Shent | 16/12/2019 23:30:04 |
![]() 46 forum posts 25 photos | Evenin' all, I have a mill arriving tomorrow and completely forgot to get oil for the ways and ballscrews. I have ordered some mobil dte 24 lite and Vactra #2 but it wont be here until wednesday/thursday and I know I wont be able to wait until then to play so out of the following which would you use temporarily for a couple of days if you absolutely had to: 1. engine oil 10w40 2. 3 in one oil 3. chainsaw oil 4. rapeseed oil.... stop laughing 5. olive oil.... please stop laughing 6. white lithium grease Think that's all i have in the house.
Cheers
Mark |
Grindstone Cowboy | 17/12/2019 00:19:48 |
1160 forum posts 73 photos | I guess the chainsaw oil would be best, good and sticky, but liberal applications of the 10W40 would also be OK, but a bit more drippy. |
Pete Rimmer | 17/12/2019 00:22:45 |
1486 forum posts 105 photos | Just use the engine oil. You won't wear it out in a day. |
peak4 | 17/12/2019 01:02:35 |
![]() 2207 forum posts 210 photos | I'd go for the chainsaw oil, it seems to say around quite well. Bill |
Hopper | 17/12/2019 03:57:33 |
![]() 7881 forum posts 397 photos | Engine oil is all I use on my lathe ways and bearings. Going good for 50 years and more now. |
Thor 🇳🇴 | 17/12/2019 06:06:19 |
![]() 1766 forum posts 46 photos | Hi Mark, Use mineral based Chainsaw oil or engine oil for the temporary oiling. The chainsaw oil sticks to the surface so would be Ok for the vertical ways. I would not recommend that you use 3 in one, rapeseed oil or olive oil. Thor |
Shent | 17/12/2019 09:41:37 |
![]() 46 forum posts 25 photos | Thanks all for the responses, engine/chainsaw oil it is then.
Cheers
Mark |
not done it yet | 17/12/2019 09:47:47 |
7517 forum posts 20 photos | Posted by Thor on 17/12/2019 06:06:19:
I would not recommend that you use 3 in one, rapeseed oil or olive oil. Thor I might expect the same problems with vegetable oils as some experienced with Castrol - R. While Castrol - R was a very good engine lubricant (obviously better than the mineral oils of the time) mixing with mineral oil showed up the incompatibility by causing engine seizures! I doubt 3 in one oil would be too bad, for a day, but it will leave a residue if left to ‘dry out’. Edited By not done it yet on 17/12/2019 09:48:54 |
Nigel McBurney 1 | 17/12/2019 11:08:06 |
![]() 1101 forum posts 3 photos | I assume that chainsaw oil that is mentioned is for the chain and not the engine,I certainly would never use chain oil far too sticky,sometimes it can be so sticky that my small Stihl will not pump it onto the blade, the big Stihl does. I have used good quality branded multi grade and nothing else on my s7 for 50 years with no problems, mono grade motor oil with minimum additives now sold as clasic oil for pre war cars does not mix well with soluble oil ,it certainly made the saddle stiff on my colchester ,I do not have any problems with multi grade though I do not use the cheap rubbish. I think that the reason machine tool makers specify mono oils that are not suitable for auto use is that if motor oil was specified the workers would nick it for their cars and motor bikes.and also machine tool oil and hydraulic oils are cheaper than good motor oil. |
Dave Halford | 17/12/2019 11:37:43 |
2536 forum posts 24 photos | 3in1 is not the oil it once was. modern synthetic engine oil is fine and won't clag over time like mineral oil does |
old mart | 17/12/2019 13:40:29 |
4655 forum posts 304 photos | Engine oil will be fine, avoid 3 in one. I would have recommended chainsaw oil until the thickness was explained. |
thaiguzzi | 17/12/2019 15:16:38 |
![]() 704 forum posts 131 photos | I'd wait the couple of days and put the proper stuff you ordered and paid for. Why contaminate a brand new machine? Patience is a virtue... Now get down the pub and wait.... |
Shent | 17/12/2019 18:20:37 |
Cheers
Mark |
Shent | 17/12/2019 18:32:27 |
Oily Rag | 17/12/2019 18:38:44 |
![]() 550 forum posts 190 photos | Posted by Nigel McBurney 1 on 17/12/2019 11:08:06:
I assume that chainsaw oil that is mentioned is for the chain and not the engine,I certainly would never use chain oil far too sticky,sometimes it can be so sticky that my small Stihl will not pump it onto the blade, the big Stihl does. I have used good quality branded multi grade and nothing else on my s7 for 50 years with no problems, mono grade motor oil with minimum additives now sold as clasic oil for pre war cars does not mix well with soluble oil ,it certainly made the saddle stiff on my colchester ,I do not have any problems with multi grade though I do not use the cheap rubbish. I think that the reason machine tool makers specify mono oils that are not suitable for auto use is that if motor oil was specified the workers would nick it for their cars and motor bikes.and also machine tool oil and hydraulic oils are cheaper than good motor oil. Haha! That reminds me of the time I was an apprentice and I discovered the Jig borers at the factory I worked at were using Newton Oil version of 'R' - It just so happened I was riding a BSA Gold Star (DB32 Clubman for those interested) that ran on 'R'. From then on I was taking a bottle a day home! The guys told me it was run on vegetable oil as it was the best oil but it was impossible to run in road vehicles - except mine I explained! |
Alan Vos | 17/12/2019 18:52:46 |
162 forum posts 7 photos | For a few days you could probably use lard. Or be seasonal and upgrade to goose fat. |
Howard Lewis | 17/12/2019 20:27:16 |
7227 forum posts 21 photos | The 20W40 engine will be fine. An overkill insofar that it contains additives that you do not need for machine ways. But should cause no problems. 3 IN 1 is far too thin, a NO NO in my book. Avoid like the plague, anything that is likely to go gooey within the next year! Howard |
Neil Wyatt | 17/12/2019 21:23:48 |
![]() 19226 forum posts 749 photos 86 articles | Vegetable oils oxidise and go thick. Neil |
Richard - | 17/12/2019 23:52:55 |
62 forum posts 7 photos | Where are you located? Perhaps somebody could help you out with a small amount until yours arrive?
Hopper | 17/12/2019 23:59:11 |
![]() 7881 forum posts 397 photos | Sheesh guys, it's oil. As long as there is some kind of oil on there, it will be good enough until the magical elixir arrives in the mail. It's not like we are talking about lubricating 10,000 rpm turbo bearings or anything. |
