John Smith 47 | 22/03/2021 22:31:47 |
393 forum posts 12 photos | Hello
I am thinking that in principle I just just cut a long strip of steel that is 13.1mm wide, and put a 45° chamfer on it and then cut it up into 16mm lengths. So was thinking that maybe I should buy a small desktop milling machine. With thanks J So do you think I should add to what I have got...? Possibly with some sort of vice(??)
Emgee | 22/03/2021 23:00:54 |
2610 forum posts 312 photos | You could use a 90 deg spot drill but I don't think you will have much success with the tools you have, a small milling machine would cope with such work. Emgee
pgk pgk | 22/03/2021 23:24:59 |
2661 forum posts 294 photos | I don't know how well it'd work in practice but with only access to rudimentary equipment I'd be inclined to bond the strip of steel between 2 lengths of MDF, say 9mm and make up a jig and fence and run a conventional router with a 90 deg cutter along it. A TCT router cutter should cope with 1mm steel OK in such a sandwich.
pgk |
Jeff Dayman | 22/03/2021 23:32:11 |
2356 forum posts 47 photos | If you truly need an exact 45 degree angle as you say, I suggest a sine bar setup to make an accurate jig to hold the work in a surface grinder. You will get an exact 45 degree angle very accurately positioned from an edge with this method. Faffling around with plastic toy tools as you show in the pics is much less likely to produce accurate results repeatably. |
Peter Cook 6 | 22/03/2021 23:35:29 |
462 forum posts 113 photos | Put a grinding wheel in the proxxon drill. Set the (a) fence at 90 degrees to where you have it now and the correct distance from the wheel. With the grinding wheel flat you could do the back edge, Tilt the wheel to 45 degrees reset the distance to the fence and grind the chamfer. You should have enough power for 1mm steel sheet. Edited By Peter Cook 6 on 22/03/2021 23:36:14 |
John Smith 47 | 23/03/2021 12:36:39 |
393 forum posts 12 photos | Emgee - Can you recommend a good quality, compact milling machine?
Frankly it all looks a bit pathetic/toy-like! PS I feel in my bones that I should be using something much more powerful. e.g. I have this (slightly beaten up) 750watt hand drill. (See https://www.amazon.co.uk/Bosch-PSB-750-Hammer-Drill/dp/B003UES78K)
Edited By John Smith 47 on 23/03/2021 13:11:37 |
Zan | 23/03/2021 12:56:37 |
356 forum posts 25 photos | Posted by Jeff Dayman on 22/03/2021 23:32:11:
If you truly need an exact 45 degree angle as you say, I suggest a sine bar setup to make an accurate jig to hold the work in a surface grinder. You will get an exact 45 degree angle very accurately positioned from an edge with this method. Faffling around with plastic toy tools as you show in the pics is much less likely to produce accurate results repeatably. Come on Jeff, get real He has very little kit and no room for even a small mill let alone a surface grinder He is asking for advice. Not a scathing unhelpful comment from someone who obviously has a lot of kit |
JasonB | 23/03/2021 13:08:38 |
![]() 25215 forum posts 3105 photos 1 articles | Given the tools to hand I think I would cut the rectangles first, a bit oversize on the 13.1mm dimension then drill the Holes. Make a simple jig with two tapped holes so the work can be screwed to it. Then set jig at 45deg and use a cut off disc in the still vertical tool to cut the edge to 45deg, less chance of wear giving differing sizes or clogging which you may get with a grinding bit. Edited By JasonB on 23/03/2021 13:08:49 |
Martin Kyte | 23/03/2021 13:10:12 |
![]() 3445 forum posts 62 photos | If you want to set an exacyt angle then a sine bar as has been suggested is the way to go to mount the work. If however you are looking to make a mitre that will join to make a 90 degree corner then I suggest you mount the two pieces square to each other and run a cutter between them to acieve two exactly matching bevels. If one is off by half a degree the other will compensate by being off in the other direction. It always helps if you give some details of what you are trying to make. regards Martin |
HOWARDT | 23/03/2021 13:10:23 |
1081 forum posts 39 photos | You say sheet steel but you may be better with gauge plate, it will be flatter to start with and cut better than soft sheet steel. I would clamp the piece standing up, rough cut with a small carbide cutter, Dremel type not mill type, then finish to size with diamond cutter. You could try any combination of cutter materials, just bear in mind the speeds your spindle is capable of. |
Andrew Johnston | 23/03/2021 13:10:47 |
![]() 7061 forum posts 719 photos | Posted by Zan on 23/03/2021 12:56:37:
Come on Jeff, get real He has very little kit and no room for even a small mill let alone a surface grinder He is asking for advice. The real question is how accurate does "exact" imply? Until that is quantified then what kit one may, or may not, have is irrelevant. Andrew |
John Smith 47 | 23/03/2021 13:41:47 |
393 forum posts 12 photos | Thanks for all your quick responses I have yet to work out a good way to cut the plate accurately. I have a hand held Nibbler like this: But even when used carefully makes a bit of mess of the steel sheet!
