What are these for
Boiler Bri05/04/2020 18:45:52
856 forum posts
212 photos
I have had these kicking around for ages. Does anyone know what they are?
Boiler Bri05/04/2020 18:47:35
856 forum posts
212 photos
peak406/04/2020 00:50:19
2207 forum posts
210 photos
The pair on the right look like lantern toolholders.
Would they slide into a T slot in the topslide?
The square headed screw would lighten down on the toll and lock both tool and holder.
Bill
not done it yet06/04/2020 11:23:32
7517 forum posts
20 photos
P4,
My first thought, but the bolt cannot push and pull at the same time? Because BB has not said there are any movable parts at the bottom end have to assume they simply fit in a slot of some description. Parts for some form of jig?]
I thought the pair on the left might be for holding a saw/blade, possibly for sharpening? Or fitting longer blades in a machine?
Edited By not done it yet on 06/04/2020 11:25:42
peak406/04/2020 12:48:48
2207 forum posts
210 photos
Posted by not done it yet on 06/04/2020 11:23:32:
P4,
My first thought, but the bolt cannot push and pull at the same time? Because BB has not said there are any movable parts at the bottom end have to assume they simply fit in a slot of some description. Parts for some form of jig?]..............................
Wouldn't it work if the "toolpost" was poking through a thick washer to set the centre height of the tip; so long as the washer is thick enough to raise the bottom of the tool above the oval bottom of the hole of course.
Bill
Nick Clarke 306/04/2020 15:14:23
1607 forum posts
69 photos
Dunno about the two on the left but the two on the right, apart from looking to be far far too small to be toolholders remind me of fittings for glass shelves or doors in shopfittings or furniture.
magpie06/04/2020 15:32:36
508 forum posts
98 photos
Could the 2 on the left be to clamp onto a sheet or strip of metal and hold a tube or rod in the 'V' whilst soldering or welding the two parts together ???
John Paton 106/04/2020 16:09:28
327 forum posts
20 photos
+1 for lantern toolholders (minus their dished washer and matching boat to go under the tool itself.
I am thinking that the items on the left may be steadies for use when turning / threading long slender shafts? I say this as they seem to be similar centre height to the lanterns and same tee slot size?
Both items fit on lathe cross slide? Might not be for metal but quickly reduce spindles and the like? One fits the original outside diameter and the other the new 'reduced' diameter? Could be handy when turning longer lengths of wood, plastics and similar flexible materials?
Kenneth Deighton06/04/2020 19:44:11
69 forum posts
The two round objects are valve lifters from some unknown engine Ken..
stevetee06/04/2020 20:32:05
145 forum posts
14 photos
unnamed.jpgThe 2 round objects do look like cam followers from a flathead Ford V8, see the item at the top of the picture
bernard towers08/04/2020 23:34:31
1221 forum posts
161 photos
Valve guides for ford v8 side valve circa 1940s, they bring back memories!
Bernard Wright11/04/2020 12:06:59
90 forum posts
16 photos
They look like drive trips off a machine with a movable table ie. milling machine or engraver...
