sink fitting help
mark smith 2019/09/2019 19:25:19
682 forum posts
337 photos
Hi , Im putting a new sink in for my mother ,this one :
As you can see it came with the tap and tails for underneath.
My mind is getting confused as to what i need to connect it up.
Ive fitted waste traps before but this one seems backwards as usually on the ones ive fitted the trap underneath just screws onto the bit under the plug hole. It says in on the webpage 45mm waste connection.40mm waste pipe fits into the hole if thats any use.
What i want to know is what type of trap do i fit as it already has a plastic nut on it????
The other thing is the tails ive used before are usually a male threaded end that connects to a standard tap connector underneath which always usually have a female nut on. ?????
Help please.
Edited By mark smith 20 on 19/09/2019 19:28:47
Oldiron19/09/2019 19:43:48
1193 forum posts
59 photos
I think you need to put in a short length of 40mm pipe as that is a compression fitting on the bottom of the waste outlet. You can then fit a "P" trap either shallow or standard to the pipe stub. The 10mm (presumably or possibly 1/4"bsp) male end of the tail should screw in directly to the new tap base. The female end will fit the end of a 15mm compression ( or soldered on ) to 1/2 bsp stud straight connector on the 15mm copper water pipes. If you need to connect to a standard old fashioned 1/2" bsp tap you have the wrong tail. You will need one with 1/2" bsp female on each end.
Hope this helps. regards
Edited By Oldiron on 19/09/2019 19:45:57
JasonB19/09/2019 19:48:48
Did you not get a bag with some other bits in?, these wastes usually come with their own trap and a few bits for connecting things like dishwashers, The first bit goes into that compression socket. Used to get them on Ikea sinks and franke do similar. Personally I tend to bin them and use one with a standard 1.5" male thread which will take the usual loose nut on a P or S trap. Our waste pipe is too loose in that compression nut.
The two large 1/2" BSP nuts will fit onto a 1/2" x 15mm fitting. Don't be tempted to screw it onto a compression fitting as the 1/2" end has a flat edge to the thread for the washer to seal against not the sharp edge due to the taper for an olive
The other end with the O ring screws into the bottom of the mixer
Edited By JasonB on 19/09/2019 19:49:22
mark smith 2019/09/2019 19:50:52
682 forum posts
337 photos
Thanks , if i fit a small piece of pipe 40mm , how do i fix the female nut screw end of a standard trap onto the pipe??
Also wondered if the large plastic nut already on there already could be removed and a waste trap could then just screw on ? Or are the threaded nut on the top of a standard trap likely to be a different size?
Edited By mark smith 20 on 19/09/2019 19:54:06
mark smith 2019/09/2019 19:59:46
682 forum posts
337 photos
Just a sort of flimsy plastic bush thing which im unsure what its for.
Oldiron19/09/2019 20:07:05
1193 forum posts
59 photos
Problem is these days there is a mix of 1.5" and 40mm fittings. You can get an adaptor to join the 2 but you may have to search for it. As JasonB says it might be simpler to go to Wickes or B&Q and get a standard sink waste then every thing will fit together. I do not think your standard trap will fit the waste.   regards
Edited By Oldiron on 19/09/2019 20:08:50
Oldiron19/09/2019 20:10:37
1193 forum posts
59 photos
The problem with using adaptors from one size to another is that the pipe work soon gets to be very long. regards
Edited By Oldiron on 19/09/2019 20:16:05
JasonB19/09/2019 20:19:56
Pipework is now all 40mm or 32mm and if threaded then that is 1.5" BSP or 1.25" BSP or G thread as they call it in Europe, don't get any 1.5" waste.
mark smith 2019/09/2019 20:35:46
682 forum posts
337 photos
I have 15mm copper pipe and 40mm waste pipe and a load of various solder ring fittings but with have to buy the bits Jason suggests. Havent bought a bottle trap yet. Problem is i dont really want it too long other wise the waste pipe will be going uphill.
I suspect Sauber who made the sink and tap are German.
Ian Johnson 119/09/2019 20:48:08
381 forum posts
102 photos
Hi Mark is this any use to you? It's under my sink and looks similar to yours, although mine is a one and a quarter sink. The trap (out of shot) is screwed to the pipe going to the left, it is actually on a slight angle but has worked just fine for the last 13 years. You could probably screw the trap directly on the thread where mine has the bend. Your little plastic bush thing looks like a spigot for a washing machine, this usually fits in the outlet which you can see on mine is blanked off, because the washing machine is on a separate system.
Here's a photo, ignore all the rubbish under the sink! who put that there?
Ian
RMA19/09/2019 21:50:17
332 forum posts
4 photos
You bought the items from Plumbworld and they are usually very good. I think there should be more parts than you have, I would phone them and check, I'm sure they'll help. All the sinks I've fitted come with a complete waste system, which you usually have to adjust to the layout you want, and it's not uncommon to have bits left over that you don't actually need. Seems daft to go and buy bits on a trial and error basis.
I should have added that the two tap tails, I usually fit direct to isolator valves. Dead easy as they just screw together. Makes life easier for future maintenance and they are really cheap from Toolstation etc.
Edited By RMA on 19/09/2019 21:54:53
mark smith 2020/09/2019 10:29:07
682 forum posts
337 photos
Thanks for all the help and suggestions i think i have an idea of what im doing now.
Ian yes it looks similar but without the side waste connector.
I have ordered the two 15mm x 1/2" connectors that jason suggested which will hopefully come by saturday afternoon.
RMA, there wasnt anything else with the sink/tap . I will proably just go to toolstation for any extra stuff i need as i want to get it done this weekend and would probably be next week if there was anything missing from the plumbworld order.
mark
Dave Halford20/09/2019 14:19:24
2536 forum posts
24 photos
Posted by JasonB on 19/09/2019 19:48:48:
You can always turn down the sharp edge on a lathe smiley
The missing part is a flat, hard rubber disc to block off the overflow neck. Putting an appliance that close to the sink can cause waste water to enter the sink or even spit it in you face.
Edited By Dave Halford on 20/09/2019 14:24:48
Neil Wyatt20/09/2019 14:26:45
19226 forum posts
749 photos
86 articles
Posted by mark smith 20 on 19/09/2019 19:59:46:
Doesn't that step down the outlet so you can fit an ordinary trap with a compression fitting at the top?
If all else fails, self amalgamating tape is your friend
mark smith 2020/09/2019 16:04:44
682 forum posts
337 photos
Neil,
It does look like something like that ,i`ll have to wait to my trap arrives to see if i can fit it on somehow..
duncan webster20/09/2019 18:14:06
5307 forum posts
83 photos
Posted by JasonB on 19/09/2019 20:19:56:
But solvent weld pipe is slightly bigger than push fit, at least in the nominal 40mm
JohnF20/09/2019 20:27:37
1243 forum posts
202 photos
I think 1/2 BSP female is intended to be fitted to a 15mm isolator service valve on the 15mm copper pipe, these are available in various configurations so make sure you get the correct one. For the trap/sink waste you can buy a short plastic pipe with a male thread at one end, just cut to length, fit the plain end into your waste then the trap fits as normal.
