Advice
Dale Parsons | 07/03/2021 16:45:01 |
5 forum posts | Hello all. Please could you share with me some of your valuable knowledge on this skill, I’ve had a warco 180 delivered and totally new to this, have been watching you tube vids and thought I’d try to make brass handles for the lathe as a start project. Could someone advise what lathe knurling tool I need to buy as there is so many and ones with more wheels than some I appreciate you taking the time to help a newcomer to this skill set kind Rgds dale
Journeyman | 07/03/2021 17:09:14 |
![]() 1257 forum posts 264 photos | Basically 3 types (someone will be along soon to tell me I'm wrong). For a small lathe such as the WM180 probably better with the Clamp type as it imposes less strain on the bearings. The cut type are good but seethingly expensive. Have a look at this one from ** ArcEuroTrade ** This article on making ** toolmakers clamps ** covers knurling in a bit more detail, about half way down the page. John Edited By Journeyman on 07/03/2021 17:16:53 |
Frances IoM | 07/03/2021 17:11:31 |
1395 forum posts 30 photos | the one with two wheels + a sisor like action to adjust to the bar and one that will fit in the tool post - the WM180 doesn't have the power to handle the single wheel type nor is the tool post big enough to take most - I bought mine I think from ARC but WARCO do a similar type but even then needed to mill part of the holding bar to fit the 180. There are several designs that you can make yourself Warco sell the hardened cutters - there was an interesting design by Jacques Chirac? in one of the mags abt 3 years ago that used non bevelled wheels to cut rather than crush the metal |
jon hill 3 | 07/03/2021 17:35:40 |
166 forum posts 40 photos | Why not make one, if you have some stock metals about there is plans for one in Harold Halls 'Lathework a complete coarse'. I think its workshop practice series no 34 There are plenty of other interesting projects in the book too. Jon |
Andy Carruthers | 07/03/2021 18:58:01 |
![]() 317 forum posts 23 photos | I bought scissor type and have good results from my WM180, didn't need to mill part of the holding bar though Recommend starting with soft material to practice on with lubricant, for me knurling is a confidence thing so I start with light clamp then tighten until I achieve the result I am aiming for An easy begiinners job is to replace the hand-dial knobs, plenty of operations to build confidence, I did mine in brass |
Dale Parsons | 07/03/2021 19:06:26 |
5 forum posts | Thank you for your replies. |
Dale Parsons | 07/03/2021 19:08:31 |
5 forum posts | Andy what size brass blanks did you buy / use for the handles. |
Andy Carruthers | 07/03/2021 19:25:10 |
![]() 317 forum posts 23 photos | I had some brass offcuts lying around so used those, IIRC the handles ended up ~20mm in diameter, much more tactile than the originals not just because of the knurl, but also because of the diameter |
Gary Wooding | 08/03/2021 07:27:39 |
1074 forum posts 290 photos | **THIS** pdf describes a clamp type knurling tool that I designed and made many years ago. It gives full details and dimensions. It works well and I've used it many times. |
Hopper | 08/03/2021 07:55:19 |
![]() 7881 forum posts 397 photos | Posted by Gary Wooding on 08/03/2021 07:27:39:
**THIS** pdf describes a clamp type knurling tool that I designed and made many years ago. It gives full details and dimensions. It works well and I've used it many times. That looks like a beauty. The side plates look as though they would stop the problem of the two arms flexing out of line under heavy loading etc. Thanks for posting. |
Dale Parsons | 08/03/2021 09:33:19 |
5 forum posts | Jon hill 3 thank you for advising on the books I’ve purchased both of them on Amazon, Andy carruthers looked on eBay for some brass blanks can’t get over how expensive they are, think I’ll be going with aluminium lol. thanks again for all your post. |
bernard towers | 08/03/2021 09:33:55 |
1221 forum posts 161 photos | Gary, very similar to the MARLCO which industry loved , I made the Hemingway version and have never looked back. Think it’s all down to the large side cheeks. |
Michael Gilligan | 08/03/2021 09:39:29 |
![]() 23121 forum posts 1360 photos | Posted by Gary Wooding on 08/03/2021 07:27:39:
**THIS** pdf describes a clamp type knurling tool that I designed and made many years ago. It gives full details and dimensions. It works well and I've used it many times. . Nicely designed, and very clearly presented, Gary ... Thanks for sharing it. MichaelG. |
John Haine | 08/03/2021 09:51:54 |
5563 forum posts 322 photos | Just a small point, what do you intend to knurl? If you plan to make new handwheels for the lathe, bear in mind that knurling may be very uncomfortable on the hands after a short while as the surface can be rather sharp. Knurling is ideal for small knobs that aren't often adjusted, but with machine handwheels it can be better to have a smooth polished surface on both the wheel periphery and the handle. A nice rotating handle with minimal play is even nicer. |
Nicholas Farr | 08/03/2021 10:17:54 |
![]() 3988 forum posts 1799 photos | Hi, I have one similar to Knurling Tool I may have even got my one from them, but it was so long ago I can't remember, however it has worked satisfactory for my needs. Regards Nick. |
Andy Carruthers | 08/03/2021 10:42:22 |
![]() 317 forum posts 23 photos | John makes a good point, I recall someone (Hopper?) suggesting to run a file over the finished knurl to take the rough edges off, it has been a while since I made the handles |
Hopper | 08/03/2021 10:52:34 |
![]() 7881 forum posts 397 photos | Posted by Andy Carruthers on 08/03/2021 10:42:22:
John makes a good point, I recall someone (Hopper?) suggesting to run a file over the finished knurl to take the rough edges off, it has been a while since I made the handles Indeed it was. Was how apprentice toolmakers were taught to do it back in the ancient days of yore. A 10" flat single-cut mill file was the weapon of choice, used on the finished knurl spun in the lathe. Just enough to knock the sharp points and burrs off the knurls. Should be done as a matter of course on all knurling. Straight knurling works very well on things like cross slide dials and is easier again on the hands, after a touch up with the fine file. If you don't file it, a diamond knurl is basically like a rasp and I reckon you could use it to machine wood. Likewise I often notice homemade tool posts, cross slides, dividing heads and the like made from chucks of bright mild steel square bar with all the sharp corners left on, just waiting to smash knuckles and hands of the unwary. A few minutes to file a nice radius along each edge where two faces meet makes it all a lot more user-friendly. The bigger the radius, the more user friendly it is. Sharp corners always look half-done to me. Edited By Hopper on 08/03/2021 10:55:53 |
John Haine | 08/03/2021 11:12:47 |
5563 forum posts 322 photos | And when you say "handles", do you mean the handwheels or the bits that stick out? If the wheels, then they are pretty large diameter and you'd need a very big scissors/clamp type knurl that probably wouldn't fit the lathe! If the stick-out bits, if they already rotate, they don't need knurling. |
Howard Lewis | 08/03/2021 13:35:11 |
7227 forum posts 21 photos | I have both clamp and push in types. Almost invariably the clamp type is used. This is equipped to give a diamond knurl. The push in one is for straight knurls, and is only rarely used, and then in gentle steps, out of regard for the Headstock bearings.. As an Apprentice I was told to use no more than 0.010" ( 0.25 mm) depth., and have always this quite sufficient. If you overdo things when making adjusting screw, the work can shear off! Howard |
noel shelley | 08/03/2021 13:59:46 |
2308 forum posts 33 photos |
