Henry Rancourt | 21/03/2021 16:03:59 |
20 forum posts 47 photos | I need a new motor for my Boley Leinen 8mm lathe and my web searches have led me to thinking brushless DC motors have very good characteristics for mini lathes. Is anyone here using one on their lathes and if so, what brand? Thanks, |
Bob Stevenson | 21/03/2021 17:09:50 |
579 forum posts 7 photos | In my clock club (EFHC) we have a Chinese watch lathe 8mm which was donated in 2019.....a copy of a Bergeron lathe. We equipped it with a Chinese industrial sewing-machine motor.....either from EBay or Banggood..can’t recall which but it is very small, about 1hp, came with switch unit fitted giving forward/reverse & variable speed. & was well under £100
Due to the virus it has not had much use but I did use it once and was impressed....it worked well and I preferred the speed knob much better than the foot controllers on our other watch lathes. |
Neil Wyatt | 21/03/2021 17:15:16 |
![]() 19226 forum posts 749 photos 86 articles | Many mini-lathes come with them as original fitting. Not sure what brand motors, but the lathes are mostly made by SIEG and Real Bull. I would just get a suitable size motor and controller from a reputable supplier who can support you if you have any problems. Neil
Michael Gilligan | 22/03/2021 08:40:12 |
![]() 23121 forum posts 1360 photos | Posted by Bob Stevenson on 21/03/2021 17:09:50:
[…] ... it is very small, about 1hp, came with switch unit fitted giving forward/reverse & variable speed . Reading back through your post, Bob I realise it’s variable speed, etc, ... but is there any justification for a 1hp motor on an 8mm lathe ? ... Not arguing : Just a little surprised by the choice. MichaelG. . P.S. __ @Henry I had a look through your Album ... The B&L looks very nice indeed ! |
not done it yet | 22/03/2021 08:59:15 |
7517 forum posts 20 photos | justification for a 1hp motor on an 8mm lathe ? It would not have been an ordinary domestic sewing machine, either. |
Michael Gilligan | 22/03/2021 09:07:40 |
In my clock club (EFHC) we have a Chinese watch lathe 8mm which was donated in 2019.....a copy of a Bergeron lathe. We equipped it with a Chinese industrial sewing-machine motor..... . Here’s a link to one ‘U.K. Supplier’ of such items: **LINK** https://vevor.co.uk/products/sewing-machine-motor-220v-750w-brushless-energy-saving-servo-motor-industrial MichaelG. |
Russell Eberhardt | 22/03/2021 10:11:52 |
![]() 2785 forum posts 87 photos | Posted by Michael Gilligan on 22/03/2021 09:07:40:
https://vevor.co.uk/products/sewing-machine-motor-220v-750w-brushless-energy-saving-servo-motor-industrial MichaelG. That looks to be good value. It doesn't have a servo though, it's an ac induction motor with an inverter. Nothing wrong with that but I do wish suppliers would describe products accurately. Russell
Edited By Russell Eberhardt on 22/03/2021 10:12:34 |
Hopper | 22/03/2021 10:25:29 |
![]() 7881 forum posts 397 photos | Posted by Michael Gilligan on 22/03/2021 08:40:12:
[…] ... it is very small, about 1hp, came with switch unit fitted giving forward/reverse & variable speed . Reading back through your post, Bob I realise it’s variable speed, etc, ... but is there any justification for a 1hp motor on an 8mm lathe ? ... Not arguing : Just a little surprised by the choice. MichaelG. . P.S. __ @Henry I had a look through your Album ... The B&L looks very nice indeed ! Those are Chinese ponies, not the same kind of horses we rate motors with. I think maybe they talk about the power consumed while we talk about the output power. That's their excuse anyway for selling "2.5HP" air compressors that are nothing of the sort by the normal way of rating such things. And not at their price of $100. So the sewing machine motor might be half a horsepower output. Or something... Edited By Hopper on 22/03/2021 10:26:24 Edited By Hopper on 22/03/2021 10:27:19 |
Clive Steer | 22/03/2021 10:59:39 |
227 forum posts 4 photos | I've been investigating the use of Brushless DC motors for small machine operation and purchased an "Industrial Sewing machine motor conversion kit" to check them out given their described performance. They also appear to be excellent value for money compared to a 3 phase induction motor and VFD combination which doesn't come "plug and play". The other benefit of the BLDC motor is its small size and weight given the power and high torque it can provide. The high torque ( 3 N-m) aspect would allow a small lathe such as a Pultra to be directly driven without needing a countershaft/pulley system as BLDC motors can develop their full torque even at low speeds. The controllers of the sewing machine motors are described as providing servo speed control, which is needed for a sewing machines cyclic load variation and is a benefit for a lathe also. The down side is that a sewing machine is usually operated either off, slow speed for positioning and then full speed and the full speed