Roger Harvey | 03/10/2020 19:17:18 |
9 forum posts | Can anyone steer me in the right direction where i can find details and drawings for Martin Cleeve's Swing Clear Retracting Toolholder. There are plenty of pictures of this but I cannot find where it was published. I have the Model Engineer magazine issues where he describes his original non-retracting version. Regards All,
Wychwar |
John Haine | 03/10/2020 20:30:18 |
5563 forum posts 322 photos | I think it's in his little book "Screwcutting in the lathe". I'll check next time I'm in the workshop. |
Michael Gilligan | 03/10/2020 20:45:49 |
![]() 23121 forum posts 1360 photos | Try here, Roger ... I re-posted the link earlier today https://www.model-engineer.co.uk/forums/postings.asp?th=168193&p=2 MichaelG. |
herbert punter | 03/10/2020 21:13:59 |
128 forum posts 1 photos | Roger, Hemingway do kits and drawings for the retracting toolholder and it’s definitely in ‘Screwcutting In The Lathe’ Bert
Edited By herbert punter on 03/10/2020 21:15:54 |
Michael Gilligan | 03/10/2020 21:19:43 |
![]() 23121 forum posts 1360 photos | That’s the Geo. H. Thomas one isn’t it, Bert ? MichaelG. |
DC31k | 03/10/2020 21:35:20 |
1186 forum posts 11 photos | Posted by Michael Gilligan on 03/10/2020 20:45:49:
Try here, Roger ... I re-posted the link earlier today https://www.model-engineer.co.uk/forums/postings.asp?th=168193&p=2 MichaelG. This is another old post of yours linking to his patent: https://www.model-engineer.co.uk/forums/postings.asp?th=139985
Clive Foster | 03/10/2020 22:41:22 |
3630 forum posts 128 photos | Yep. Geo. H. Thomas did the Retracting Toolholder. Martin Cleeve did the Swing Clear one. Tubal Cain did a stop system for Myfords, probably adaptable to others, that limited retraction via the cross slide handle giving essentially the same result. SouthBends, and maybe Boxfords, along with some others are equipped to take a threading stop clamping to the cross slide ways setting both retraction via the handle and, somewhat crudely, threading depth. They all get you to the same place in practice. I decided to do without extra bits and learned the zero-2-zero method. For some folk one considerable restriction of Martins original Swing Clear tool holder is that it completely replaces the normal tool post. Not compatible with four way blocks or QC systems although it can be revised to fit at the cost of considerable extra overhang. It would work well as part of the quick change (two slot?) block system I've been known to advocate. Martin made his living with a seriously modified and upgunned Myford so threading and other jobs needing the swing clear holder were batch processes with many parts to do. Switching toolposts was of little consequence. But if you only have one or two threads to do .... I have just finished a batch of 6 threaded parts needing 5 tools for each. The swing clear would have been totally impractical for that job. Clive |
Ady1 | 04/10/2020 00:47:41 |
![]() 6137 forum posts 893 photos | Best one I ever saw didn't even need retracting he reversed his lathe and it lifted the tool up back to the start... stop the lathe... and it dropped back into the same start position ...clever |
John Hinkley | 04/10/2020 09:17:16 |
![]() 1545 forum posts 484 photos | Ady1, When I got my first mill, several years ago, I made one of these from Mike Cox's design,as an exercise in milling. I don't think I ever used it in anger, but it still sits on the shelf above the lathe, waiting to pounce on some unsuspecting piece of stock. John
Cornish Jack | 04/10/2020 10:13:47 |
1228 forum posts 172 photos | I have a pair of swing-up holders (one in use) purchased secondhand, and a bit 'agricultural'. Very handy for allowing easy dimension checks and resetting centre height for different tool sizes. John 'bog-standard' made an example of the self-retracting holder on another forum and seemed very enthusiastic. rgds Bill |
John MC | 04/10/2020 12:11:25 |
![]() 464 forum posts 72 photos | Any videos of the Martin Cleeve tool holder in action? John |
Nicholas Farr | 04/10/2020 13:07:23 |
![]() 3988 forum posts 1799 photos | Posted by Ady1 on 04/10/2020 00:47:41:
Best one I ever saw didn't even need retracting he reversed his lathe and it lifted the tool up back to the start... stop the lathe... and it dropped back into the same start position ...clever Hi Ady1, might this be the one you mean Flip up threading tool Regards Nick. |
Graham Meek | 04/10/2020 13:22:20 |
714 forum posts 414 photos | I remember assisting Dr John Beddard with some technical details of the Prototype for Hemingway's on the Martin Cleeve Retracting Tool Holder. I know this was after Neil Hemingway sold the business, someone Lyons springs to mind. John may have even written it up for SMEE at the time. The Toolholder was listed with Hemingway's, as I remember the photographs that were used which were taken by John. I also seem to recall some 3D views of this somewhere, may-be the front cover of Martin's book. The basic mode of operation was an eccentric in the tool block which initially retracted the tool. I cannot remember if the handle would also swing the tool clear, or if this was a separate manual operation. Regards Gray, |
Michael Gilligan | 04/10/2020 13:59:53 |
![]() 23121 forum posts 1360 photos | This appears to be Hemingway’s current version: **LINK** http://www.hemingwaykits.com/acatalog/Retracting_Tool_Holder.html ... Which is quite unlike Cleeve’s ‘Swing Clear’ Did they also do that one ^^^ ? MichaelG.
ega | 04/10/2020 14:10:57 |
2805 forum posts 219 photos | Posted by Michael Gilligan on 04/10/2020 13:59:53:
Yes, but machined from solid rather than fabricated in the MC way. |
Howard Lewis | 04/10/2020 14:26:17 |
7227 forum posts 21 photos | My Hemingway kit version (of the Martin Cleeve ) retracts the tool, and lifts as it retracts. If I forget to retract the tool, when the lathe is reversed, the tool is swung up so that it does not cut. Howard Edited By Howard Lewis on 04/10/2020 14:26:50 |
Michael Gilligan | 04/10/2020 14:28:27 |
![]() 23121 forum posts 1360 photos | Posted by ega on 04/10/2020 14:10:57:
[…] Did they also do that one ^^^ ? MichaelG.
Yes, but machined from solid rather than fabricated in the MC way. . Thanks for that ... I was not aware http://www.hemingwaykits.com/cgi-bin/sh000029.pl?REFPAGE=http%3a%2f%2fwww%2ehemingwaykits%2ecom%2facatalog%2fRetracting_Tool_Holder%2ehtml&WD=swing&PN=Swing_Tool_Post%2ehtml%23aHK_201630#aHK_201630 |
Circlip | 05/10/2020 10:38:52 |
1723 forum posts | Nearly sure "Marlco" had a version of the swing up on the market. Regards Ian. |
