Boring head or fly cutter
Eric Cox11/02/2021 10:10:56
557 forum posts
38 photos
I have a small amount of machining to do that requires fly cutting. Would you use a boring head which I have or get a fly cutter.
Michael Gilligan11/02/2021 10:19:43
23121 forum posts
1360 photos
If there is room to use the boring head, and it will come to no harm ... then there is no need for a dedicated fly cutter.
As Liverpudlian friends used to say:
You can use a Rolls Royce to kill a pig.
larry phelan 111/02/2021 11:44:09
1346 forum posts
15 photos
Very well put ! You have a great way with words.
I must remember that for future use.cheeky
Emgee11/02/2021 12:21:40
2610 forum posts
312 photos
Eric
Much fly cutting involves interrupted cuts which will put more load on the boring head than straightforward boring so if you do use the boring head best to tighten all setting and adjusting screws as well as keeping DOC and speed to a level that the head copes with.
You don't say what machine you will use or which material you will be cutting but that information would be useful to advise on spindle speed, DOC and traversing feedrate.
Emgee
not done it yet11/02/2021 13:02:18
7517 forum posts
20 photos
Probably not. The liverpudlians would likely be using the word ‘pig’ as a metaphor.🙂
Eric Cox12/02/2021 10:34:18
557 forum posts
38 photos
The machine is a Warco WM14 cutting mild steel 2" wide by 4" long
Howard Lewis12/02/2021 12:37:54
7227 forum posts
21 photos
Out of kindness to the Boring head, I would feel inclined to make or buy a Flycutter. It will always "Come in handy, one day" for other jobs.
And is likely to be more rigid than a boring head, when subjected to interrupted cuts.
MIke Cox published a design, in MEW, for a Flycutter on the principle of the Tangential Turning Tool.
Although mine differs slightly from his design, it functions quite well!
mechman4812/02/2021 13:20:11
2947 forum posts
468 photos
I am fortunate that I have one of each, fly cutter, boring head, & a 60mm face ( 4 insert  cutter so I have a choice. For the size you mention I would use my insert face cutter first followed by the fly cutter, & lastly the boring head ( as emgee's reasoning .
George.
John Baron12/02/2021 13:56:55
520 forum posts
194 photos
Hi Eric, Guys,
You can make a fly cutter quite easily and more rigid than most you could buy.
This one is a simple disc 20 mm thick on a 20 mm shaft, using a piece of 6 X 6 mm square HSS as the cutter. This on will cover about 65 mm. The tool bit is held in an 8 mm diameter hole using an M6 grub screw.
