Lee Reynolds 1 | 17/07/2020 10:39:05 |
11 forum posts 6 photos | Hi, When I get it up and running I will have a change gear set on my Harrison M300 that will comprise a combination of metal, fiber and Delrin gears. Do I lubricate the set, and if I do, what do you more experienced machinists suggest I use. I seem to remember reading somewhere that nylon should not be lubricated, is Delrin the same? Regards, Lee |
Andrew Johnston | 17/07/2020 10:56:08 |
![]() 7061 forum posts 719 photos | My M300 has the original steel and Tufnol change gears. I give them an occasional squirt with ISO68 slideway oil as per the manual. Andrew |
Ronald Morrison | 17/07/2020 11:14:09 |
98 forum posts 4 photos | Delrin should not need lubrication buy shouldn't be harmed by lubrication either. |
Circlip | 17/07/2020 11:41:31 |
1723 forum posts | Nylon absorbs water and even the "Low" absobtion rated Nylon 6 or 6-6 does to a lesser extent. Tufnol should not be lubricated, it's a layered material. Regards Ian. |
Swarf, Mostly! | 17/07/2020 12:05:35 |
753 forum posts 80 photos | Posted by Circlip on 17/07/2020 11:41:31:
Nylon absorbs water and even the "Low" absobtion rated Nylon 6 or 6-6 does to a lesser extent. Tufnol should not be lubricated, it's a layered material. Regards Ian. Hi there, Ian, Are you suggesting possible delamination? Best regards, Swarf, Mostly! |
not done it yet | 17/07/2020 12:05:52 |
7517 forum posts 20 photos | Posted by Andrew Johnston on 17/07/2020 10:56:08:
My M300 has the original steel and Tufnol change gears. I give them an occasional squirt with ISO68 slideway oil as per the manual. Andrew Exactly this. As per page 8 of the user manual. Or rather ‘daily’, perhaps? |
john halfpenny | 17/07/2020 12:08:15 |
314 forum posts 28 photos | Henry Ford used layered tufnol for camshaft gears on millions of cars. Later he used macerated tufnol, and later still a type of nylon. No problems from engine oil. |
Nick Wheeler | 17/07/2020 12:23:20 |
1227 forum posts 101 photos | Posted by john halfpenny on 17/07/2020 12:08:15:
Henry Ford used layered tufnol for camshaft gears on millions of cars. Later he used macerated tufnol, and later still a type of nylon. No problems from engine oil. Although the nylon teeth on V6 cam gears are a notorious week point....... |
Lee Reynolds 1 | 17/07/2020 13:09:12 |
11 forum posts 6 photos | Sorry Gentlemen it,s the fiber gear I am more concerned about. It came from 600 group as it was an original gear but missing from my S/H machine. For the price I expected a metal one....silly me! and then the lubrication advice in the manual would make sense and be followed. Lee |
Michael Gilligan | 17/07/2020 13:20:08 |
![]() 23121 forum posts 1360 photos | Posted by Circlip on 17/07/2020 11:41:31: […] Tufnol should not be lubricated, it's a layered material. . Certain grades of Tufnol are used for propeller shaft bearings ... totally immersed in, and lubricated by, water. MichaelG. . A little light reading: http://ahistoryoftufnol.org/whatistufnol/ and ... https://www.tufnol.com/technical/technical_materials.aspx
Edited By Michael Gilligan on 17/07/2020 13:30:35 |
