sparky mike | 04/12/2019 08:39:31 |
259 forum posts 77 photos | Is it possible to buy a i inch reamer with a no.2 morse taper ? All those I have seen so far on line are no. 3 morse tapers. Mike. |
Tony Pratt 1 | 04/12/2019 09:17:29 |
2319 forum posts 13 photos | I doubt it but someone may find one, that's a fair old diameter for a # 2 morse taper. Tony |
Brian H | 04/12/2019 09:23:19 |
![]() 2312 forum posts 112 photos | You could always turn a 3MT down to 2MT. Brian |
not done it yet | 04/12/2019 09:56:22 |
7517 forum posts 20 photos | Posted by Brian H on 04/12/2019 09:23:19:
You could always turn a 3MT down to 2MT. Brian Or use a 3-2MT reducer. Might need a longer lathe, or taller milling machine, and a ‘lead-in’ to get the reamer on centre height. |
Bazyle | 04/12/2019 13:19:59 |
![]() 6956 forum posts 229 photos | Are you looking for the MT part to be aligning the reamer? There are other methods and any flex in the setup with it that rigidly held might be a problem. |
sparky mike | 04/12/2019 15:31:35 |
259 forum posts 77 photos | Just looking for a 1" reamer that will fit my pedestal drill or my Boxford tail post. If all fails, I can visit my friend who had a Bridgeport mill. Mike. |
John Reese | 05/12/2019 03:38:01 |
![]() 1071 forum posts | The standard taper for 1" reamers is 3MT. Instead of turning down a 3MT to 2MT consider buying a straight shank reamer and turn the end of the shank to a diameter that fits your chuck. |
thaiguzzi | 05/12/2019 08:59:23 |
![]() 704 forum posts 131 photos | Posted by sparky mike on 04/12/2019 15:31:35:
Just looking for a 1" reamer that will fit my pedestal drill or my Boxford tail post. If all fails, I can visit my friend who had a Bridgeport mill. Mike. I use MT 3 reamers up to 1.250" and including 1" in my Boxford tailstock. Just buy a MT 3 -2 reducer, plenty of room. |
Alain Foote | 06/12/2019 09:55:47 |
69 forum posts 10 photos |
Here is a 1" reamer with 2MT |
Bernard Wright | 10/12/2019 17:50:55 |
![]() 90 forum posts 16 photos | Hi, have you tried Tracey Tools in Torquay, they often have non-standard items, usual disclaimer. |
