Philip Burley | 19/02/2020 17:54:04 |
![]() 198 forum posts 1 photos | |
Philip Burley | 19/02/2020 17:56:31 |
![]() 198 forum posts 1 photos | a picture of my boring set up , with a monster keats type angle plate |
Philip Burley | 19/02/2020 17:58:40 |
![]() 198 forum posts 1 photos | a pic of the set up to bore my red wing cylinder using a monster keats type angle plate |
Baz | 19/02/2020 19:32:28 |
1033 forum posts 2 photos | Looks good to me, lovely Keats angle plate. Is the lathe a Bantam 1600? |
Philip Burley | 19/02/2020 19:44:20 |
![]() 198 forum posts 1 photos | Its a Mk 1 Bantam . I bought the plate last week for £25 . nobody wanted it as it's too big and heavy for most lathes . I was going to use a between centres bar , but I couldnt see how to set it to get an exact to size bore with out a complicated adjustment bar . . and the Bantam doent have and bolt holes in the cross slide anyway . With a thick boring bar I think this should be OK , Takes ages though . 10 mins for one pass at my speeds !! regards |
the artfull-codger | 19/02/2020 19:47:44 |
![]() 304 forum posts 28 photos | Looks like a genuine Keats Philip, made by exe engineering,I have the same model.they did a smaller one as well,I have a smaller one but not a Keats, it does the job but genuine keats are real quality. Graham. |
Mick B1 | 19/02/2020 20:54:21 |
2444 forum posts 139 photos | Here's a rather shaky video of what I did to the cylinder of my Murray's Hypocycloidal from the Polly Models kit. It's a bit boring. Sorry... Edited By Mick B1 on 19/02/2020 21:00:40 |
IanT | 19/02/2020 20:58:13 |
2147 forum posts 222 photos | Posted by the artfull-codger on 19/02/2020 19:47:44:
I have a smaller one but not a Keats, it does the job but genuine keats are real quality. Graham. I have an Asian "Keats" type plate that I purchased some time ago from one of the better known suppliers. It was to work on a small run of parts where I needed repeatable setting and used straight out the box. After the job, it got put away and (as it happened) I didn't use it again until late last year. This time I needed to turn the bridge clamp over to increase it's holding diameter and was puzzled as to why I couldn't get the bolts back in. Turned out both bolts had been through drilled (and tapped) at about 5 degrees off upright and that the bridge casting had also been machined well off centre too. Looking at it now, I can't understand why I didn't spot this on first use but I didn't. It's on the TUIT list. I will drill the clamp holes true and re-tap them a larger size, replacing the bolts. The bridge will also need to be squared up - a shaper job for this coming Summer when it's warmer. The base seems OK but I will also check that too. So, morale of the story - check tools carefully on receipt and don't just assume they are right....mostly they are but not always... Regards, IanT |
Steviegtr | 19/02/2020 22:29:58 |
![]() 2668 forum posts 352 photos | Posted by Mick B1 on 19/02/2020 20:54:21:
Here's a rather shaky video of what I did to the cylinder of my Murray's Hypocycloidal from the Polly Models kit. It's a bit boring. Sorry... Edited By Mick B1 on 19/02/2020 21:00:40 Nice work Mick B1. Steve. |
Ian S C | 20/02/2020 10:59:10 |
![]() 7468 forum posts 230 photos | When I built an ALPHA type Stirling engine, I bored both cylinders at the same time, then I made the pistons and lapped them to the cylinders, I then divided the cylinders into two separated liners. In the end I had to lap the hot cylinder as it got a bit tight after 15 to 20 minutes running. The motor had water cooling but that didn't help much. It is now air cooled and will run as long as it has fuel. Note the ALPHA motor has equal size cylinders. Ian S C |
