Blue Heeler | 03/03/2021 23:00:52 |
![]() 342 forum posts | Crowning a pulley for a flat belt, been trying on some ali before moving onto brass using the top slide set at 1° + and then set at 1° - and it ain't an easy exercise to achieve a simple crowned pulley! Any hints on how to do this? I thought this was going to be really simple, its kicking my arse! |
Michael Gilligan | 03/03/2021 23:15:44 |
![]() 23121 forum posts 1360 photos | Think of the crown as part of a sphere ... Then produce a suitably dimensioned ball-turning tool. MichaelG. |
Blue Heeler | 03/03/2021 23:29:29 |
![]() 342 forum posts | Posted by Michael Gilligan on 03/03/2021 23:15:44:
Think of the crown as part of a sphere ... Then produce a suitably dimensioned ball-turning tool. MichaelG. If I'm stuck on making a small crown and its kicking my **** to "produce a suitably dimensioned ball-turning tool" is probably going to kick my bruised **** out my shed door Edited By JasonB on 04/03/2021 06:57:33 Edited By JasonB on 04/03/2021 06:58:34 |
Pete. | 03/03/2021 23:31:00 |
![]() 910 forum posts 303 photos | Try planning it as series of cuts like a manually operated cnc process to get the profile, then blend it together with a file, Jason the moderator has some photos carrying out this process, I'm sure he'll explain in more detail when he sees your post. |
Michael Gilligan | 03/03/2021 23:42:12 |
![]() 23121 forum posts 1360 photos | Posted by Blue Heeler on 03/03/2021 23:29:29:
![]() I need a much easier method than that, I'm close to getting some files out. . You haven’t even mentioned what size the pulley is ... but the ball-turning tool need not be much more than temporary tool-post on a pivoted lever. MichaelG. |
Blue Heeler | 03/03/2021 23:57:25 |
![]() 342 forum posts | Posted by Michael Gilligan on 03/03/2021 23:42:12:
![]() I need a much easier method than that, I'm close to getting some files out. . You haven’t even mentioned what size the pulley is ... but the ball-turning tool need not be much more than temporary tool-post on a pivoted lever. MichaelG. Sorry Michael I should have been a lot more clearer mate. Edited By JasonB on 04/03/2021 06:58:12 |
Blue Heeler | 03/03/2021 23:57:44 |
![]() 342 forum posts | Posted by Pete. on 03/03/2021 23:31:00:
Try planning it as series of cuts like a manually operated cnc process to get the profile, then blend it together with a file, Jason the moderator has some photos carrying out this process, I'm sure he'll explain in more detail when he sees your post. Thanks Pete. |
Michael Gilligan | 04/03/2021 00:20:33 |
![]() 23121 forum posts 1360 photos | Posted by Blue Heeler on 03/03/2021 23:57:25:
[…] . At those proportions you will need your surface to be much bigger radius than the pulley, but the principle is still good ... You might be pivoting the lever on the shed wall though, rather than clamping it to the lathe Not really relevant, but here are some notes about the ‘crown height’ on full size pulleys. http://www.visusa.com/belt_tracking_m01.htm MichaelG. . Edit: The first few seconds of this woodworking demo are probably all you need to understand what I am wittering on about : https://youtu.be/fmzD8wI8RIA Edited By Michael Gilligan on 04/03/2021 00:30:36 |
Blue Heeler | 04/03/2021 00:23:35 |
![]() 342 forum posts | Thanks for the link Michael. |
Blue Heeler | 04/03/2021 05:49:05 |
![]() 342 forum posts | Thanks all, managed it finally, that camber is 1.5° - |
JasonB | 04/03/2021 07:26:10 |
![]() 25215 forum posts 3105 photos 1 articles | having spent enough time toning down the language used I not go through it again, if you search "crowning jasonB" on the homepage search box you will find several threads like this about crowning pulleys & flywheels and also fish bellies on conrods. This has always been the traditional model engineers way of doing it so no need for large radius ball turning tools and you were right in your first post about getting your files out. |
Nicholas Farr | 04/03/2021 07:47:28 |
![]() 3988 forum posts 1799 photos | Hi MichaelG, I'm not really into wood turning, but a very interesting demo you've linked too. Regards Nick. |
not done it yet | 04/03/2021 08:25:12 |
7517 forum posts 20 photos | If it’s for authenticity, OK. But for a normal flat belt I would stick to a pulley with side guides and make full use of the contact area. Worked well enough on our Massey Harris 701 baler. |
Chris Evans 6 | 04/03/2021 08:41:17 |
![]() 2156 forum posts | Faced with this type of calculation again do it in steps as suggested. The formula is the square root of radius squared minus distance moved (step over) squared. Hope this makes sense. |
JasonB | 04/03/2021 08:49:48 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Chris Evans 6 on 04/03/2021 08:41:17:
Faced with this type of calculation again do it in steps as suggested. The formula is the square root of radius squared minus distance moved (step over) squared. Hope this makes sense. is that not just the radius? |
Michael Gilligan | 04/03/2021 08:51:49 |
![]() 23121 forum posts 1360 photos | Posted by Blue Heeler on 04/03/2021 05:49:05:
. That looks good MichaelG. |
Martin Kyte | 04/03/2021 08:52:26 |
![]() 3445 forum posts 62 photos | Hand turn it against a prifile guage. regards Martin |
Michael Gilligan | 04/03/2021 08:58:31 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 04/03/2021 08:49:48:
Faced with this type of calculation again do it in steps as suggested. The formula is the square root of radius squared minus distance moved (step over) squared. Hope this makes sense. is that not just the radius? . ... but you only emboldened part of the text ! Try adding some mathematically relevant parentheses to what Chris wrote. MichaelG. |
ega | 04/03/2021 10:05:30 |
2805 forum posts 219 photos | Posted by not done it yet on 04/03/2021 08:25:12:
If it’s for authenticity, OK. But for a normal flat belt I would stick to a pulley with side guides and make full use of the contact area. Worked well enough on our Massey Harris 701 baler. I seem to remember that the pre-war Austin 7 dynamo pulley was like this but also had a degree of crowning? Belt and braces! |
Nigel McBurney 1 | 04/03/2021 10:09:01 |
![]() 1101 forum posts 3 photos | General practice with belt drives ,in our sphere of vintage steam and oil engine belt drives ,was if the motive power runs at a higher speed than driven machine ,the large pulley on the machine would be crowned and the small pulley on the engine would be parallel, where it was the other way round ie a traction engine driving a faster rotating small pulley on sat a threshing machine then the T/E flywheel would be crowned and the small pulley would be parallel and very often with raised sides to stop the belt slpping off as the threshing machine was never in perfect alignment as it was on rough ground, Now on oil engines as they very often ran faster than the driven machine the engine belt pulley was parallel and I have not come across any genuine manufacturers pulley that was crowned,with the exception where they had to drive a generator or thrashing machine and these would be vey large pulleys. Where it was common in steam practice for portable and traction engine to have crowned flywheels ,oil engines tended to have flat face flywheels only one of my oil/lgas engines has a crowned flywheel, So for a small pulley is crowning essential,? |
