Spanner sizes wanted please
StephenS | 07/04/2021 00:10:48 |
38 forum posts | Hi all, Can anyone help me with the specific BSW or BSF spanner sizes that would have come with a Myford Super 7 that is approx 40 years old? Or any other spanners that would be needed (eg BA)? Many thanks, |
Steviegtr | 07/04/2021 00:24:08 |
![]() 2668 forum posts 352 photos | There are BA sizes on the S7 e.g the oilers are all 2BA. There are also i think whitworth too. I have a stack of old spanners & just go for what fits. Never bothered to look at what size they were. My little Bahco adjustable fits everything. Steve. Edited By Steviegtr on 07/04/2021 00:24:54 |
T.B | 07/04/2021 01:52:00 |
54 forum posts 21 photos | 2BA , 1/4" BSF and 7/16" BSF would be a good start.
Bo'sun | 07/04/2021 11:32:03 |
754 forum posts 2 photos | If I remember correctly, you need to bear in mind that not all BSF/BSW spanner sizes refer to the thread size as you might expect. Something to do with reducing the hex size to save material during WW2. |
Howard Lewis | 07/04/2021 14:41:24 |
7227 forum posts 21 photos | The Myford 7 Series was introduced in 1947, so being post War would, most likely, use the later, smaller BSW and BSF hexagon sizes. Spanner likely to see most use is the 7/16 BSF on the Toolpost. A 2 BA one for the locknuts on the gib adjusters, unless the nuts are oversize. Others are unlikeley to see much wear, unless you are planning a complete strip down and rebuild. A set of Imperial Allen keys will be useful. If you are, just be sure of what is involved before upsetting any adjustments. Howard |
JA | 07/04/2021 15:01:21 |
![]() 1605 forum posts 83 photos | Stephen My ten year old Myford came with two open ended spanners - 3/16W & 1/4W, 5/16W & 3/8W - and two Allen keys - 3/16AF and 5/32AF. Other than an open ended 2BA spanner these are all I have needed. The same goes, if my memory serves me well, for my earlier Super 7 Myford (the one with the flooded headstock bearing). JA
Tim Stevens | 07/04/2021 21:12:36 |
![]() 1779 forum posts 1 photos | One caveat: I have found that some of the whitworth spanners sold new on well known sites are rather loose in the fit on the nuts. The open ends seem to be made oversize, while the rings are not a series of 6 flats, or 12 half-flats, but a ring of rounded lumps. These tend to wear the heads - especially of adjusters as used on machines - much more rapidly than 'proper' flats. Combine this with the too slack fit to start with and it can be very disappointing. The answer - look for used Whitworth spanners on the same sites, and then look for reliable makes, such as: Hope this helps Cheers, Tim
Robert Butler | 07/04/2021 21:45:46 |
511 forum posts 6 photos | And use ring spanners where ever possible. Robert Butler
Nigel Graham 2 | 08/04/2021 12:51:19 |
3293 forum posts 112 photos | Note though that some of the accessories now sold appear to use fastenings to ISO-Somewhere-near, with a 17mm spanner fitting one or two of those on mine - and these were bought new. Most of the originals though are BSF/BSW.
John Purdy | 08/04/2021 17:33:26 |
![]() 431 forum posts 252 photos | As well as the ones mentioned by JA my Myford (1977) came with a single ended 3/8 A/F spanner for use on the lock screws on the cross slide to retain the top slide. My two double ended Whitworth spanners are "Snail Brand". John Edited By John Purdy on 08/04/2021 17:34:05 |
Michael Gilligan | 08/04/2021 17:51:21 |
![]() 23121 forum posts 1360 photos | Posted by Tim Stevens on 07/04/2021 21:12:36:
[…] while the rings are not a series of 6 flats, or 12 half-flats, but a ring of rounded lumps. These tend to wear the heads - especially of adjusters as used on machines - much more rapidly than 'proper' flats. Combine this with the too slack fit to start with and it can be very disappointing.
. That’s interesting, Tim ... it seems to completely contradict the story that Snap-on tells about ‘Flank Drive’ MichaelG. . Ref. https://worldwide.espacenet.com/patent/search?q=pn%3DUS3273430A [click the vertical column of three dots, at upper-right of the page, to find the download option] Edited By Michael Gilligan on 08/04/2021 17:53:19 |
Peter Sansom | 09/04/2021 11:45:03 |
125 forum posts 4 photos | Just look for Ring Open End spanners from a good brand. A set comprising 2BA and 1/4"BS to 7/16"BS. The largest 2 Nuts are the Lead Screw Hand wheel nut and the Tail stock nut.
