Nick Clarke 3 | 03/02/2021 14:29:05 |
![]() 1607 forum posts 69 photos | I am setting about insulating the metal up and over door to my garage/workshop I have some 25mm foam insulation sheet, not the foil covered type, and intend sticking it to the inside of the door. What do you suggest will be the most successful as anything with a solvent is likely to attach the foam - perhaps high viscosity PVA like NoMoreNails or Silicon sealant/adhesive? |
Ady1 | 03/02/2021 14:32:26 |
![]() 6137 forum posts 893 photos | pinkgrip |
Nick Clarke 3 | 03/02/2021 14:39:46 |
![]() 1607 forum posts 69 photos | Posted by Ady1 on 03/02/2021 14:32:26:
pinkgrip Isn't that solvent based though and likely to attack the foam? |
Clive Brown 1 | 03/02/2021 14:45:42 |
1050 forum posts 56 photos | I've used contact adhesive for foam backed vinyl. An aerosol spray-can is very easy and convenient for applying adhesive onto the foam and the normal liquid adhesive applied to the solid surface. |
Tony Pratt 1 | 03/02/2021 14:49:05 |
2319 forum posts 13 photos | Contact adhesive or non solvent 'grab' adhesive. Dead light so nothing fancy needed. Tony |
JasonB | 03/02/2021 14:56:30 |
![]() 25215 forum posts 3105 photos 1 articles | Everbuild do one called "Dry Fix FR" made for sticking insulation to walls etc. |
Bazyle | 03/02/2021 17:44:56 |
![]() 6956 forum posts 229 photos | "foam insulation sheet" is a bit too vague. One such might be expanded polystyrene which is going to be rather different in its susceptibility compared to polyurothane or some other types. Edited By Bazyle on 03/02/2021 17:45:47 |
Nick Clarke 3 | 03/02/2021 20:44:15 |
![]() 1607 forum posts 69 photos | Posted by Bazyle on 03/02/2021 17:44:56:
"foam insulation sheet" is a bit too vague. One such might be expanded polystyrene which is going to be rather different in its susceptibility compared to polyurothane or some other types. Edited By Bazyle on 03/02/2021 17:45:47 It is expanded polystyrene - this stuff **LINK** Thanks Nick |
Bazyle | 03/02/2021 22:06:56 |
![]() 6956 forum posts 229 photos | I think there is a special 'foam in a can' for eps specifically. Have a look at all the ones available on teh Screwfix website. |
Fowlers Fury | 03/02/2021 22:10:57 |
![]() 446 forum posts 88 photos | Nick, not sure I'd want to use expanded polystyrene in a garage/workshop location even when the EPS contains fire retardant. Have you had a look at Kay Metzeler's safety data sheet?
Some years ago, I went for this product to insulate the inside of steel garage doors:- https://www.weatherstop.co.uk/collections/garage-door-insulation Very effective, it seems to be polyethylene "bubble sheet" inside a double layer of aluminium foil.
Peter Jones 20 | 03/02/2021 22:20:55 |
![]() 63 forum posts 9 photos | As with everything nowadays, there is far more to learn than you ever wanted . Interesting topic though. I'm going to use paintable expanding foam in a can to cut down the rattling from belt cover on mill/drill |
Bazyle | 03/02/2021 22:48:53 |
![]() 6956 forum posts 229 photos | this might work but I've not used it myself |
JasonB | 04/02/2021 07:05:49 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Bazyle on 03/02/2021 22:06:56:
I think there is a special 'foam in a can' for eps specifically. Have a look at all the ones available on the Screwfix website. That's the one I mentioned earlier works with PU and EPS boards etc. details Edited By JasonB on 04/02/2021 07:06:25 |
David George 1 | 04/02/2021 09:19:36 |
![]() 2110 forum posts 565 photos | Have you bought the insulation yet as the weight of thick insulation may make the door very heavy and the spring actuator may not work. I did something similar and found thicker insulation very wealdy to fasten to the door and too heavy. I bought some 12mm foil backed insulation and found that it slides into the framework supports on the inside of the door and other than a few bits of foil tape no adhesive used. The insulation value is more than adequate and the worksop is loads warmer and I can open the door! David |
An Other | 04/02/2021 09:22:29 |
327 forum posts 1 photos | I did this to the inside of my garage door years ago - I used to condensation on the inside (steel door), and I had some spare 25mm foam, so I just stuck it to the inside of the door using the spray on foam builders adhesive mentioned above by Jason - works fine. |
Tony Pratt 1 | 04/02/2021 10:21:05 |
2319 forum posts 13 photos | I used 25 mm thick foam on the garage door & it worked fine but you have to watch the weight & adjust the springs to compensate. Tony |
Dave Halford | 04/02/2021 13:04:16 |
2536 forum posts 24 photos | You can simply test EPF for fire yourself, break a bit off and try to burn it, take the flame away and it should go out. |
mgnbuk | 06/02/2021 14:12:16 |
1394 forum posts 103 photos | Aldi locally (Huddersfield) currently have this insulation wrap on offer, which is quite lightweight & inexpensive (£9 for 4.5 square meters). A couple of rolls found their way into my trolley yesterday, so I'll see how effective the stuff is on steel up-and-over garage doors in due course. I'll use PU adhesive from Toolstation "dot & dab" style to attach it & hope it never needs to come off ! Nigel B. |
