Cornish Jack | 07/10/2019 19:50:26 |
1228 forum posts 172 photos | I have a Tiplap grinder with two original Boremaster wheels. They aren't really suitable for general grinding, so I am fitting a carborundum cup wheel . I have made a new mounting adaptor but I am unsure about the type of 'washer' to fit on either side. I have cut our a couple from the cardboard of a tool package. Is this appropriate or should they be made from something less 'agricultural? TIA rgds Bill |
John Reese | 07/10/2019 19:53:58 |
![]() 1071 forum posts | I cut my "blotters" from the cardboard back of a writing tablet. |
old mart | 07/10/2019 20:37:00 |
4655 forum posts 304 photos | The cardboard from a cereal packet or slightly thicker would be fine, you could cut a stock and change them every time a wheel is changed. As you are obviously aware of the importance of the soft interface, there is nothing more to say. |
Cornish Jack | 07/10/2019 21:00:02 |
1228 forum posts 172 photos | John and Old Mart - thank you. Both your suggestions are much less 'spongy than the card I have - no writing tablet and no cereal packet . I have a nagging feeling that what I have produced is not ideal! I shall have to search further. rgds Bill |
Grindstone Cowboy | 07/10/2019 21:55:38 |
1160 forum posts 73 photos | If yours are a bit thin, just double them up. I have also seen vinyl flooring used - the spongy sort - but not entirely convinced this is 'right'. |
Baz | 07/10/2019 22:02:27 |
1033 forum posts 2 photos | Use your favourite cereal packet, makes excellent washers, not convinced that vinyl flooring is suitable though. |
Nicholas Farr | 07/10/2019 23:09:55 |
![]() 3988 forum posts 1799 photos | Hi Bill, or just get some Blotting Paper Regards Nick. P.S. there are others available, the link is just an example. Edited By Nicholas Farr on 07/10/2019 23:13:45 |
ega | 07/10/2019 23:44:35 |
2805 forum posts 219 photos | Unless your flanges are rustproof I suggest you make the blotters from something that won't harbour moisture. |
Joseph Noci 1 | 08/10/2019 06:46:13 |
1323 forum posts 1431 photos | Thin Gasket sheet from your local motor-spares supply works very well - I use around 0.6mm material. In my town, around £3 for a half square meter. Use the rest on your model engines.. Joe |
mechman48 | 08/10/2019 08:53:48 |
![]() 2947 forum posts 468 photos | Any of the above are deemed suitable; they are to allow for slight imperfections on the outer faces of the wheels & equalise the loading of the metal discs. As with all grinding wheels; apart from resin bonded type give them a 'ring test' with any non metallic tool, screwdriver handle, small hammer shaft etc, if it rings your good to go, if a dull sound, bin it, as it will have a crack/damage somewhere. George. |
Martin Kyte | 08/10/2019 08:54:11 |
![]() 3445 forum posts 62 photos | As I understand it what you are trying to acheive by interposing 'soft pads' between the clamp washer and nut and the wheel is the avoidance of local stress on the wheel caused by it's rough surface. basically something to conform to the surface and fill all the gaps. So still enough to hold firmly buut soft enough to give a little to spread the load. Pretty much all the materials that have been suggested above fit the bill. regards Martin |
Cornish Jack | 08/10/2019 09:12:32 |
1228 forum posts 172 photos | Thank you all again. From all the advice given, I'm concerned about the compressiblity of the cardboard I had intended to use. As I said, it's just a standard piece of a cardboard box and doesn't have the less compressible qualities of e.g. gasket material - maybe I'm over-worrying! rgds Bill |
Michael Gilligan | 08/10/2019 10:02:57 |
![]() 23121 forum posts 1360 photos | The elfin folk have very kindly provided this, free to download: **LINK** https://www.hse.gov.uk/pUbns/priced/hsg17.pdf It’s an excellent little document, and p19 is particularly relevant. MichaelG. |
Pete Rimmer | 08/10/2019 14:07:35 |
1486 forum posts 105 photos | Posted by Cornish Jack on 08/10/2019 09:12:32:
Thank you all again. From all the advice given, I'm concerned about the compressiblity of the cardboard I had intended to use. As I said, it's just a standard piece of a cardboard box and doesn't have the less compressible qualities of e.g. gasket material - maybe I'm over-worrying! rgds Bill I think you are Bill. All of the wheels I have in my workshop have simple paper blotters. Not much give in them at all. |
