(If it used USB for data transfer)
Ian P | 26/02/2021 20:07:02 |
![]() 2747 forum posts 123 photos | I've put this in the Tea Room as its mostly for discussing the pro's and conn's of cheap versus expensive cables between PC's and driven equipment. Is seems that (apparently) transferring digital audio signals is best achieved by using only the highest quality cables. I have always understood that digital was digital and thought that as long as a USB cable transfers the 0's and 1's to the far end it would have no effect on the sound quality. Since the cables in the links below improve the sound quality, would these cable make CNC machined parts even more accurate? Edited By Ian P on 26/02/2021 20:08:11 |
HOWARDT | 26/02/2021 20:15:02 |
1081 forum posts 39 photos | Cheap compared to some Kimber hi-fi cables. Not convinced that beyond switching away from bell wire or equivalent makes much difference, but then I only listen to LP,s. |
Andrew Tinsley | 26/02/2021 20:15:46 |
1817 forum posts 2 photos | Ah! That reminds me that gold plated pins on a 13 amp socket, definitely improve the audio from good analogue audio amplifiers! Andrew. Edited By Andrew Tinsley on 26/02/2021 20:16:09 |
Tom Sheppard | 26/02/2021 20:20:08 |
47 forum posts | Sheer twaddle. Electrons aren't fussy. |
James Hall 3 | 26/02/2021 20:25:50 |
92 forum posts 12 photos | I think that someone has (apparently) been pulling your plonker. IFF the bits are getting transmitted and received correctly the quality of the cable will make absolutely no difference. Unless you are sending signals over too long a distance or in a high noise environment the chances are that a cheap cable should be fine (subject to correct manufacture). |
Emgee | 26/02/2021 20:27:25 |
2610 forum posts 312 photos | Screened cables usually provide better interference rejection. Emgee |
Andrew Johnston | 26/02/2021 21:21:20 |
![]() 7061 forum posts 719 photos | Posted by Tom Sheppard on 26/02/2021 20:20:08:
Sheer twaddle. Electrons aren't fussy. Hmmm, not an electronics engineer I presume? Electrons most definitely are fussy, and can be extremely annoying when they don't flow where you expect. The USB signal (1.x and 2.0) is differential, transmitted over a twisted pair with a nominal impedance of 90 ohms. If the impedance is wrong and/or the lines are not terminated properly then reflections and overshoots will occur, ultimately leading to loss of signal integrity. A digital signal is really an analogue signal. In some ways digital is more challenging than analogue as the fast edges imply a larger bandwidth than might be suggested by the data rate. If the transmission channel is not linear, ie, non-dispersive, then distortion of the signal will result leading to problems in decoding the signal. There's a vast literature available on the transmission and decoding of digital signals, with some pretty hairy mathematics. Having said the above a quality USB cable will not be expensive. The cables linked to in the OP are nothing to do with technical ability; they're intended to separate fools and their money. Andrew |
Ian Parkin | 26/02/2021 21:52:28 |
![]() 1174 forum posts 303 photos | I see that in Ians links to the cables they can add on a cable of three thousand pounds a contract enhancer for only an extra £3.20 must be some special snake oil... I’d love to know how many cables they can sell at those prices Edited By Ian Parkin on 26/02/2021 21:53:18 |
James Hall 3 | 26/02/2021 21:52:37 |
92 forum posts 12 photos | A digital signal is most definitely NOT an analogue signal. Over copper it is transmitted by way of an underlying analogue signal, but that is a different matter and the two signals are quite discreet. |
Ian Parkin | 26/02/2021 21:56:58 |
![]() 1174 forum posts 303 photos | And look at the cost of mains cables a 10m iec set for only £13,800 where do they think the electricity comes from to supply the mains socket
makes a new myford look good value Edited By Ian Parkin on 26/02/2021 21:57:49 |
SillyOldDuffer | 26/02/2021 21:58:19 |
