. I suspect it's because №2 is a tighter fit all round, and needs running in! I'm still slightly miffed the extra-effort version wasn't as good as the trainee bodge!
As Mr Harley said to Mr Davidson, a little extra clearance never got in the way.
I have the same problem: using toolmaker's clearances and tolerances and ending up with things too damn tight for real world conditions..
Hopper12/04/2021 10:59:06
7881 forum posts
397 photos
Posted by David George 1 on 11/04/2021 20:13:29:
Love the high-performance con-rod. You'll be able to flog the daylights out of the engine with no fear of that letting go!
David George 125/04/2021 13:57:39
2110 forum posts
565 photos
It lives. I had the first run on my engine.
I had it connected to tyre inflator, only 5 PSI and it runs great.
David
Steviegtr25/04/2021 14:02:14
2668 forum posts
352 photos
Brilliant David. Nice job.
Steve.
JasonB25/04/2021 16:06:17
That turned out well.
geoff walker 125/04/2021 18:32:40
521 forum posts
217 photos
Well done David top quality stuff.
Are you going to set it up with that boiler of yours?
Go on let's see it running on steam.
mechman4826/04/2021 14:53:35
2947 forum posts
468 photos
Super job David; any advice on how you prepped the aluminium pror to painting... was the paint rattle can or mini spray gun ?
George.
David George 126/04/2021 15:44:01
2110 forum posts
565 photos
Hi George. I used rattle can paint. First an etch primer then a primer followed by finnish coat with fine wet and dry between coats.
David
David George 108/05/2021 22:28:06
2110 forum posts
565 photos
Got my pottymill on steam today. I had a try with the boiler on the wobbler and lamp but the solid fuel wasn't sufficient to power the pottymill. I ordered a gas burner from Forests and it came today and it ran perfect.
https://youtu.be/VhrElKNqgyY
David
Edited By JasonB on 09/05/2021 06:56:26
