William Chitham | 06/11/2020 14:55:02 |
156 forum posts 56 photos | My brother in law has kindly given me this die set which was part of his father's tool collection. Metric sizes from 3mm to 12mm (including odd ones 7mm & 9mm) marked "RA" but no other identifier, I've never seen one like it before. Is it a common type? Operation seems self explanatory but is there anything to watch ou for? Thanks, William. |
Clive Brown 1 | 06/11/2020 15:02:22 |
1050 forum posts 56 photos | I've seen sets like that dating back to the 1960s, possibly earlier, pre-dating UK metric changer-over. From what I remember, they could be good quality products. Can't help with the RA though. |
Brian H | 06/11/2020 15:03:45 |
![]() 2312 forum posts 112 photos | Never seen a metric one but Whit and BSF ones are not rare though usually found without the extra sets of dies. Brian |
Bo'sun | 06/11/2020 15:11:03 |
754 forum posts 2 photos | Presumably, round one piece dies are cheaper to make, but I do like the idea of two halves for cleaning. |
Robert Butler | 06/11/2020 16:03:03 |
511 forum posts 6 photos | I have a Whitworth BSF set in a box which was marked WD although the contents are not so marked. Pretty much rust free. Robert Butler |
William Chitham | 06/11/2020 16:24:53 |
156 forum posts 56 photos | Perhaps this set belonged to the Gunners. |
old mart | 06/11/2020 16:50:57 |
4655 forum posts 304 photos | I would expect a broad arrow on it if it had ever been in the military. |
Robert Butler | 06/11/2020 16:59:32 |
511 forum posts 6 photos | The box which was falling to pieces certainly had the broad arrow marking but there is no marking on the two diestock holders or the split dies. The set belonged to my late uncle and as the box was falling apart I re-glued the finger joints on the box frame and replaced the ply wood top and bottom. The interior has cut outs which were salvageable and match the diestocks, (one large and one small) the split dies and the taps. From memory there is one tap missing. Robert Butler |
Clive Foster | 06/11/2020 17:13:00 |
3630 forum posts 128 photos | Such die and stock sets go back a very long time. Allegedly the Whitworth and BSP ones I ended up with via complex family inheritance route date back to before WW1. Something I have no way of proving but they are certainly early inter-war period at the latest. My stocks hold all the dies in a set at once. Just release the clamp screw and ease the desired set apart to use. Nearly impossible to loose a die half as fiddling them out once the screw has been fully undone is tricky with about 10 thou clearance to work with. Mine also have a 55° Vee roller and plain half "die" section to clean out threads. Not a universal fitting. Allegedly on gas fitters and the like sets. Big problem with this form of die set is that there is no easy way to set to the correct size. The split sections are narrow enough to easily close up to well below the official core diameter. I suspect the correct method is to close them up on a rod of core diameter to set the spacing. Clive |
William Chitham | 06/11/2020 17:53:41 |
156 forum posts 56 photos | Posted by Clive Foster on 06/11/2020 17:13:00:
Big problem with this form of die set is that there is no easy way to set to the correct size. The split sections are narrow enough to easily close up to well below the official core diameter. I suspect the correct method is to close them up on a rod of core diameter to set the spacing. Clive Or maybe on a sample piece of thread? I'll try it out this weekend. William. |
Robert Butler | 06/11/2020 18:05:10 |
511 forum posts 6 photos | William, I'm not sure you are correct, assuming you are thread cutting on a rod of the correct diameter surely the crests and troughs of the die limit the depth of cut and presumably it is possible to judge a tight or loose thread with an appropriate female thread (nut). Robert Butler |
Oily Rag | 06/11/2020 18:16:43 |
![]() 550 forum posts 190 photos | These sets were in use from the early 1900's - if it is pre WWII then the metric set will be SI not ISO. As Brian H mentioned I have never seen a Metric set - my father passed his down to me many years ago, from memory that came from the COW (Coventry Ordnance Works, Red Lane) in about 1920. RA could be the makers mark?? Ransome & Allsop anyone? |
Sandgrounder | 06/11/2020 19:15:21 |
256 forum posts 6 photos | One good thing these can do which the usual die can't is to start off in the middle of a thread, if you have a bolt or stud which has the first threads damaged you can start the die off below the damaged section and work backwards. John |
BOB BLACKSHAW | 07/11/2020 09:33:34 |
501 forum posts 132 photos | I have a workshop book from the early 1900s showing a similar stock and dies. |
ega | 07/11/2020 11:09:23 |
2805 forum posts 219 photos | My 1933 Brown Brothers catalogue shows a British made combined Whit and BSF set of these plus taps at £9 4s 6d. And in Buck & Hickman's 1964 when the comparable price had risen to £20. Edited By ega on 07/11/2020 11:20:49 |
Samsaranda | 07/11/2020 11:24:19 |
![]() 1688 forum posts 16 photos | In respect whether of military provenance then each individual item would have had a broad arrow, after 22 years of military service using tools they all had the broad arrow on, the government were obsessively protective of “Crown Property”. |
Dalboy | 07/11/2020 12:53:08 |
![]() 1009 forum posts 305 photos | I have a similar set of split dies but not in metric as can be seen the name Warrior. The holder as can be seen is of a round design rather than the square one you have.
Terry B | 07/11/2020 14:20:30 |
22 forum posts 5 photos |
This set was given to me by a friend before he went abroad about 15 years ago. As you cab see by the label it was made by a firm called Stronghold. The smaller print at the bottom states that it was made by "The British Tap and Die Company, England" Has anybody any idea of it's age? |
ega | 07/11/2020 14:52:43 |
2805 forum posts 219 photos | Terry B: I assume that the blue fitting is used in conjunction with a carpenter's brace but how, exactly? Not clear to me how the split dies are adjusted in the circular holder? |
Brian H | 07/11/2020 15:23:58 |
![]() 2312 forum posts 112 photos | I bought this set some years ago. I don't really have a use for it but found it unusual. It is of US manufacture and operates in a similar manner to a Coventry die head. The lever on top moves the four dies in and out to adjust the cut and there is a lever and graduated plate on the side so that fine adjustments can be made. The taps are not original, I have filled the spaces with American made ones where possible. Despite its American origin it is Whitworth. Brian |