Peter |
Robert Butler | 09/04/2021 23:08:47 |
511 forum posts 6 photos | If you are looking for Ring Open End spanners try instead for Combination spanners, ring at one end open ended at the other, Each spanner only fits one size. Robert Butler PS the ex Myford fitter who serviced my lathe advised Myford used the cheapest spanner sets available
DMB | 09/04/2021 23:35:24 |
1585 forum posts 1 photos | My S7, new in ?1971?, came with the 2 big double open ended spanners mentioned above and 2 small single open ended spanners, one fits topside locking screws, cant remember what the other was for, maybe banjo locking screws. Still need 2BA to fit Oilers and Allen keys for all the skt hds. L/S Brkts held by 2BA skt hds, e.g. A C - spanner was also in the kit to adjust the mandrel bearing. |
DMB | 09/04/2021 23:38:27 |
1585 forum posts 1 photos | Tim, That sounds like another brainless modern idea to save on production costs and bugger the result. Complete trash. |
Hopper | 10/04/2021 03:11:13 |
![]() 7881 forum posts 397 photos | Posted by Robert Butler on 09/04/2021 23:08:47:
Yes but in those days the cheapest spanners were still made in Britain and still quite reasonable quality for home use. They must have churned out millions of Snail brand and King Dick, Vincent etc spanners over the years so costs were low. But they used good steel and good dies to make them. Different story with today's cheapest cheese-metal spanners. I round up handfuls of good old BS spanners for peanuts whenever I am at garage sales and flea markets etc. The supply will run out one day so I figure I might as well keep them out of the hands of the hoarders. So I have a full set for each Brit motorbike and lathe in the shed. |
Nigel McBurney 1 | 10/04/2021 09:18:06 |
![]() 1101 forum posts 3 photos | Myford used the cheap end of the market black as forged UK made spanners as they knew that their lathes were good and did not need frequent adjustment so these spanners would not see much use. |
Matt Harrington | 10/04/2021 09:42:41 |
![]() 212 forum posts 16 photos | As Steve says, my 'go to' spanner for day to day stuff is a quality Bahco adjustable. Matt |
ega | 10/04/2021 10:03:54 |
2805 forum posts 219 photos | Did anyone mention the square socket wrench needed for the standard Super 7 topslide clamp screws? I long ago changed mine for hex socket screws: easier to access with a ball-ended driver and less temptation to overtighten. I think that one reason folk reach for the inherently inferior shifting spanner is the difficulty in selecting the right conventional tool from a bunch of others but colour-coding would solve that problem. |
SillyOldDuffer | 10/04/2021 10:56:48 |
10668 forum posts 2415 photos | Posted by Hopper on 10/04/2021 03:11:13:
Yes but in those days the cheapest spanners were still made in Britain and still quite reasonable quality for home use. They must have churned out millions of Snail brand and King Dick, Vincent etc spanners over the years so costs were low. But they used good steel and good dies to make them. Different story with today's cheapest cheese-metal spanners. I round up handfuls of good old BS spanners for peanuts whenever I am at garage sales and flea markets etc. The supply will run out one day so I figure I might as well keep them out of the hands of the hoarders. So I have a full set for each Brit motorbike and lathe in the shed. Isn't it odd Model Engineers are the only people in the world who believe steel made 60 years ago is better than anything produced today? It's not my experience. When I bought my first socket-set, an elderly chap intervened to explain Japanese tools were rubbish and because it wouldn't last I should spend 3 times more on a British set. Fifty years later the Japanese set is fine (and is now recognised as a reputable Brand!) He was wrong! In the last 3 years the Chinese made more steel than the British steel industry produced throughout their entire history. It is an enormous quantity of steel and although some of it might be below par, in general it's closer to specification than historic steels. Not paddy farmers stirring old bicycles into a pot, the production is from large modern steelworks using the world's most advanced processes. Too many British firms after WW2 believed their own propaganda. Rather than accept the need to change and modernise, they tried to convince customers their over-priced products were 'quality' and appealed to our patriotism. Unfortunately, patriotism cuts no ice in export markets. Abroad, British goods came to be associated with average quality and high-prices. At home, people gradually realised they were paying over the odds for stuff that was just expensive. I suggest we rose-tint the past as we grow older! The past was better because I was young, not because things were done properly then. Now retired, I remember the good bits and expunge the less creditable episodes! Spanners are an example: lasted jolly well most them, but is it due to them being solid, lightly used and kept indoors or ' they used good steel and good dies to make them'. If spanners were wonderful, why did UK makers churn out millions of third rate steel cars? Nice spanner, shame about the car? I have a GPO tool roll full of well-made British screwdrivers and a contemporary British screwdriver that bends! It's rubbish. Nothing to do with steel, or when and where the screw-drivers were made. The bendy example is too cheap whereas the GPO bought the best tools available at the time, unaffordable for amateur purposes. Important to compare like with like before jumping to conclusions. Always dangerous to believe your own propaganda. Faced with the need to compete in a rapidly changing world, looking to the obsolete methods of the past is unlikely to work for industry today, no matter how effective they once were. Time flies. It's what customers want tomorrow that matters. There's no place for small 'c' conservatism in manufacturing: such thinking does too much damage. Dave
