geoff adams | 05/12/2020 14:53:08 |
214 forum posts 207 photos | Hi all where to you guys get your metal cutting blades from i have a clarke 6" saw looking for a general purpose blade last two i bought first one broke first time used on the weld the replacement has now lost teeth and not cutting square very little use first blade i got from this company lasted well over a year any recommendations welcome Geoff |
Jim Nic | 05/12/2020 15:13:49 |
![]() 406 forum posts 235 photos | Tuffsaws! (www.tuffsaws.co.uk) I can't recommend them highly enough for the service the proprieter offers. Their products are good quality at reasonable prices. Jim |
David George 1 | 05/12/2020 15:37:16 |
![]() 2110 forum posts 565 photos | One more for Tuffsaws. I bought three blades last year an extra fine tooth and 2 standard tooth and the first standard one is still like new with plenty of use. David |
SillyOldDuffer | 05/12/2020 15:41:34 |
10668 forum posts 2415 photos | I bought my last from Warco, a few years ago and still going strong. I lashed out and bought a bi-metallic. The carbon steel blade that came with my saw worked well enough to prove the machine cut metal, but didn't last long. Probably about as cheap as possible to prove the saw worked out of the box, but not much longer! It broke at the weld and lost teeth like yours. My band-saw was by far the worst of my Chinese tools, pretty crude throughout. It ticked when the blade weld went over the drive wheel, and cut sideways. However, filing off a tiny casting ridge on the drive wheel and tweaking the tracking made it cut straight without breaking the weld. The other important change was the casting didn't quite allow enough room for the tension adjuster to fully relax, putting a fair amount of stress on blades during installation. Filing a couple of millimetres off the casting fixed that too. My favourite tool now - not because it's beautifully made, but because it works and saves so much time. Can't remember the last time it needed attention. Dave |
Bo'sun | 05/12/2020 15:55:57 |
754 forum posts 2 photos | Also, some excellent info' on the Tuffsaws website when it come to choosing blades. |
larry phelan 1 | 05/12/2020 16:39:54 |
1346 forum posts 15 photos | I bought my Chinese bandsaw from Chester, many moons ago, never had any real problems with it, and I use it quite a lot. The fact is that the machine is only as good as the blade, either bench saw or bandsaw, wood or metal. Bad or cheap blades are a waste of both time and money. Good quality sawblades for the bench saw and likewise for the bandsaw are cheaper in the long run and perform better too. So, go for Bimetal blades. Just my experience !. |
Dalboy | 05/12/2020 16:46:45 |
![]() 1009 forum posts 305 photos | I have only ever brought mine from Tuffsaws. Great service and always will give advice if not sure what blade to get. Good quality blades |
Emgee | 05/12/2020 17:17:51 |
2610 forum posts 312 photos | Seems like Tuffsaws is well used by forum members, I have also used their blades and been very satisfied with their performance. Emgee |
ega | 05/12/2020 17:19:52 |
2805 forum posts 219 photos | Posted by Emgee on 05/12/2020 17:17:51:
Seems like Tuffsaws is well used by forum members, I have also used their blades and been very satisfied with their performance. Emgee Joining in the chorus: I believe they will fix any blade that breaks at the weld; none of mine ever have. |
Oily Rag | 05/12/2020 17:19:59 |
![]() 550 forum posts 190 photos | I always go for a branded quality blade, such as a Starrett bi metal (M42) and choose the combination tooth type (14/18 or 6/10). I get mine from J and L in Wednesbury (now taken over by MSC). Cheap blades are a waste of time and money. |
Joe Metcalfe 1 | 05/12/2020 17:48:02 |
7 forum posts | I have used Lenox Diemaster blades from MSC for many years. Made in USA, expensive but worth it. |
peter smith 5 | 05/12/2020 18:14:17 |
93 forum posts | North LondonSaws. NLS Tools in Waltham Cross. Cut and welded to your spec and only buy bi metal blades unless you are cutting cardboard. pete |
geoff adams | 06/12/2020 08:25:28 |
214 forum posts 207 photos | thanks all for the advice looks Tuffsaw is the one to go for will order one today many thanks Geoff |
Ady1 | 06/12/2020 09:14:38 |
![]() 6137 forum posts 893 photos | lol, tuffsaws has gone offline because of increased traffic volume, probbly with these aldi and lidl units The power of the internet eh |