10668 forum posts 2415 photos | USB doesn't provide any error correction itself so maybe a bad connection due to an unshielded cable in an electrically noisy environment or wobbly plugs could corrupt the digital stream. I don't know what hi fi systems do, but computers send and receive data in check-summed blocks and usually ask for repeats until they get clean data. Broadcast digital tv and radio can't ask for a repeat so they just drop the offending block causing audio to go silent or the screen to pixelate. The quality of received segments is perfect, but they are interspersed by obvious glitches. Unlike an analogue system It either works or it doesn't: there is no general low-level loss of quality, just good and bad blocks. Maybe hifi systems use usb cables as ordinary audio connectors and aren't digital at all. A convenient bodge, but prone to analogue defects, that might be reduced by a decent cable. What's needed is a good dose of double-blind testing. For some strange reason it's never done... Dave
Andrew Johnston | 26/02/2021 22:10:42 |
![]() 7061 forum posts 719 photos | Posted by James Hall 3 on 26/02/2021 21:52:37:
..........and the two signals are quite discreet. That's a new one on me. I've never seen a signal, analogue or digital, that aimed to avoid social embarrassment. It's convenient, and may be logical, to think of a digital signal as being one of a small set of values. But in reality, however it exists, the actual signal is analogue. Would a FSK signal be analogue or digital? Andrew |
Martin Kyte | 26/02/2021 22:48:23 |
![]() 3445 forum posts 62 photos | I have to agree with Andrew in this one. The signal is analog. The signal is interpreted as digital by the receiver circuit defined by it's threshold levels. Digital coding, analog transmission. You could transmit digitally by sending single electrons with the data coded in spin up or spin down but the cost of your system would make the USB cables above seem cheap. regards Martin |
Martin Connelly | 27/02/2021 08:16:12 |
![]() 2549 forum posts 235 photos | My ears are well past their best before date. I doubt any amount of money thrown at a sound system will ever make it sound as good as when my ears were still in the first flush of youth. Martin C |
Hopper | 27/02/2021 08:38:35 |
![]() 7881 forum posts 397 photos | Yes, I just spent $1,000 on a new sound system. Then realised the sound is only going to be as good as my two hearing aids! Oh well, at least it's loud enough that I can't hear my neighbour banging on my door, or his bloody dog barking. |
Ady1 | 27/02/2021 08:56:55 |
![]() 6137 forum posts 893 photos | Plus our hearing degrades quickly as we age, particularly for the higher ranges Those fabulous ABBA sounds of our youth can never be as good in our old age no matter what we do Chap on my dog walk showed me with a phone app, neither of us could hear a thing in the higher ranges, even though those sounds were within the audible range for a human |
Hopper | 27/02/2021 09:28:58 |
![]() 7881 forum posts 397 photos | Yep that's me. Can't hear the beeper on the microwave any more or the "lights on" alarm beeper when getting out of the car. Shoulda worn earplugs in all those power stations I guess. Let alone Harleys with straight pipes and Nortons with megaphone mufflers. But that would have been uncool. |
Dave Halford | 27/02/2021 09:56:43 |
2536 forum posts 24 photos | You certainly get errors at 2mbit and above from a bad connection so decent connectors are worth paying for and it also helps that the impedance of the cable is what it says it is. Good screening will help stop the VFD noise getting on the cable. Will it make a difference CNC, no idea |
James Hall 3 | 27/02/2021 10:13:25 |
92 forum posts 12 photos | Martin Kyte: you may well agree with Andrew Johnston on this one but you would, with respect, both still bee wrong. This really is DigComms 101 - kids' stuff. To say that a digital signal is really an analogue one because it is carried over an analogue channel is as ridiculous as saying that an analogue signal is really a piece of wire because the piece of wire carries the electrons. I've tried to think up an illustrative analogy with the difference between the meaning of word and a dumb spell-checker for you further amusement - but it proved to be too contrived. |
Anthony Kendall | 27/02/2021 10:33:04 |
178 forum posts | Being a simple person, I like to look at it like this. Digital signals are decodeable providing noise added does not approach the amplitude of the digital signal such that it is not possible to reliably distinguish between a nought and a one. Thus, any cable should be low loss and screened. To answer the OP - unless you are going to send signals to your mate's house down the road, the normally available screened cables will suffice. This should cost no more than 2 quid per metre. It might even get you to your mate's house as well! |
