Where's the spindle lock?
Gary Wooding20/02/2020 14:05:29
1074 forum posts
290 photos
I've obtained a 2nd hand Bosch angle grinder. The model id is on a stick-on label which is partially missing. What is visible reads 'nWS 6-115', but I think the 'n' is a 'P'.
The problem is, how do I apply the spindle lock? According to the only manual I could find, there is supposed to be a spindle-lock button, but I can't find it at all.
The photos show the grinder where the button should be visible, but where is it?
JasonB20/02/2020 14:22:21
Probably came with a thin stamped out spanner about 12mm that fits over flats on the spindle just as it exits the machine.
This shows the two spanners
Edited By JasonB on 20/02/2020 14:25:32
Willem Kotze20/02/2020 14:47:17
17 forum posts
My PWS 7-115 has a 17 mm Flat. The flat drives the rear washer unlike others that screw on. If not overtightened an appropriate blow on the normal spanner on the front nut may loosen it easily against just the motor inertia. Or just grip whatever disk or wire-brush is on it and undo the nut.
Willem Kotze20/02/2020 14:53:26
17 forum posts
Tightening should only be enough not to have the wheel spin of. Once under load it will self tighten.
Gary Wooding20/02/2020 15:44:46
1074 forum posts
290 photos
Thanks guys. I'll have to make suitable spanner.
Russ B20/02/2020 17:00:47
635 forum posts
34 photos
My dad has this grinder, thin spanner required, I would guess you might find one on eBay for a quid or 2 delivered
Neil Wyatt20/02/2020 18:12:56
19226 forum posts
749 photos
86 articles
The spindle lock on 99% of angle grinders (and cheap routers) is a waste of time anyway, they round off of stop working quite quickly. I've modded spanners to fit before now...
MichaelR20/02/2020 19:23:31
528 forum posts
79 photos
img_0098.jpg The spindle on my grinder is on the top of the front housing.img_0096.jpg
Edited By MichaelR on 20/02/2020 19:24:54
Edited By MichaelR on 20/02/2020 19:26:35
larry phelan 121/02/2020 13:10:54
1346 forum posts
15 photos
Yes ,I think there should be a thin spanner to lock the spindle. I have one such spanner kicking around for years, never quite sure what it was for, now I know !
You learn something new every day !
Gary Wooding21/02/2020 15:42:39
1074 forum posts
290 photos
Since my acquisition came with no proper means of changing discs I made a pair of spanners.
not done it yet21/02/2020 20:15:09
7517 forum posts
20 photos
I have a couple of the 14mm ‘quick change’ disc nuts. For wire brushes I use a very heavy duty glove. Finding one spanner to fit is usually a pita. Never yet damaged a spindle lock.