is preset on the controller for what the machine or operator can cope with. The speed control unit has an operating lever connected by a rod to a foot operated treadle. Internally it has a linear Hall effect device so when the control lever is moved a magnet moves in a small arc above the Hall device. The Hall device is powered by 5V from the Motor control unit and produces an output from zero to about 4V when the operating lever is moved over its full range. From zero to 2.5V the motor is OFF, from 2.5V to 3V the motor operates at a fixed slow speed of around 200RPM and from 3V to 4V the motor speed varies linearly from slow to full speed. On my unit the full speed can be set from 500 RPM to 4500 RPM. If 500 RPM full speed is selected the 1V linear range of the Hall is used to proportionally control the speed from 200 RPM (jog) to 500 RPM. To check out what resolution the 3 - 4V proportional range was I replaced the Hall device with a 10 turn potentiometer and found that even for a high full speed setting, (200 - 4500 RPM range) the speed was essentially linear with no noticeable steps although I may test this further. A word of warning !!! there is no isolation of the controller electronics including the speed control Hall device from the mains supply so adequate precaution should be taken to prevent contact with potentially live circuitry. The consequence of any error in this matter can be serious!! I purchased a second similar unit from a different supplier and the motor used is a Permanent Magnet Synchronous Motor and works in a slightly different way to a BLDC motor. Both motors are driven by sinusoidal waveforms so produce low torque ripple another plus for use with a lathe. Being servo controllers when the manual speed control is moved to off from say full speed the motor is physically braked by the control and it stops almost instantly. I haven't explored this area of operation when the motor is loaded with significant rotational inertia. The controller also has the capability to position the output shaft which in a sewing machine relates to the needle position using another sensor which may be useful for a lathe ? My investigations continue but so far they have the potential of being good for powering even larger lathes such as a Myford if this isn't heresy. Clive |
Niels Abildgaard | 22/03/2021 11:24:28 |
470 forum posts 177 photos | Posted by Clive Steer on 22/03/2021 10:59:39:
As a sewing machine motor fan I sincerely hope You will put up more writing and video concerning potentiometer substuting. Personally I think the Hall Sensor is more fail safe,but hearing contra views is interesting. A Myford with 500Watt BLDC(smallest size) is an overkill.It will maybe selfdestruct. My latest motor is a 1500 Watt /12Nm/3500rpm and that will make a Myford look like an (Expensive) corkscrew. |
Frances IoM | 22/03/2021 12:09:59 |
1395 forum posts 30 photos | This is the sort of discussion and subsequent article that should be carried in MEW possibly at the expense of 6 page articles on Mull scarecrows |
Clive Steer | 22/03/2021 12:11:16 |
227 forum posts 4 photos | Although I would like to present more details about the substitution of the pot for the Hall device it was just a way of exploring the controller functionality and not a recommended conversion. As an experienced electrical/electronics design engineer I understand the electrical safety issues but others may not have that understanding and in experimenting put themselves and others at risk. Even commercial VFDs only have Basic insulation between high internal voltages and their control potentiometer input and any failure of this insulation could cause the Pot circuit to become live so supplementary insulation/isolation needs to be added externally in the way of putting the pot in say a plastic box and using a plastic knob. In the case of the sewing machine motor controller the Hall circuit is directly connected to high voltage (160V DC) with regard to neutral or earth so supplementary insulation/isolation is imperative and needs to be done correctly. The hall sensor can still be used but there may be mechanical limitations to the fineness of control achievable when zero to full scale output from the Hall device is brought about by a 3mm movement of the magnet. However fitting a shaped pole piece to the magnet may improve the situation and worthy of a try as the Hall device would be more reliable as there is no moving contact. Clive |
Bob Stevenson | 22/03/2021 14:35:13 |
579 forum posts 7 photos | @Micheal G........We basically bought a motor that 'looked' ok and apparently offered a solution.....since it was quite cheap (seem to remember £62...might be wrong!) we ordered, removed supplied pulley, adapted baseboard, replaced pulley, fitted drive belt, and switched it on!.....20 mins later it had completed the first made part.....I did not expect a great deal, frankly, but it works extremely well.
