Pete Rimmer | 23/02/2021 17:13:13 |
1486 forum posts 105 photos | I put an advert on homeworkshop for an optically flat mirror but as yet have had no responses to it. These things seem to be thin on the ground and very expensive, if you buy the mounted ones. I'm looking for 'thinking out of the box' suggestions as to where I can find a decent fractional-wave first surface mirror to use as a reflector for an autocollimator I am picking up shortly. I can make the sled to carry it and I'm confident that I can make a mount but I need to first buy the mirror itself. I know that there are a few members interested in telescopy and other optical interests so I'm hoping that someone can suggest a source for a reasonably priced mirror. It must be flat, and first-surface, and fractional waveength, so half-wave or better. I'm not a tightwad but I don't want to pay newor crazy ebay prices. Hopefully there will be someone here can point me in the direction of a decent mirror or a device or instrument where they re used so I can look for a surplus one. Pete,. |
Michael Gilligan | 23/02/2021 17:34:36 |
![]() 23121 forum posts 1360 photos | Have a look at SurplusShed : **LINK** https://www.surplusshed.com/index.php Fred is a very honourable chap, and will accept an order cancellation if you don’t like his shipping rate. MichaelG. |
old mart | 23/02/2021 18:59:39 |
4655 forum posts 304 photos | You need to post the maximum and minimum diameters that would be useful to you. |
Pete Rimmer | 23/02/2021 20:03:17 |
1486 forum posts 105 photos | Well Mart, they come in all sizes but realistically I am expecting to find one between 1" and 3" diameter. |
John Haine | 23/02/2021 20:09:12 |
5563 forum posts 322 photos | A surplus scanner? |
DC31k | 23/02/2021 20:10:26 |
1186 forum posts 11 photos | There is a US site, firstsurfacemirror.com where they have an online calculator. I do not know if their products are suitable for your application so apologies in advance if this is misdirection. |
Robert Atkinson 2 | 23/02/2021 20:24:29 |
![]() 1891 forum posts 37 photos | I have some first surface mirrors that should suit. send me a PM. Robert G8RPI. (Cambridge UK) |
Dave S | 23/02/2021 21:28:12 |
433 forum posts 95 photos | You could try comar optics - comaroptics.com They list 25mm dia 1/4 wavelength for what seems a reasonable £36. We used them for custom optics when I worked in precision non contact metrology. Dave |
Clive Hartland | 23/02/2021 22:26:16 |
![]() 2929 forum posts 41 photos | Pete, if you are going to mount a surface mirror it needs adjustment in x and y planes. The ones I used had three adjusters. The mirror mount was mounted on 1 ball bearing and the adjustment screws held the mount onto the ball. The best were made from Titanium, solid, about 15mm thick. Not glass but polished up very well and of course flat. I surveyed a damaged ships engine bed after a con rod bent which from the survey ended up bent like a banana. I measured at 300mm intervals and drew it out and it had 230 Thou. droop at both ends and 180 thou in the middle. |
Pete Rimmer | 23/02/2021 23:55:47 |
1486 forum posts 105 photos | Thanks for the replies and suggestions. It's given me a lot to go on. Comar optics do a 63mm 1/10 mirror which would be ideal except it's £120 plus vat. I was hoping to avoid quite that much expense but if I don't find a suitable mirror for less I will have to stump up the cash for that. Pete.
Lainchy | 24/02/2021 07:05:48 |
![]() 273 forum posts 103 photos | Have a look at Orion optics in Crewe. |
Clive Hartland | 24/02/2021 07:57:55 |
![]() 2929 forum posts 41 photos | Pete, could you give us what application/use you have in mid for the collimation work. I have some experience in collimation etc.
Pete Rimmer | 24/02/2021 08:35:54 |
1486 forum posts 105 photos | Clive yes I am buying an autocollimator for checking surface plates and machine alignment. It will only be used over short distances so I can suffer a bit of error in the mirror. I've got a couple of plates that I need to renovate, one is quite bad the other quite good. I've got a lapping plate and I've made a repeat-o-meter and found this instrument, now I need a good mirror to use with it. |
John Baron | 24/02/2021 09:02:54 |
![]() 520 forum posts 194 photos | Posted by Pete Rimmer on 23/02/2021 17:13:13:
I put an advert on homeworkshop for an optically flat mirror but as yet have had no responses to it. These things seem to be thin on the ground and very expensive, if you buy the mounted ones. I'm looking for 'thinking out of the box' suggestions as to where I can find a decent fractional-wave first surface mirror to use as a reflector for an autocollimator I am picking up shortly. I can make the sled to carry it and I'm confident that I can make a mount but I need to first buy the mirror itself. I know that there are a few members interested in telescopy and other optical interests so I'm hoping that someone can suggest a source for a reasonably priced mirror. It must be flat, and first-surface, and fractional waveength, so half-wave or better. I'm not a tightwad but I don't want to pay newor crazy ebay prices. Hopefully there will be someone here can point me in the direction of a decent mirror or a device or instrument where they re used so I can look for a surplus one. Pete,. Hi Pete,
There are usually a number of different size first surface mirrors in a laser printer head unit !
Martin Connelly | 24/02/2021 09:17:30 |
![]() 2549 forum posts 235 photos | The disk in a scrap hard drive may be useable. If you have one to take apart the disk is aluminium so easily cut. Don't know how well it will work for your application but it may be a suitable stop gap until you get exactly what you want. Martin C |
Anthony Knights | 24/02/2021 09:21:21 |
681 forum posts 260 photos | Sheer speculation-how flat is a hard drive disk? |
Martin Kyte | 24/02/2021 10:19:14 |
![]() 3445 forum posts 62 photos | I've used this lot in the past for telescope optics. regards Martin |
Michael Gilligan | 24/02/2021 10:45:26 |
![]() 23121 forum posts 1360 photos | I’m sure you know all this, and more, Pete ... or you wouldn’t have started this thread But for general reference, there are some useful diagrams here: **LINK** https://www.taylor-hobson.com/-/media/ametektaylorhobson/files/product-downloads/autocollimators/autocollimators-en.pdf?dmc=1&la=en MichaelG. |
noel shelley | 24/02/2021 11:47:27 |
2308 forum posts 33 photos | Coventry gauge and tool at their Gt Yarmouth plant made optical measuring instruments that used mirrors that were polished at the plant back in the late 60s. They used the name Kandux and the machines were optical comparetors. The mirrors were quite a few inches in diameter - it might be worth looking for an old unit, as I expect most have gone now but the mirrors might have survived. I worked there. Noel. |
Dave S | 24/02/2021 12:16:37 |
433 forum posts 95 photos | Posted by Anthony Knights on 24/02/2021 09:21:21:
Sheer speculation-how flat is a hard drive disk? According to this **LINK** - lambda/100 or Very Very Flat might be a cheap alternative Dave
