MC Black 2 | 18/07/2020 19:27:47 |
99 forum posts | My new benchtop mill was supplied with a Q-tech R8-ER32 collect chuck Having used it for the first time, I find that I can't hold the body of the chuck while I use the C-spanner to loosen the nut. I just don't have a sufficiently strong grip in my arthritic fingers. There are flats on the body of the chuck so I guess that one needs a spanner to hold the body. Can anybody who owns one of these Collet chucks kindly tell me what size spanner is required, please? Further, any suggestions as to where I might obtain one, please? Very many thanks for your help MC Black
JasonB | 18/07/2020 19:53:25 |
![]() 25215 forum posts 3105 photos 1 articles | With the chuck in the spindle you can also lock the spindle or put a tommy bar into it and then use the collet nut spanner in the other hand, that's what I do with my two R8 machines |
not done it yet | 18/07/2020 20:36:28 |
7517 forum posts 20 photos | I’m not surprised, if the collet chuck is tightened to the proper torque! Likely tighter than your car wheel nuts should be. Measure the distance across the spanner flats - that will be the spanner size required. For items closer to the minimum diameter for the collet, I have some handy blocks of wood, of various thickness, to support the end mill/ whatever while tightening and undoing - to avoid the item falling. |
MC Black 2 | 18/07/2020 23:30:28 |
99 forum posts | Thank you for taking the time to respond. Measuring across the flats gives 46.3mm. The chuck uses a 7/16 UNF drawbar with a 11/16 nut on the top. So I suspect that the spanner may be 1.7/8 or 1.1/8 Whitworth Since I have nothing approaching any of these sizes (even in adjustable or waterpump spanners) I thought it would be useful to know is anybody among the intelligent and helpful readership has previously solved the problem. I have NOT discovered any way of locking the spindle and I'm sure I would have spotted a hole for a Tommy Bar. But I'll go and look at the Mill in the morning and search for Tommy Bar apertures and spindle locks.
pgk pgk | 19/07/2020 06:30:25 |
2661 forum posts 294 photos | About the first job I did on my mill was to make a spanner to fit the ER32 flats. I do own a huge adjustable spanner (which weighs a silly amount) since i have some farm machinery and that was used to tighten the endmill for making my spanner from a wide bar of 8mm mild steel i bummed off the local agri engineers. i cut a wide slot to fit the flats and thinned down the rest of the bar as a handle. It is crude but functional and one day I;ll get around to making a nicer one but I've been sayng that for years.... Hacksaw and drill work could fashion a temporary one or even as simple as drill holes and bolts on some narrower bar bits to create a U with a handle. pgk |
JasonB | 19/07/2020 06:53:47 |
![]() 25215 forum posts 3105 photos 1 articles | I slightly enlarged an old bicycle headset spanner with the intention of making a proper one but that was some 10years ago. What mill do you have? |
Ron Laden | 19/07/2020 07:39:36 |
![]() 2320 forum posts 452 photos | You can buy a single open ended 46mm spanner for a tenner and if its tight on your 46.3mm just mill a tad off each side. Ron |
larry phelan 1 | 19/07/2020 07:47:07 |
1346 forum posts 15 photos | As PGK said, a little work with a hacksaw and file would soon produce a useable spanner. I have made several such for odd jobs over the years where the cost of a "Proper" spanner could not be justified. They may be crude but they still work years later. |
MC Black 2 | 19/07/2020 08:28:23 |
99 forum posts | Posted by JasonB on 19/07/2020 06:53:47:
What mill do you have? It's a SP 9512-B from SPG Tools with R8 Spindle It came with a Jacobs (type) Drill chuck but I needed a way of holding milling cutters; so it was supplied with a Q-tech R8-ER32 collet chuck as an "extra". The Drawbar has a 11/16 AF nut; finding a spanner for that wasn't easy and I've now bought a suitable ring spanner from Ebay. |
Michael Gilligan | 19/07/2020 08:51:48 |
![]() 23121 forum posts 1360 photos | Please forgive the digression, but I was intrigued by that 46.3mm dimension 46.3 ÷ 25.4 = 1.82283464566929 [which doesn’t look very encouraging] and [using the converter on ‘calculator soup’] the fractional value is 1.8228346456692 = 1 + 2057086614173 / 2500000000000 [and rounding-up doesn’t seem to improve things] Google search for 46.3mm finds a Trend router cutter of that diameter, but little else of interest Eureka ! Somehow, I managed to stumble into: **LINK** http://www.convertaz.com/convert-cable-length-(international)-to-kilofoot/ Which reveals that: 3 cable lengths (International) = 1.8228346457 kilofeet . Now, can someone [probably Dave S.O.D.] please explain the connection between that little gem and the A/F dimension that MCB measured ? MichaelG.
