Greensands | 20/01/2021 12:10:34 |
449 forum posts 72 photos | Hi - I am thinking about buying a Silverline 1/4" straight extended long reach die angle grinder/cut-off tool for mounting onto the Top/Crosslide of a Myford 7 lathe. Before paying a visit to that well known auction site for the purhase has anyone had the experience of using the tool this application? The long reach of the tool would appear to make it quite suitable for achieving a secure fixing. |
noel shelley | 20/01/2021 12:22:36 |
2308 forum posts 33 photos | Having had good and cheap air tools, all I would say is you get what you pay for. They will have revs but may not have much grunt. What purpose do you intend to put it too ? Noel |
Greensands | 20/01/2021 12:31:07 |
449 forum posts 72 photos | Typical use would be light spotting/drilling/grinding applications |
noel shelley | 20/01/2021 13:02:46 |
2308 forum posts 33 photos | You may struggle with grinding, except very light cuts. You will need a good air supply. |
Nick Wheeler | 20/01/2021 13:20:05 |
1227 forum posts 101 photos | Posted by Greensands on 20/01/2021 12:31:07:
Typical use would be light spotting/drilling/grinding applications Air tools are horrible. Then you turn them on and they get worse.
This works well for what you mentioned, and I also use it for milling fluted knobs:
ER11 collets, drops onto the QCTP just like any other tool, and adjustable speed via the power supply. Cost about £80 all in from Ebay. I already had the 10mm square bar to mount it to the tool holder. |
mike T | 20/01/2021 14:18:07 |
221 forum posts 1 photos | What wattage and voltage is required for a "good" spindle drive? Would 300watts be enough to do more than just light spotting and drilling? Mike |
Dave Halford | 20/01/2021 15:18:42 |
2536 forum posts 24 photos | I have a Sealey cut off - hopeless thing that sprays oil everywhere and stalls as soon as look at you. |
not done it yet | 20/01/2021 15:43:36 |
7517 forum posts 20 photos | Posted by noel shelley on 20/01/2021 13:02:46:
You may struggle with grinding, except very light cuts. You will need a good air supply. First question might be: What capacity is your compressor (or what was it when new). That is free air delivery, not capacity by displacement, and pressure rating. Next: Is this a 4 bar rated tool? No experience with this offering, but as above, Electric, variable speed with slower speeds (for use with a larger diameter blade) would be my choice. Edited By not done it yet on 20/01/2021 15:44:28 |
James Alford | 20/01/2021 21:32:01 |
501 forum posts 88 photos | Leaving aside how well either will work as planned, I have used both a cheap Silverline die grinder and a comparably priced US Pro tool. I found the US Pro die grinder was much more effective, needing less air, but still having plenty of power. A friend uses the US Pro die grinders in his business restoring cars and finds them to last well. Regards, James. |
Martin King 2 | 20/01/2021 21:37:43 |
![]() 1129 forum posts 1 photos | Nicholas, any chance of some supply links for the items on your grinder, power supply, motor spindle etc? pm me if links will not be allowed regards, martin |
Nick Wheeler | 21/01/2021 08:53:15 |
1227 forum posts 101 photos | Posted by Martin King 2 on 20/01/2021 21:37:43:
I bought them off Ebay about 4 years ago, so a link won't help you much. A search for ER spindle motor will soon find what you need. I bought the motor, clamp, power supply and collets as a set, which comes to about £120 now. A length of 10mm square screwed to the motor clamp to fit a tool holder will have the the motor in use in a few minutes. |
David George 1 | 21/01/2021 08:53:52 |
![]() 2110 forum posts 565 photos | I used a high speed spindle it comes with a collet set built in and power supply with speed controle. https://youtu.be/2VKR45MYVEw I only had to make a bracket to hold spindle and enclosure for power supply etc. David |
old mart | 21/01/2021 15:05:32 |
4655 forum posts 304 photos | I bought one of the Silverline extended nose air die grinders and have been very pleased with it. I believe the extended shank is 3/4" diameter, just a little bit bigger than the chuck at the end. It comes with 1/4" ans 1/8" collets and I have just got 6mm and 3mm collets through the post today. |
Nick Clarke 3 | 21/01/2021 15:37:35 |
![]() 1607 forum posts 69 photos | Posted by old mart on 21/01/2021 15:05:32:
I bought one of the Silverline extended nose air die grinders and have been very pleased with it. I believe the extended shank is 3/4" diameter, just a little bit bigger than the chuck at the end. It comes with 1/4" ans 1/8" collets and I have just got 6mm and 3mm collets through the post today. Where did you obtain the extra collets from? Thanks, Nick |
old mart | 21/01/2021 16:14:14 |
4655 forum posts 304 photos | The 6 and 3mm collets came from ebay, they look alright and the bores are ground and they were very cheap. |