John Smith 47 | 23/03/2021 13:47:34 |
393 forum posts 12 photos | HowardT - what exactly do you mean by a carbide cutter and a diamond cutter?
Edited By John Smith 47 on 23/03/2021 13:50:39 |
Andrew Johnston | 23/03/2021 14:43:39 |
![]() 7061 forum posts 719 photos | Posted by John Smith 47 on 23/03/2021 13:41:47:
The reason for the accuracy is thatt they are for magnetic guides and even a 0.1mm gap will cause a significant drop in magnetic pull. In magnetic terms 0.1mm is a pretty big gap. With the existing design and kit available I think you'll be wasting your time. Far better to invest that time in coming up with a better design. Why can't the part be bent from a single blank? Even if the angles could be made accurately how are you going to hold the parts together? Ferrite cores, gapped or otherwise, come with stiff springs to hold them together for a good reason. Andrew |
John Smith 47 | 23/03/2021 15:01:22 |
393 forum posts 12 photos | Andrew - Sorry, no I am not in a position to seek public opinions about our design. So no, I am not in a position to disclose the details of the design. Sufficeit to say that no, the part absolutely CANNOT be bent from a single part. Edited By John Smith 47 on 23/03/2021 15:01:56 |
Bo'sun | 23/03/2021 15:10:37 |
754 forum posts 2 photos | Hi JS 47, I appreciate your dilemma with a small workshop space. A little more detail of what you are trying to achieve might render some more suggestions. |
HOWARDT | 23/03/2021 15:39:06 |
1081 forum posts 39 photos | I was referring to the material of the cutter that is doing the cutting. If you look at cutters on the Dremel site you will see cutters with the letters HSS, which stands for high speed steel, and others may say carbide and again diamond. HSS and carbide cutters are usually solid metal, carbide is a sintered powder usually harder than HSS when formed. Some cutters are diamond coated which is used for lighter cuts in hard materials. If you are cutting sheet steel then HSS might be adequate at least for trials when roughing then use a diamond wheel to finish to get the accuracy you want. Holding the piece perfectly parallel to the cutter is the key to achieve what you want so a little fixture with pins and clamp would do and slide it along a guide under the fixed cutter. |
JasonB | 23/03/2021 15:48:17 |
![]() 25215 forum posts 3105 photos 1 articles | JS47, file one edge of the sheet straight. Then use a hacksaw to cut off a strip say 14mm wide does not have to be 100% straight. Then hacksaw into pieces and file the two ends to give lengths of 16mm and drill. You can now cut the 45edge as I suggested which will clean up the wavey sawn edge and leave it at 45deg. I would use the same method if doing it with a mill, except the 3 other edges would also be milled at 90deg to the face and at right angles to each other and obviously use a milling cutter rather than be limited by what you can run. Edited By JasonB on 23/03/2021 15:51:36 |
Tim Stevens | 23/03/2021 16:08:11 |
![]() 1779 forum posts 1 photos | How about a different approach? First, cut your steel into pieces of the size required but leaving say 5mm on the edge where the 45 degrees is required. Find yourself a slab of steel with a good flat face, big enough to accommodate the full length of the 45 edge, and ensure that is is properly flat - perhaps get a local engineering firm to do this bit. While you are there, ask them if they could prepare a bar of tool steel with 5 faces - like a long shed with flat floor and walls, and a roof at 45 degrees each side. This should be hardened and tempered. The cost of doing this will be way less than buying new machinery. Then you need a big solid vice, or a bottle jack, and add some ingenuity, so you have some way of forcing the roof of the 5-sided bar into the steel plates at exactly the right position, one at a time, until the edge is cut away. This will mark the slab each time, so move across the surface with each piece to avoid marking the back of the workpiece. This should give you edges which are as accurately 45 degrees as the tooling itself. Wrap some fine wet-&-dry paper round a flat file and run this along the finished edges to remove any burrs. The sharper the roof edge and the flatter the slab, the more tidy will be the product. Hope this helps Cheers, Tim |
Tony Pratt 1 | 23/03/2021 17:14:10 |
2319 forum posts 13 photos | I would suggest hacksaw/bandsaw sheet metal blanks & then finish mill all round to get all 32 parts any where near 'identical'. Warco, Chester or Arc Eurotrade sell suitable mills. Trying to do this job by hand is not really an option. Tony |