MC Black 2 | 19/07/2020 08:58:35 |
99 forum posts | Posted by Ron Laden on 19/07/2020 07:39:36:
You can buy a single open ended 46mm spanner for a tenner and if its tight on your 46.3mm just mill a tad off each side. Ron Very many thanks for the pointer. I've pondered getting an adjustable spanner - cost is higher but offers versatility of other uses. I have also remembered that I have a (slightly rusty) 24" Stilson wrench inherited from my late father. But I can't lift it one handed (in fact, I have trouble lifting it with both hands!). With best wishes and thanks again. |
Nick Clarke 3 | 19/07/2020 09:23:10 |
![]() 1607 forum posts 69 photos | 'Superwide' adjustable spanners like this one could fit without the hassle and ungainliness of 24" stilsons, but would cost you about £20 at least. I don't use mine on a mill but nearly everywhere else! |
Gary Wooding | 19/07/2020 09:47:13 |
1074 forum posts 290 photos | **THIS** will almost certainly do the job for you, and cheap too.
MC Black 2 | 19/07/2020 10:09:23 |
99 forum posts | Posted by Gary Wooding on 19/07/2020 09:47:13:
That looks like good value. Thank you Have you actually used one? I bought a cheap adjustable spanner a few years ago and the jaw wobbled - waste of money (which I put down to experience!) Hence my question. Thank you again for taking the time to respond. |
MC Black 2 | 19/07/2020 10:17:33 |
99 forum posts | Posted by Michael Gilligan on 19/07/2020 08:51:48:
Please forgive the digression, but I was intrigued by that 46.3mm dimension 46.3 ÷ 25.4 = 1.82283464566929 [which doesn’t look very encouraging] and [using the converter on ‘calculator soup’] the fractional value is 1.8228346456692 = 1 + 2057086614173 / 2500000000000 [and rounding-up doesn’t seem to improve things] Google search for 46.3mm finds a Trend router cutter of that diameter, but little else of interest Eureka ! Somehow, I managed to stumble into: **LINK** http://www.convertaz.com/convert-cable-length-(international)-to-kilofoot/ Which reveals that: 3 cable lengths (International) = 1.8228346457 kilofeet . Now, can someone [probably Dave S.O.D.] please explain the connection between that little gem and the A/F dimension that MCB measured ? MichaelG. I think it could be 1.7/8 inch or 1.1/8 Whitworth I shall measure across the flats more carefully. Please stand by
Norman Billingham | 19/07/2020 10:32:25 |
56 forum posts | My VMC mill doesn't have a spindle lock and the ER collet chuck doesn't have spanner flats, so I had difficulty tightening collets especially at the smaller end of their range. The answer was to swap the closer nut for a ball-bearing version (I got mine from Arc Euro). Reduces the tightening torque dramatically and I can get things more than tight enough just by holding the quill pulley with one hand and the c-spanner with the other. I had planned to grind flats on the chuck but there's no need now. |
Rockingdodge | 19/07/2020 11:11:26 |
![]() 396 forum posts 111 photos | Posted by MC Black 2 on 19/07/2020 08:28:23:
What mill do you have? It's a SP 9512-B from SPG Tools with R8 Spindle It came with a Jacobs (type) Drill chuck but I needed a way of holding milling cutters; so it was supplied with a Q-tech R8-ER32 collet chuck as an "extra". I have the identical mill to you, came from same dealer. I have the belt conversion on it. It has a spindle lock near the top of the head, little black knob, push it in and spin the spindle until it drops into the hole. Regards Roger Edited By Rockingdodge on 19/07/2020 11:12:02 |
Gary Wooding | 19/07/2020 11:13:29 |
1074 forum posts 290 photos | Posted by MC Black 2 on 19/07/2020 10:09:23:
Sorry, no, I haven't used one. I found it when looking for one similar to the Eclipse version that I purchased a few years ago, which works very well and cost only about £12, but it's maximum opening turned out to be 33mm. For the sole purpose of tightening an ER30 nut I would think it would be quite adequate. |
MC Black 2 | 19/07/2020 11:28:30 |
99 forum posts | Posted by Rockingdodge on 19/07/2020 11:11:26:
What mill do you have? It's a SP 9512-B from SPG Tools with R8 Spindle It came with a Jacobs (type) Drill chuck but I needed a way of holding milling cutters; so it was supplied with a Q-tech R8-ER32 collet chuck as an "extra". I have the identical mill to you, came from same dealer. I have the belt conversion on it. It has a spindle lock near the top of the head, little black knob, push it in and spin the spindle until it drops into the hole. Regards Roger Edited By Rockingdodge on 19/07/2020 11:12:02 Thank you for taking the time to respond. That is VERY useful information It's a pity that there's wasn't anything equally useful in the Instruction Manual !! In fact, there's very little useful information in the manual - which is for the gear rather than belt version. It would be better if it had been written by a native English speaker! I suspect it was translated by a computer. Very many thanks again
MC
Rockingdodge | 19/07/2020 11:49:14 |
![]() 396 forum posts 111 photos | Glad I could help, yes the 'manual' is a bit useless I had a problem where the lower ballrace 'lost' a couple of balls( basically it disintegrated) so I put a set of tapered roller bearings in by machining a mm off each seat and it works fine now. I found I could source most of the spares I required from Arc Eurotrade, the basic machine is/was the same as their offerings. Regards Roger |
