Help identifying thread
Chris Shelton16/05/2020 11:32:38
92 forum posts
46 photos
Hi I have a thread on an American made car diagnostic probe, which I am having trouble identifying, the major diameter is 4mm or .1580" it is 32tpi. can anyone help, I need to purchase a tap to suit, have looked on the internet, but cannot match the details.
Thank you
Tony Pratt 116/05/2020 11:44:12
2319 forum posts
13 photos
Most likely 8-32
Tony
Marischal Ellis16/05/2020 11:48:29
77 forum posts
27 photos
poss UNF does that help.
mechman4816/05/2020 12:19:49
2947 forum posts
468 photos
Try:-
ANF ( 60* ) #10 = 32TPI
2 BA = 4.0 mm / 0.1575
George.
Chris Shelton16/05/2020 12:21:47
92 forum posts
46 photos
Hi, Thank you for the replies, just found my engineers Black Book, and it looks as if it could be 5/32 BSW, which is not listed in Zeus
Tony Pratt 116/05/2020 12:34:56
2319 forum posts
13 photos
Hi Chris, 2 points, the yanks would not use BSW & .158" is bigger than 5/32" that being said it will work.
Tony
Clive Brown 116/05/2020 12:37:08
1050 forum posts
56 photos
5/32" BSW is Meccano thread. Seems unlikely on an American gadget.
Andrew Johnston16/05/2020 12:42:24
7061 forum posts
719 photos
Given it's US made I'd bet it's 8-32 UNC.
Howard Lewis16/05/2020 12:55:37
7227 forum posts
21 photos
Zeus Charts give 6-32 ANC as having an OD of 0.138", and 8-32 as 0.164" The thread form will be 60 degrees
There is no ANF thread with 32 tpi pitch.
It could be 10-32 UNF which is 0.164" diameter, but slightly truncated to give the 0.158" OD.
If it were 4mm it would be 0.15748" diameter, but M4 is 0.7mm pitch which is 17.78 tpi.
HTH
Jeff Dayman16/05/2020 13:08:49
2356 forum posts
47 photos
Howard Lewis - your third sentence - #10-32 UNF is NOT .164" diameter, #8-32 UNC is .164" diameter
#10-32 UNF is .190" diameter
Howard Lewis16/05/2020 13:16:35
7227 forum posts
21 photos
Quite RIGHT,
I misread from one line to the next
Sackcloth and Ashes again!
So looks like 8-32 UNC as a likely candidate.
Chris Shelton16/05/2020 13:24:56
92 forum posts
46 photos
Thank you all for taking the time to reply, I have ordered a 5/32 BSW set of taps, as Tony P said it will work.
Tony Pratt 116/05/2020 13:49:17
2319 forum posts
13 photos
Posted by Chris Shelton on 16/05/2020 13:24:56:
If it doesn't work I will refund your moneycheeky or send you an 8-32 tap.
Tony
Edited By Tony Pratt 1 on 16/05/2020 13:49:57
Pete Rimmer16/05/2020 13:53:28
1486 forum posts
105 photos
Posted by Howard Lewis on 16/05/2020 12:55:37:
HTH
Sorry to be a correction-ist Howard but I think you multiplied instead of dividing there. 0.7mm pitch would be 36.28tpi
Former Member16/05/2020 14:57:10
Neil Wyatt16/05/2020 15:15:25
19226 forum posts
749 photos
86 articles
This is a great explanation of the different systems from an American perspective.
www.rustmag.com/gear/2018/1/4/threads-and-thread-systems
With one exception UNC and Whitworth are the same, except for the flank angles.
<edit> I forgot the link!
Edited By Neil Wyatt on 16/05/2020 15:15:59
Chris Shelton16/05/2020 17:23:33
92 forum posts
46 photos
A local friend came to my rescue with a 5/32 BSW tap, after tapping the part it screwed onto the probe about half a turn, so have now ordered, an 8-32 tap, can someone tell me what the 8 in the 8-32 stands for?
Tony I will not hold you to your promise of a refund, after all I could tap some Meccano parts now.
Former Member16/05/2020 17:51:30
JasonB16/05/2020 17:53:08
below 1/4" dia UNC & UNF use a number system a bit like old wood screws and BA threads, the higher the number the larger the thread.
Tony Pratt 116/05/2020 18:33:14
2319 forum posts
13 photos
Posted by Chris Shelton on 16/05/2020 17:23:33:
Thanks, let us know if the 8-32 does the trick, 5/32 BSW is slightly smaller on diameter, maybe that is the problem.
Tony
