Modification to a Harold Hall design
Roderick Jenkins | 17/09/2019 17:14:55 |
![]() 2376 forum posts 800 photos | My toolpost mill is very convenient to mount and I have been considering a similarly quick and convenient way to do simple indexing rather than mount my GHT HDA. This solution is based on Harold Hall's design **LINK** except I have made the base a permanent feature, that still allows the headstock cover to shut on to the buffers. The indexer slides onto a T slot and is secured by half a turn of the locking lever.
The detent spring is pretty strong, hence the big knob. The traditional coloured dots are for 4, 6 and 10 divisions. Rod |
Nick Hulme | 17/09/2019 18:06:34 |
750 forum posts 37 photos | That's cute, neat and well executed. |
not done it yet | 17/09/2019 18:22:15 |
7517 forum posts 20 photos | Lucky, you myford users. The bull wheel on my lathe has (useful?) factors of only 5 and 13, I think! |
Neil Wyatt | 17/09/2019 18:44:31 |
![]() 19226 forum posts 749 photos 86 articles | Neat, you could have won the MEW reader's Tips with that Neil |
JasonB | 17/09/2019 18:56:20 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by not done it yet on 17/09/2019 18:22:15:
Lucky, you myford users. The bull wheel on my lathe has (useful?) factors of only 5 and 13, I think! Someone will now suggest you make an expanding arbour to stick in the back end to mount any of your change wheels or plates from div head and an indexing pin. Edited By JasonB on 17/09/2019 18:58:45 |
martin perman | 17/09/2019 19:20:38 |
![]() 2095 forum posts 75 photos | Posted by JasonB on 17/09/2019 18:56:20:
Lucky, you myford users. The bull wheel on my lathe has (useful?) factors of only 5 and 13, I think! Someone will now suggest you make an expanding arbour to stick in the back end to mount any of your change wheels or plates from div head and an indexing pin. Edited By JasonB on 17/09/2019 18:58:45 Now theres an idea Martin P Edited By martin perman on 17/09/2019 19:22:44 |
Roderick Jenkins | 17/09/2019 20:59:04 |
![]() 2376 forum posts 800 photos | Something like this: Came with the lathe when I got it. As did this indexing arm: The pivot slips rather tidily onto the reversible thread/fine feed stud. Of course, if you have a gearbox it is unlikely that you will have many change wheels! (Mine did since it was a conversion, the gearbox was a later addition). I don't think the idea was ever completed, it needs a spring or something similar to keep the detent engaged. It's quite a neat idea though. Rod
Emgee | 04/09/2020 13:59:47 |
2610 forum posts 312 photos | If a gear tooth shape is machined/filed in the centre of the detent when rotated 90 deg you can get 1 tooth rotation as well. Emgee |
Greensands | 04/09/2020 17:20:47 |
449 forum posts 72 photos |
Martin Kyte | 04/09/2020 18:10:53 |
![]() 3445 forum posts 62 photos | Posted by Roderick Jenkins on 17/09/2019 17:14:55:
My toolpost mill is very convenient to mount and I have been considering a similarly quick and convenient way to do simple indexing rather than mount my GHT HDA. This solution is based on Harold Hall's design **LINK** except I have made the base a permanent feature, that still allows the headstock cover to shut on to the buffers. The indexer slides onto a T slot and is secured by half a turn of the locking lever. The detent spring is pretty strong, hence the big knob. The traditional coloured dots are for 4, 6 and 10 divisions. Rod I like the design and the neat way it it fitted, but I'm fascinated as to why you went to the trouble given that the VDH, which you already have, is fitted in under a minute which OK may be a few seconds longer than your bull wheel job but not much. Is the the extra time taken to wind the handle on the VDH when you only want to mill a square or drill holes on a PCD the consideration. Even so I'm impressed with you going the extra distance. Once I can achieve a function with the kit I have it takes the promise of big advantages to persuade me to build more just for the extra finesse. As I say this is certainly not a criticism of what it a very nice attachment just would be interested in your motivation. best wishes Martin |
Roderick Jenkins | 04/09/2020 20:48:23 |
![]() 2376 forum posts 800 photos | Hi Martin, Good question! I guess it's because the plates and sector arms etc. are normally on the Timmins head on the mill (and I don't have to wind the the handle 4 x 15 times to mill a square) Cheers, Rod Edit OK, 3x15 times Edited By Roderick Jenkins on 04/09/2020 20:53:06 |
ega | 04/09/2020 21:25:31 |
2805 forum posts 219 photos | Some excellent ideas here for quick and simple indexing. Here is my GHT-inspired solution for indexing work in the ER chuck: I have the HDA but it is slower to set up and the detent shown can remain in position when turning continues. |
Martin Kyte | 04/09/2020 22:49:31 |
![]() 3445 forum posts 62 photos | Posted by Roderick Jenkins on 04/09/2020 20:48:23:
Hi Martin, Good question! I guess it's because the plates and sector arms etc. are normally on the Timmins head on the mill (and I don't have to wind the the handle 4 x 15 times to mill a square) Cheers, Rod Edit OK, 3x15 times Edited By Roderick Jenkins on 04/09/2020 20:53:06 OK, I'm convinced. I have to admit to digitising my HDA complete with dedicated controller so my plates can remain on the Versatile Dividing Head which does have the adaptor plates to fast fit to my mill so on reflection I suppose I have put more effort in than your bull wheel mod to acheive something of the same aim. I suppose my main motivation though was once the division number has been selected no mistakes can occur with a stepper system, which eliminates that heart stopping moment when cutting the last tooth of your 290 tooth clock wheel leaves half a tooth missing. I tend to find the reason why someone did something as interesting as what they did. GHT was very good at explaining his thinking and I feel I learn more that way. best regards Martin PS (I realise I may have to calculate the relative chances of sector arm errors with that of power cuts for the new system but at least I can blame power cuts on someone else)
Edited By Martin Kyte on 04/09/2020 22:51:05 |
