Sodium Nitrite
Michael Gilligan24/05/2020 23:58:49
23121 forum posts
1360 photos
I need a small quantity of Sodium Nitrite, for an entirely innocent purpose
... not Potassium, and not Nitrate
This stuff is used in food processing: **LINK**
https://pubchem.ncbi.nlm.nih.gov/compound/Sodium-nitrite
but I was astonished to see the PhilipHarris web page: **LINK**
https://www.philipharris.co.uk/product/chemicals/chemicals-q-t/sodium-nitrite-250g/b8a71535
Can anyone advise or assist, please ?
peak425/05/2020 00:24:27
2207 forum posts
210 photos
Probably an expensive way to source it, but HERE maybe??
https://www.etsy.com/uk/listing/222604811/sodium-nitrite-4-ounces-fine-powder-996
Failing that, do you know any local butchers who cure their own bacon?
Bill
Ron Laden25/05/2020 05:20:05
2320 forum posts
452 photos
Hi Michael
Hope Education list 250gms for £4.20 which seems a good price.
https://www.hope-education.co.uk/product/science/chemistry/chemicals/sodium-nitrite-250g/b8a71535
Ron
Sorry Michael, just read they will only deliver to a School address.
Edited By Ron Laden on 25/05/2020 05:50:37
Michael Gilligan25/05/2020 07:52:31
23121 forum posts
1360 photos
Thanks, both
@Bill ... for no particularly good reason, I was hoping to avoid Etsy
Edit: and I now find this: ‘Sorry, this item doesn’t deliver to United Kingdom.‘
@Ron ... yes that’s the same as the Philip Harris offering
Edited By Michael Gilligan on 25/05/2020 08:00:15
Robert Atkinson 225/05/2020 08:35:50
1891 forum posts
37 photos
Posted by Michael Gilligan on 24/05/2020 23:58:49:
Hi,
Camlab is a UK chemical supplier who will happly sell chemicals to private individuals (as long as they are not restricted). They eventake PayPal. They list Sodium Nitrite at reasonable cost.
https://www.camlab.co.uk/sodium-nitrite-pure
Unfortunatly it's on back order at the moment.
Robert G8RPI.
Michael Gilligan25/05/2020 09:01:04
23121 forum posts
1360 photos
Posted by Robert Atkinson 2 on 25/05/2020 08:35:50:
Hi,
Robert G8RPI.
Many thanks, Robert
... I will enquire
Edit: A pattern seems to be emerging heresad
Sodium Nitrite Pure for laboratory use only. Not suitable for food use. We can only supply this to companies. You should only purchase this with an account and not through the guest checkout these orders will be cancelled and refunded.
Edited By Michael Gilligan on 25/05/2020 09:22:34
Andrew Evans25/05/2020 09:11:20
366 forum posts
8 photos
Try asking at a butcher
not done it yet25/05/2020 09:12:22
7517 forum posts
20 photos
It’s neither the sodium or potassium salt that is ‘naughty’ but they both can be used to produce a chemical that is unstable.
I remember, back in 1965/66, that the school lab technician spilt a solution of chemicals on a rough paved surface and for weeks afterwards we could generate tiny explosions underfoot. Afterwards, I wondered if he did it on purpose as he was a mischievous individual.
Later, at work, we regularly made another unstable chemical (similar but not the same) which detonated easily. It was OK until someone blew the drying cabinet door open by preparing too much at a time and it spontaneously decomposed - either too hot or local vibration!
Our supervisor used to get cross when there was a carpet of rubber bits on the floor - due to smashed rubber bungs - he was no fun
JohnF25/05/2020 10:21:23
1243 forum posts
202 photos
Michael, try these , no experience with Nexchem also look up Walsall chemicals they manufacture metal treatment salts which do contain said compound, I have used these folk for supplies. There is another one in Brum that supplied the gun trade— name escapes me right now but if the memory bank opens I’ll PM you
Michael Gilligan25/05/2020 10:29:25
23121 forum posts
1360 photos
Thanks for that, John ... much appreciated
mark smith 2025/05/2020 10:35:24
682 forum posts
337 photos
Not clear whether you want lab grade or food grade???
Michael Gilligan25/05/2020 10:38:24
23121 forum posts
1360 photos
Posted by mark smith 20 on 25/05/2020 10:35:24:
Probably not important ... but on principle, I would go for lab grade if available
the 250g that Philip Harris sells would probably be more than I will ever need.
Edited By Michael Gilligan on 25/05/2020 10:40:48
Martin Connelly25/05/2020 10:40:05
2549 forum posts
235 photos
Before we went to all stainless pipework at work we used to have treatment baths for mild steel pipe fabrications. The first tank was deoxidine which was a phosphoric acid based chemical. The second tank was plain water to rinse off the deoxidine. The third tank was a heated tank containing sodium nitrite to neutralise any remaining acid and after the water flashed off left an anti-corrosion layer that was good for a week or so giving enough time to get the pipes painted then the bores were sprayed with preserving oil before the ends were capped off.
We went all stainless when the labour costs of removing lacquer, descaling (imagine the work involved with raised face spiral grooved ANSI flanges), treating and painting required for mild steel pipes outweighed the material cost of stainless pipes.
Martin C
mark smith 2025/05/2020 10:41:40
682 forum posts
337 photos
Ive used this place several times fast delivery etc... but no sodium nitrite
mark smith 2025/05/2020 10:43:48
682 forum posts
337 photos
Posted by Michael Gilligan on 25/05/2020 10:38:24:
Important if you were going to pickle or preserve foodsmiley
mark smith 2025/05/2020 10:55:15
682 forum posts
337 photos
Posted by Martin Connelly on 25/05/2020 10:40:05:
Martin C
Sorry if i misunderstood but sodium nitrite in your process will be used as an anodic inhibitor to reduce corrosion on the surface .smiley
peak425/05/2020 12:08:24
2207 forum posts
210 photos
Posted by Michael Gilligan on 25/05/2020 07:52:31:
Thanks, both
Sorry, typing too late, missed that bit. blush
Looks like it comes under Section 1.2 of This Document as a poison
https://www.gov.uk/government/publications/supplying-explosives-precursors/supplying-explosives-precursors-and-poison
See also This Document and the downloadable pdf.
https://www.gov.uk/government/publications/record-of-suspicious-transactions
Bill
mark smith 2025/05/2020 12:26:07
682 forum posts
337 photos
Michael how much do you need ?
Edited By mark smith 20 on 25/05/2020 12:29:32
Robert Atkinson 225/05/2020 13:43:55
1891 forum posts
37 photos
So it looks like suppliers are taking the easy way out on EPP reporting and only selling to companies even for reportable substances.
In theory they should sell to the public and only report it if the transaction is suspicious. By only selling to companies they remove the need to judge if a transaction is suspicious. Basically they are applying the EPP prohibition to every chemical on the list They don't even say you can buy them if you have an EPP licence (you can't get an EPP licence for Sodium Nitrite becuse it not restricted DOH). The easy way out is to set up a business to use it.
Michael Gilligan25/05/2020 14:39:57
23121 forum posts
1360 photos
Posted by mark smith 20 on 25/05/2020 12:26:07:
About 50g would be plenty for the foreseeable future, so the Philip Harris or similar offering would have been ample and cost-effective.
... My entirely innocent purpose has no connection with food processing or improvised pyrotechnic devices.
I will post a link shortly
Edit: ___ I will be working with much finer needles than he demonstrates here,
but the principle is the same: https://youtu.be/0rhRJpepesM
Edited By Michael Gilligan on 25/05/2020 14:48:01
