Tufnol, Phenolic, SRBP, HPL, CGL, SGL
Hollowpoint14/02/2021 13:51:10
550 forum posts
77 photos
Guys I'm looking for some hard sheet material for use under a small lathe, I remembered back to some very hard plastics used in lab work surfaces and counter tops back in my school days which would be ideal.
Searching around the web it seems to come under many different names, HPL, CGL, SGL, SRBP, and Phenolic resin to name but a few.
I only need a small piece and was wondering if anyone knew of a supplier?
Failing that, does anyone know of an alternative? It needs to be tuff and hard wearing for my application. Tufnol might have been an option had it not been only available in brown.
Any suggestions?
Andy_G14/02/2021 14:03:55
260 forum posts
Lab worktops are often made of ‘Trespa’ - a trade name for some type of laminate. It’s horrendously expensive, but you may be able to buy an off cut. (It cuts & machines OK with TCT woodworking tools.)
noel shelley14/02/2021 14:10:11
2308 forum posts
33 photos
The thing that comes to mind is what I would know as formica. Noel.
Hollowpoint14/02/2021 14:16:56
550 forum posts
77 photos
Posted by Andy_G on 14/02/2021 14:03:55:
Yes,thats the stuff. And yes expensive! I was hoping someone knew where to get an offcut.
Jeff Dayman14/02/2021 14:59:12
2356 forum posts
47 photos
Steel sheet galvanised, plated or painted would be cheaper, have much longer life, and be much more robust than laminates etc. as well as being the traditional proven under-lathe material. However if you really want laminate/plastic I would give a +1 to Noel's suggestion of formica, as used in kitchen counters. A kitchen or bath fitter shop may have an offcut or a counter that was cut too short for less than all new custom cut material.
Bo'sun14/02/2021 15:07:51
754 forum posts
Hello Hollowpoint,
What about the material used for the base of small trailers (Ifor Williams, etc). It's a phenolic covered plywood. Unfortunately, I haven't got a clue what it's called.
Roderick Jenkins14/02/2021 15:35:26
2376 forum posts
800 photos
Posted by Bo'sun on 14/02/2021 15:07:51:
Hello Hollowpoint,
Buffalo Board and/or Hexagrip?
Rod
ega14/02/2021 15:37:11
2805 forum posts
219 photos
I know it simply as "phenolic-faced ply" but I suppose there may be a brand name.
AFAIK, Formica is a thin laminate ie not a board material as such.
Peter Cook 614/02/2021 15:53:50
462 forum posts
113 photos
Thin stainless sheet glued down on a piece of MDF. Thin stainless is available as cooker splashbacks or just as sheet.
noel shelley14/02/2021 16:02:26
2308 forum posts
33 photos
If stainless will do PM me. Noel
Hollowpoint14/02/2021 16:37:36
550 forum posts
77 photos
Thanks for the replies.
I have some stainless sheet (thanks anyway Noel) and have considered gluing a piece to some ply and I might yet go down that route.
My requirements though are quite specific. I have built a base from aluminium extrusion to house the motor and electrics for a small Cowells lathe, The board will sit in the top and be screwed up from the bottom. I want something durable and scratch resistant, I could use wood but I feel it will start to look tatty relatively quickly. Metal would be better, but will scratch. Hard plastic seems like a good compromise as it will do what I want while also having the benefit of insulating the electronics below.
Grindstone Cowboy14/02/2021 16:51:59
1160 forum posts
73 photos
Corian would be good if you could get an offcut from a kitchen/bathroom fitter.
Rob
Hollowpoint14/02/2021 17:01:12
550 forum posts
77 photos
Posted by Grindstone Cowboy on 14/02/2021 16:51:59:
Rob
Yes that might be an option. Thanks
Has anyone used SRBP? it seems to be quite cheap and plentiful on ebay.
Edited By Hollowpoint on 14/02/2021 17:06:02
Michael Gilligan14/02/2021 17:09:35
23121 forum posts
1360 photos
Posted by Hollowpoint on 14/02/2021 17:01:12:
But isn’t that typically Brown in colour ?
... as per the Tufnol products that you rejected
Hollowpoint14/02/2021 17:13:23
550 forum posts
77 photos
It seems to be available in black too. smiley
Michael Gilligan14/02/2021 17:17:20
23121 forum posts
1360 photos
Posted by Hollowpoint on 14/02/2021 17:13:23:
Then use it, and be happy yes
Edit: __ Possibly this : https://www.attwater.com/products/b4b
Edited By Michael Gilligan on 14/02/2021 17:21:51
Martin Dilly 214/02/2021 17:43:28
50 forum posts
7 photos
Hollow, I have an unused 6 ft length of white Formica kitchen work surface which you, or anyone else, are welcome to, f.o.c. I'm in the Bromley/Croydon area if that's any help.
larry phelan 114/02/2021 17:59:57
1346 forum posts
15 photos
I hate a workbench that has scratches on it ! Dont you ?cheeky
Hollowpoint14/02/2021 18:08:03
550 forum posts
77 photos
Posted by Martin Dilly 2 on 14/02/2021 17:43:28:
Thank you for the offer, very kind! but I'm in the Leeds area so a fair distance away and I've just ordered a piece of SRBP so will give that a go. yes
Hollowpoint14/02/2021 18:09:47
550 forum posts
77 photos
Posted by larry phelan 1 on 14/02/2021 17:59:57:
It's more of a box to be fair, haha. laughcheeky
