micro switch
Ian Parkin01/07/2020 12:31:55
1174 forum posts
303 photos
Can anyone identify this micro switch ?
i have lots of these all faulty because the spring has done a runner
Brian G01/07/2020 12:39:37
912 forum posts
40 photos
Marquardt 1010 series. Out of stock at RS though Marquardt
Google image search for 1010 microswitch brings up plenty of them
Brian G
Ian Parkin01/07/2020 12:44:00
1174 forum posts
303 photos
brilliant Brian
now to find some in stock somewhere
Ian Parkin01/07/2020 13:12:43
1174 forum posts
303 photos
Hmm lots availble but at high prices
Mouser came up trumps though at a reasonable price for 10 switches
but only shipping option  is £12 ( ouch)
Many thanks to Brian
Edited By Ian Parkin on 01/07/2020 13:14:31
not done it yet01/07/2020 14:12:39
7517 forum posts
20 photos
Posted by Brian G on 01/07/2020 12:39:37:
Brian G
Little wonder they discontinued them. Have you seen the insulation resistance of those things!
Michael Gilligan01/07/2020 15:28:12
23121 forum posts
1360 photos
Posted by not done it yet on 01/07/2020 14:12:39:
Insulation resistance (new condition)
> 100 MOhm (500 V DC)
Jeff Dayman01/07/2020 15:56:25
2356 forum posts
47 photos
Hi Ian, If possible, I would recommend changing to a modern enclosed microswitch. I have used Omron's D2F series in many projects with great success. About 1 UK pound retail, probably 50 p or less each from an Omron distributor in UK. Many styles of lever and terminals available, several operating forces and volt / amp combinations up to 5A at 250 VAC. These are good units with small size high performance and quality at a good price. No connection to Omron except as a very satisfied user. (if you still use a computer mouse chances are it has two D2F's in it, or a cheap knockoff of one - billions of them in service worldwide)
not done it yet01/07/2020 17:14:13
7517 forum posts
20 photos
Posted by Michael Gilligan on 01/07/2020 15:28:12:
> 100 MOhm (500 V DC)
Try again, you clearly didn’t read the link. Probably as usual, when it suits you. Here is what it actually says, just for you.
“They have a contact resistance of <100 mΩ and an insulation resistance of >100 mΩ. “
In my book, that is a mega small resistance.😆
Michael Gilligan01/07/2020 20:39:24
23121 forum posts
1360 photos
Posted by not done it yet on 01/07/2020 17:14:13:
> 100 MOhm (500 V DC)
Funny, that ^^^
I actually copied and pasted the text directly from the document linked on the RS Components page.
Perhaps [prior to apologising for yet another snide remark] you could try reading the definitive document.
https://docs.rs-online.com/5321/0900766b810168f7.pdf
Edited By Michael Gilligan on 01/07/2020 20:41:19
Ian Parkin01/07/2020 20:54:51
1174 forum posts
303 photos
Jeff
they are fitted in this piece of av equipment
and theres 7 of them fitted in each one
made in Germany in the 70’s and 80’s by kodak
its really tricky to retrofit new styles of switch
but as i said they all seem to lose the spring
they only carrying small currents at 24v
Michael Gilligan01/07/2020 21:00:43
23121 forum posts
1360 photos
“They have […] an insulation resistance of >100 mΩ. “
In fact, all that would tell you is that the insulation resistance is greater than a small resistance.
... Which would be about as pointless as the crass assessment given ‘in your book‘
V8Eng01/07/2020 22:17:17
1826 forum posts
You are both correct.
The homepage as linked to by Brian G & NDIY for these switches shows: Insulation Resistance. >100 mΩ whereas the actual specification docs linked to by Michael say it is > 100 MOhm.
Edited By V8Eng on 01/07/2020 22:19:37
Michael Gilligan01/07/2020 22:25:23
23121 forum posts
1360 photos
Posted by V8Eng on 01/07/2020 22:17:17:
Yes, I know [thanks] ... It’s the snide digs that I find objectionable
[quote] Try again, you clearly didn’t read the link. Probably as usual, when it suits you. Here is what it actually says, just for you. [/quote]
Edited By Michael Gilligan on 01/07/2020 22:28:07
peak401/07/2020 22:33:55
2207 forum posts
210 photos
Posted by Ian Parkin on 01/07/2020 20:54:51:
Jeff
Maybe use a short length of clock mainspring with a couple of holes either punched or drilled through in a simple jig.
Bill
V8Eng01/07/2020 22:34:04
1826 forum posts
Yes I think we all have enough on our minds at this time without seeing nastiness on here.
Edited By V8Eng on 01/07/2020 22:34:44
Mark Rand01/07/2020 22:57:06
1505 forum posts
56 photos
Learned something today! Been doing electronics on and off for 50 years and never realised that people used naked microswitches!
Circlip02/07/2020 12:02:33
1723 forum posts
You obviously didn't frequent surplus shops Mark. Have a couple of these as limit switches on a radio control "Servo" I made around 1960. Were scavenged from an "Aerial tuning unit" ex RAF, difference being the insulator is a paxolin stack.
Regards Ian.
Edited By Circlip on 02/07/2020 12:03:47
Martin Connelly02/07/2020 17:53:07
2549 forum posts
235 photos
You can buy small long lever microswitches that I think would replace these if the lever was bent to suit.
Martin C
RS part 0150710 for example
Edited By Martin Connelly on 02/07/2020 17:59:43
