mick H | 02/03/2020 09:58:43 |
795 forum posts 34 photos | I have been advised that I can effectively seal and waterproof electronic circuit boards with silicone. The specific application is for a small (1.25" x 1.25" Mick |
Michael Gilligan | 02/03/2020 10:03:16 |
![]() 23121 forum posts 1360 photos | There are better products available, Mick ... Do a search for ‘Conformal Coating’ MichaelG. |
Mike Poole | 02/03/2020 10:04:05 |
![]() 3676 forum posts 82 photos | There are versions of silicone for electronic work, I would not use a kitchen bath sealant. Mike |
Nick Clarke 3 | 02/03/2020 10:11:59 |
![]() 1607 forum posts 69 photos | Subject to choosing an appropriate silicon yes - Many thousands of Lucas ACR car alternators had the diodes sealed in silicon and the tripler in a CRT TV or monitor was often similarly sealed - I used to dig out the sealant from both of these to replace (non-replaceable!) parts. |
Joseph Noci 1 | 02/03/2020 10:37:24 |
1323 forum posts 1431 photos | Don't use any sealer using acids or alkalies as curing agents. All non-nobel metals corrode when embedded in that stuff! Many Electrical supplies sell a conformal coating spray for electrical switch boxes, or a better type is often available from an Auto-Electrical supplier - often used to insulate/seal alternator/generator windings - typically a red spray. Conventional Electronic conformal sprays are available from places like RS components, etc, but pricey. If the board is not exposed to temps greater than 80degC, then a decent clear lacquer spray will do the job. Won't last years as will a good conformal coating, but maybe good enough? Make sure the board is really clean - clean with dishwashing liquid and water, rinse, dry, bake in the oven at 50degC for a while - 20min, and spray 4 or five thin coats from every angle. Joe
norman royds 2 | 02/03/2020 11:56:38 |
48 forum posts | I would sugest silicon for fish tank I think it is acid free norm |
Steviegtr | 02/03/2020 12:19:31 |
![]() 2668 forum posts 352 photos | Or contain it in resin. Available from many places inc car accessory shops. Steve. |
Bazyle | 02/03/2020 12:45:07 |
![]() 6956 forum posts 229 photos | Double glazing sealed units are supposed to be put in with non-acidic sealant. You might see if an installer will give you the end of a tube. |
mick H | 02/03/2020 13:51:35 |
795 forum posts 34 photos | Thanks for the advice gents. I am pleased that I asked. Mick |
Steve Skelton 1 | 02/03/2020 13:54:38 |
152 forum posts 6 photos | Mick, having worked with silicone rubbers in the window industry the type of silicone you are looking for is "neutral cure low modulus" silicone sealant. Steve |
old mart | 02/03/2020 17:08:50 |
4655 forum posts 304 photos | You can get electronic potting compound for this, or an acetic acid free silicone from Dow Corning. Don't forget, that sealing will affect any heat sinks adversely. Edited By old mart on 02/03/2020 17:10:51 |
Neil Wyatt | 02/03/2020 17:44:42 |
![]() 19226 forum posts 749 photos 86 articles | Posted by mick H on 02/03/2020 09:58:43:
is that tube silicone usually has a strong acetic acid type smell and I wonder whether it will corrode the connection wires etc ? The answer is yes, there are special types. An easier to use and more effective solution is hot melt glue! I used this when I modified my DSLR to have a cooled sensor to protect the cricuit board from condensation and ice, and it worked perfectly. Neil |
duncan webster | 02/03/2020 19:51:47 |
5307 forum posts 83 photos | I used hot melt glue to pot some resistors recently (for track circuiting) A lot easier than messing about with 2 pack resins, especially for a small amount |
Martin Hamilton 1 | 02/03/2020 20:03:50 |
188 forum posts | Yes hot melt glue will do the job, you can also use Plastidip also. Def do not use any of the acidic silicons like the bathroom & kitchen types. if using silicon use electronics grade silicon, You can also seal with a thin coat of 2 part epoxy glue. |
Brian Oldford | 02/03/2020 20:06:57 |
![]() 686 forum posts 18 photos | Posted by duncan webster on 02/03/2020 19:51:47:
I used hot melt glue to pot some resistors recently (for track circuiting) A lot easier than messing about with 2 pack resins, especially for a small amount track circuiting what pray tell?
duncan webster | 02/03/2020 20:48:02 |
5307 forum posts 83 photos | Posted by Brian Oldford on 02/03/2020 20:06:57:
a 5"g railway of course. If you're interested send me a pm and I'll find the relevant ME articles |
