Vic | 25/08/2020 17:22:43 |
3453 forum posts 23 photos | I was only thinking the other day it would be nice to be able to put identical chamfers on all corners of an object. Sadly I don’t have either a surface grinder or a mag chuck but I may be able to come up with something for stuff I do have?! |
John Haine | 25/08/2020 17:26:00 |
5563 forum posts 322 photos | You can do it with a countersink used as a milling cutter, by accurate measurement. I'be done it by CNC but should be possible on a manual mill especially if you have DROs. |
old mart | 25/08/2020 17:58:19 |
4655 forum posts 304 photos | I do it by eye, but it is very difficult to get them identical. |
jimmy b | 25/08/2020 18:11:33 |
![]() 857 forum posts 45 photos | I spent a few weeks of my apprenticeship chamfering gear plates on a grinder that did just that! the plates were offered up from above. Quite boring and too easy to chamfer the edge that didn't doing! Jim |
DC31k | 25/08/2020 19:26:26 |
1186 forum posts 11 photos | 1/4" woodworking router and a bearing-guided bit. Sleeve bearing OD to adjust width; use router's height adjustment for depth. |
Neil Wyatt | 25/08/2020 19:54:45 |
![]() 19226 forum posts 749 photos 86 articles | I'm thinking a jig made out of a bit of angle iron with a slot cut in it, set across a grinding wheel so any metal slid along the vee gets ground down by the same amount. Neil |
Mike Poole | 25/08/2020 19:58:42 |
![]() 3676 forum posts 82 photos | Stefan Gotteswinter also felt the need and created this. **LINK** Mike |
Vic | 25/08/2020 23:51:02 |
3453 forum posts 23 photos | Another method a little past half way of this video using a belt sander. |
jimmy b | 26/08/2020 05:09:48 |
![]() 857 forum posts 45 photos | This is a (very small) modern version of the machine I worked all those years ago. This one uses milling cutters, not a grind stone, but the principle is easy to see. Jim Edited By jimmy b on 26/08/2020 05:11:13 |
colin brannigan | 26/08/2020 08:26:51 |
125 forum posts 29 photos | Put the block in the vice, place a good quality countersink in the collet, my rear vice jaw is always set Y zero as is right hand side vice stop X zero, set the depth of cut and lock it, set Y to give required cut when happy make note of reading say +3 then go round each face adding 3 to each block dimension + or - and you end up with four chamfers all same size, turn block over repeat you now have eight. It may sound long winded but when you have a lot of tooling to chamfer you want them to look the same otherwise it's a pigs ear, same can be done with rads. Colin |
Clive Foster | 26/08/2020 09:49:18 |
3630 forum posts 128 photos | That Assflag machine in Jims link looks interesting but I think one of their other machines is more inspirational. The type AF165 **LINK** . Take one of the cheap "disk on a motor" sanding devices, like the LiDL £30 one I got on a whim, and get creative with an adjustable angle mount rather than the fixed pedestal and it could do a variety of other jobs. Especially if you have alternative tables / holders. Lathe tools being the obvious one as a poor boys Tiplap. Which was the plan for my LiDL device. Drill sharpening and touching up milling cutters ought to be easy enough with appropriate cutter carriers. Bound to be something that can be modified and repurposed in the back numbers! Clive |
Hopper | 26/08/2020 10:20:25 |
![]() 7881 forum posts 397 photos | Cool gadget and a godsend if you are a commercial machine shop churning out lots of work with lots of edges to chamfer. But for my (admittedly snail's pace) output, a 10" flat millsaw file will do all the chamfers I need, with job held in the vice to allow a nice chamfer filed on one edge at a time. It takes more time but I have plenty of that these days. |
Dusty | 26/08/2020 10:42:26 |
498 forum posts 9 photos | Yes, what's wrong with a file? As an apprentice toolmaker I was taught to file chamfers on tools, you soon learnt to make them identical or incur the Foreman's wrath or worse still if it was a part for one of the toolmakers. 60 yrs on I can still file chamfers probably quicker than it takes to set a machine up to do them. |
I.M. OUTAHERE | 26/08/2020 13:35:04 |
1468 forum posts 3 photos | Posted by Mike Poole on 25/08/2020 19:58:42:
Stefan Gotteswinter also felt the need and created this. **LINK** Mike The original idea came from Robin renzetti i believe i and he recently uploaded a video showing his latest design .
I personally like the way eccentric engineering did it on his acute sharpener video series( yes a plug for a long term advertiser on this forum) - a diamond lap or file . Gives very consistent results for small chamfers. Nice kit to build also ! |
Clive Foster | 26/08/2020 14:03:40 |
3630 forum posts 128 photos | Realistically a power driven unit is a gadget too far for most of us but if its something else a tool you need for other duties can do then .... Clive |
Roger Best | 06/09/2020 21:53:42 |
![]() 406 forum posts 56 photos |
David George 1 | 06/09/2020 22:49:59 |
![]() 2110 forum posts 565 photos | At the last place i worked at we had a pneumatic air grinder with a pair of adjustable blocks and you just run it round the block after adjusting the champher width with a thumb screw. There was a 2 inch grinding wheel on end of spindle behind the two Vee blocks. I believe you can get one with a cutter instead of grinding wheel but it made a lot of needle shaped swarf and can only cut soft steel. David |
Martin Kyte | 06/09/2020 23:03:37 |
![]() 3445 forum posts 62 photos | I agree with Dusty, can't you lot use a file. I have put chamfers on in the mill but only because the block was in the mill at the time. The only other time was deep chamfers on the slots of the table of my tapping and staking tool. Oh and chamfers on trespar for tool stands which gets the router treatment. regards Martin ;O) |