I will say, that the clubs main watch lathes (IME mainly with a couple of Pultras) used on the watch side of the club all use convention al sewing machine motors which have always seemed underpowered to me, as well as awkward with the foot controller. The lathe mentioned here/above has lots of power and does not loose torque when deeper cuts are made using the compound (my prefered option)
Also, about 5 or 6 years back we had a member who famously used a model aeroplane motor called an 'outrunner'....basically a light-weight brushless motor to power his watch lathe, apparently very successfully. I did NOT see the resulting machine but I DID see the tiny motor which was rated at 900 watts (?!!)..it was about the size of a 35mm film cylinder for 36 exposures (if anyone remembers what that's like!) |
Michael Gilligan | 22/03/2021 15:10:22 |
![]() 23121 forum posts 1360 photos | Thanks for the reply, Bob ... if it works for you, that's great It's just that I would have never thought to put a more powerful motor on my 8mm watchmakers' lathe than I currently have on the Myford ML7R
MichaelG. |
Bob Stevenson | 22/03/2021 15:31:23 |
579 forum posts 7 photos | Interesting.....I'm not aware that a lathe motor (in this context) could be too powerful...certainly 'bigger is not always better', but you can easily turn down the power, which is usually what i do with these very small lathes...and it's useful to have more power available should you need it..also motor is not 'flat out' etc |
Michael Gilligan | 22/03/2021 16:06:52 |
![]() 23121 forum posts 1360 photos | Posted by Bob Stevenson on 22/03/2021 15:31:23:
Interesting.....I'm not aware that a lathe motor (in this context) could be too powerful...certainly 'bigger is not always better', but you can easily turn down the power, which is usually what i do with these very small lathes...and it's useful to have more power available should you need it..also motor is not 'flat out' etc . I fully accept that, Bob ... in fact I implied it in my first post on the subject. MichaelG. |
Michael Gilligan | 22/03/2021 17:00:08 |
![]() 23121 forum posts 1360 photos | This may be of interest: **LINK** https://youtu.be/4htyv7Bg3rY Installation of a 550W sewing machine motor on an [Australian made] Advance Lathe. MichaelG. . Edit: __ and getting back to the opening question ... a BLDC motor on a mini-lathe: Edited By Michael Gilligan on 22/03/2021 17:04:39 |
SillyOldDuffer | 22/03/2021 17:53:57 |
10668 forum posts 2415 photos | Perhaps a subject for another thread, but isn't there confusion about what 'power' means in connection with motors? Power is a rating, not a fixed output. It's the rate at which a motor is sized to do work where both 'power' and 'work' have specific technical meanings different from ordinary English. Say you buy a 1000W motor:
I suspect many assume power output is a problem when it's the duty cycle or motor type that matters. And also true that advertisers highlight the parts of the specification that appeal to the customer, perhaps claiming correctly the motor can deliver 2HP out, whilst not mentioning it will only do so for 5 minutes in every hour without burning out. Motor power is likely to be deceptive, either optimistic sales-speak, or due to purchaser not undertanding the detail. It's not like buying a kilo of cheese where weight is defined exactly. Instead, output power is a rating, indicating roughly what to expect, and it can't be trusted unless the other factors are defined, and they are often only available in the full specification. Applies to heat engines too: the power output of a car engine varies considerably, being quite low when the car is cruising at 40mph on a flat road, and far, far higher towing a heavy caravan over the Simplon Pass. (One of my fond childhood memories is dad's Ford Anglia passing several boiling performance cars going up the Simplon, perhaps because their designers depended on speed to keep the engine cool...) Dave
Edited By SillyOldDuffer on 22/03/2021 17:55:59 |
Michael Gilligan | 22/03/2021 18:35:50 |
![]() 23121 forum posts 1360 photos | Interesting dissertation, Dave ... But I think we should just note that the 'Industrial Sewing Machine Motors' [whatever their actual design and specification, both of which remain under-documented] are widely used in the garment-making sweatshops of the World: So perhaps we can reasonably assume that at least some of them are rated for continuous use. MichaelG.
noel shelley | 22/03/2021 22:20:06 |
2308 forum posts 33 photos | SOD, s points remind me why many bought Japanese audio gear ! They quoted Peak power, whereas We quoted RMS - Half the value !!! Noel |
