Vic | 11/02/2021 22:37:27 |
3453 forum posts 23 photos | Do any of you know what type of wire these are made from? I need something similar for a job. I’ve got some garden wire but it seems more flexible which isn’t what I want. It needs to be plated like the coat hangers. |
Pete. | 11/02/2021 22:55:41 |
![]() 910 forum posts 303 photos | I'd guess it's zinc plated steel rod, searching for rod rather than wire might assist your search. |
Bob Stevenson | 11/02/2021 23:03:20 |
579 forum posts 7 photos | The pendulum rod of my first clock is made of coat hanger,...the light grey/silver stuff and looks as good now as it did when first fitted. This would be about 8 or 9 years ago now. At the time coat hanger material was either dark brown/grey or this light coloured stuff. at the time I was told that there was a move over to stainless (the light grey stuff) as it was cleaner for the automated machines that fold up the hangers. I don't know how accurate this info actually is/was, but every time I look at that clock it does look like stainless steel to me......I threaded both ends and it certainly did not thread like a plated rod and both threads still look as new now.
......Hope this helps! Edited By Bob Stevenson on 11/02/2021 23:07:42 |
Pete. | 11/02/2021 23:04:00 |
![]() 910 forum posts 303 photos | If the plating is just for corrosion protection, you might find it easier to buy stainless rod, easily available in millimeter increments. |
Vic | 11/02/2021 23:17:38 |
3453 forum posts 23 photos | I think the brown stuff was actually lacquered. The silver stuff probably zinc plated. Stainless steel rod may be an alternative, thanks for the suggestion. |
Grindstone Cowboy | 11/02/2021 23:26:52 |
1160 forum posts 73 photos | Would the 3.15mm dia galvanised wire on this page be any good? No recommendation implied for that particular supplier, it just came up first in a search. Rob |
John Olsen | 12/02/2021 02:19:55 |
1294 forum posts 108 photos 1 articles | What about Piano wire, as used to be sold by model aircraft shops for making undercarriages etc. The stuff I used to get was zinc plated and in a reasonably high state of temper. You could bend it but not easily. I don't know what current availability is like. It came in a range of sizes in SWG. John
Paul Lousick | 12/02/2021 05:29:16 |
2276 forum posts 801 photos | Look for high tensile galvanized or zinc plated wire. Sould be available from a decent hardware store or available online. (even at that auction site that some people are afraid to say. aka: ebay) Or suppliers that sell fencing wire. Paul
James Alford | 12/02/2021 07:20:07 |
501 forum posts 88 photos | Knitting needles, depending upon length needed? They come in all sorts of sizes, are rigid and have do not seem to be affected by a damp atmosphere. I have a tub of them which I use as picks and "things". I bought a large bundle from the charity shop for next to nothing. Obviously, these are currently shut, but e-bay or Gumtree might have some. Regards, James. |
Robin | 12/02/2021 10:48:05 |
![]() 678 forum posts | Most excellent. I just bought 5kg of galvanised 3mm fencing wire for £24 with free shipping off that auction site I need about a foot but I am sure the other 4.99kg will eventually come in handy. Being galvanised it can live in the shed. Her coat hangers are safe at last. |
BOB BLACKSHAW | 12/02/2021 10:57:26 |
501 forum posts 132 photos | Would cycle wheel spokes be any good, you could get plated ones at one time, or find a old wheel. Bob |
Howard Lewis | 12/02/2021 11:13:09 |
7227 forum posts 21 photos | If you want to bend it, knitting needles are sometimes quite brittle. Don't ask! Howard |
ega | 12/02/2021 12:16:03 |
2805 forum posts 219 photos | Posted by BOB BLACKSHAW on 12/02/2021 10:57:26:
Would cycle wheel spokes be any good, you could get plated ones at one time, or find a old wheel. Bob They can be re-purposed in a number of ways: I have seen them used to deter cats from getting over a garden wall. I doubt if they can be had in the same diameter as coat hangers, however, and they are often butted ie of reduced diameter in the middle. |
Vic | 12/02/2021 12:34:11 |
3453 forum posts 23 photos | Posted by Grindstone Cowboy on 11/02/2021 23:26:52:
Would the 3.15mm dia galvanised wire on this page be any good? No recommendation implied for that particular supplier, it just came up first in a search. Rob Thanks for that Rob, it may do. Rather more than I need but I suppose it will get used. Thanks for the find. |
Vic | 12/02/2021 13:40:39 |
3453 forum posts 23 photos | Following Pete’s suggestion I’ve been looking at some stainless rod on eBay. What’s the easiest to bend though? Most of the stuff on there seem to be 303, 304 or 316. Or should I be looking at 400 series. Corrosion resistance isn’t an issue. |
Tim Stevens | 12/02/2021 14:02:08 |
![]() 1779 forum posts 1 photos | The bendability is much more dependent, I suggest, on the way in which the stainless has been treated. It might be hard drawn, or annealed, or anything in between. I doubt if the suppliers (*bay or otherwise) will have a clue about this. And of course, the finer the gauge the easier the bending. For sure, though, threading is less joyful with stainless, but it won't break when you try to bend it, even hard drawn. So, perhaps make a small loop and put a bolt through? Cheers, Tim Edited By Tim Stevens on 12/02/2021 14:04:52 |
Michael Gilligan | 12/02/2021 19:49:50 |
![]() 23121 forum posts 1360 photos | These are black, so presumably not plated, but they are very reasonably priced and get good reviews from ‘hackers’ https://www.dunelm.com/product/set-of-10-wire-hangers-1000008160 MichaelG.
